^could be using the smps type power supply, it may even be a class D that is why it is lightweight, my guess....
hello mga sir...im just asking if how to wire a series and parallel connection from power amplifier to speakers..Konzert K8 is my amplifier....it say 2x1350watts at 4ohms and 2x800watts at 8ohmsss..here is my spekeres 2pcs 450w 4ohms and 2pcs 300w 4ohms...what is the proper setup or wiring connection for this setup without damaging the speker or the amp..
thanks in dvance
you can only use either pair....
You can use 50 hz but the transformer will have much heat than the 60hz
Hi, Im new here. Im wondering if anyone could inform me where the konzert service center is? I have a k6 power ampli that needs repair. Umusok kasi to and i had it checked by a technician, sabi niya he needs the diagram. I hope you can help me. The power amp is used in the church. Thanks
transformers designed for 50hz will have more primary turns than a traffo designed for 60hz, it will run cooler when operated at 60hz.....
Sir Tony...good days po.. to you...i just want to ask you if...the diagram you given to be can be supplied with +-100V...the modified AV502...
thanks...benny
thanks...benny
Yes more turns but smaller size of wiretransformers designed for 50hz will have more primary turns than a traffo designed for 60hz, it will run cooler when operated at 60hz.....
thanks...benny
yes, you will have to change your trannies to ones with min Veo rating of 200volts or more....
@eesbiboi
very good job...now the only concern is the cover...it must be really firm and secured from flexing otherwise problem may occur...but all is looking good...kudos bro.
try to mod the cover something like this sample from nexo dual 18.
Sir jojo..
Just wanna ask, whats the use/purpose of of the cover (whole being reduced)
Nways, are the Cerwin Vega cabinets are more boomy? what are the characteristics of this cabinets.. thanks
Sir jojo..
JE-36C CERWIN VEGA FOLDED HORN SERIES SPEAKERS SUBWOOFERS
CV
Thank you sir...
What are effects of this compare to the regular baffle cut-out.
Thank you sir...
Thank you sir...
To Sir Jojo,
At your Constant Pressure Site, what plan exactly is the BP118, RCF of ACM?
It's a 6th order bandpass configuration...no relation to the above mentioned...
Sir jojo.
When using the MT-130 , is it necessary to use with delays or other enhancers? thanks
Sir jojo.
Yes...use your Delay in the Loudspeaker management (DBX driverack or Behringer Ultradrive) to time align your drivers...
Thanks sir..
- Live Sound
- PA Systems
- Konzert Amp & Speakers Website
