troystg said:"assuming termal resistance scales linearly"
I was informed that doubling the height of a heat sink does not double the capacity. As the air rises it heats and is not the same as two separate heat sinks side by side.
Yours may indeed work; I am just repeating what I was told by a manufacturer about height.
The manufacturer disappointed me with news about my height, and my girlfriend disappointed me with news about my length. Rough times I tell ya.. 😀
Height and length should bre pretty much equivalent. Everything else is wrong!
I have sent an email to Conrad to see if they can do a massive 45 cm high (that is massive!) sink. I asked for 30 width, which I'm sure will satisfy even the most demanding people here.
Hi,Patrik Floding said:
Yes, but the MF25-151.5 in the catalogue is only 15 cm high. I was going for 40 or more cm. So at 45 cm it's 3x the weight (3 x 1.78 = 5.34 kg), and about 0.1 C/W assuming termal resistance scales linearly. Perhaps 30 cm wide and 45 high will do the trick.
the Rth s-a is approximately inversely proportional to square root of the height.
twice the height will give about 40% lower Rth s-a PROVIDED the Radius to thickness ratio does not exceed ~10 from the devices to the extreme corners.
Four times the height will roughly half the Rth s-a. i.e. 0.29 becomes 0.145 when about 600mm high.
Remember to de-rate from the deltaT=80Cdeg to about 25Cdeg.
when de-rated for both radius and for delta T one may find that Rth s-a has gone back up by 50% or worse for large area sinks and very much worse for thin sinks.
Troy,
the "Length does Not matter" club for weeny Hermans that i joined advised me to construct really big amplifiers.
I'm still waiting for the CRDs, so i started rebuilding Jam's Class A amp instead.
Hi Andrew!
Is there no chimney-effect with taller sinks?
Also I wonder how to best spread the devices to make the maximum of a sink like that.
look for Wakefield's design guide. It's on their site.
It tells you how to de-rate for temperature, how to place components to maximise efficiency, how to convert for different heights, confirms that increasing the width increases Rth s-a linearly. It confirms that the whole backplate should be at the test temperature to achieve the published Rth s-a values.
It does not say how to estimate the loss of efficiency for a thin backplate to radius ratio. But distributed devices alleviate this problem.
I think Fischer has a less comprehensive design guide and Conrad has a cut down design guide.
Go read.
Go read.
Hi Mark,
when you get back home please don't forget to send me the four boards and diodes.
Harry
Harry
Hi Mark,
When you get back home please don't forget to also send me my ten boards and diodes.
As soon as we have the boards Pierre Watts can start building and possibly be one of the first to finish a no holds barred KSA clone and possibly guide others re problems experienced.
There are three very anxious builders waiting for the boards in Cape Town....
Jozua
Cape Town
South Africa
Jozua
Cape Town
South Africa
Also one in Belgium!
Another one in Dubai. (Boards and doides.....)
Krell KAV-250
Gents:
Are we ready for a higher output Krell? If there's interest to work on the KAV-250. I can post schematics and layouts but won't do so for the heck of it.
Here are my conditions :
Al does the Boards.
Mark does the GB.
Troy makes me my kit
Let me know if there is interest in actually doing this.
I own a KAV-250 and love it, As nice as the KSA-100. Mkii sounded, I sold it after I heard the KAV-250. This is one Krell I'd really like to build.
At about 325 watts per channel into 8 ohms (rated 250) and 1000 watts bridged, good enough for almost any application, this is the amp to make !
K-amps
Gents:
Al does the Boards.
Mark does the GB.
K-amps
KAV 250
K-amps
Maybe you should first audition the new KSA 100 clone before you jump into a KAV 250 as there are many subtle improvements which might just make it sound better than the original.....
That is why we should start building these amps as soon as possible to hear how it sounds.
Personally this is going to be my last DIY amp so it going to be a "No-holds-barred" version. I have to draw the line with all my DIY projects.
Jozua
K-amps
Jozua
KAV250
I still haven't finished my KSA50, let alone my KSA100, but I would really be interested it the KAV. I've been wanting a KAV250 3ch for a very long time.
Robert
Robert
stop it! your killing me! I said that two amps ago.
Re: Krell KAV-250
Hi K-amps. Yes Im in and I would like to join this Krell clone project as I did to the KSA 100 clone project. If this would be a real project, Im in for at least 6 boards.
I liked what I read about the KAV 250a and what I really liked was its balanced input design, something I lack for the KSA 100. Is it possible to implement that solution to the KSA 100 amp? If yes, it could be a part (# 1) of the whole KAV 250a project?
Could you say anything about the technical solutions used in this model? Are the balanced input configuration build on a separate PCB or is it a part of the front end at the main board?
Regards 😎
K-amps said:Gents: Are we ready for a higher output Krell? If there's interest to work on the KAV-250. I can post schematics and layouts but won't do so for the heck of it.
Regards 😎
I Just got married last week so count me out on this one! I might buy a set of boards though for down the road a bit. I can barely find time to finish shipping the last of the diodes and boards from the last Group Buy... They are trickling out but just barely.
Mark
Mark
Hi Mark & Co,
that's our good luck!
Now there are twice as many of you and the job (sorting/packing/posting) gets done twice as fast.
Your not sacked, you've just had your contract extended.
- Krell KSA 100mkII Clone
