@edu,
hi, Ah the electro tech from raon, IMHO if your gonna use it for p.a. (mostly speech only) it does the job well, long throw, high efficiency but highly directional. You gonna need 2 box per side for more or less uniform coverage. They sound a little thin compared to a bass reflex cab and a lot of eq. However if you prefer to use this kind of speaker system may I suggest that you use a speaker with a 3 inch voice coil minimum to avoid sounding to thin.
Best Regards,
audiomachines
Best Regards,
audiomachines
hello sir audiomachine,
can you give me any buying tips for my 350W@4ohm bass guitar amp. Does raon's crown and dai-ichi instrumental speakers are "ok"? I don't want to shell out on "branded" speakers, too expensive for me.
Sorry to the thread, I just don't know where to ask this, Kudos
@asdean,
Well I could suggest Dai-1chi IS line of instrumental speakers (the one with the blue stickers on the back not the orange ones) http://www.daiichi.ph/professional.htm A quad of 10"s or two 12"s (or a quad of 12''s, it's gonna be loud!) on your bass cabs for a balance of power, clarity, punch and bottom end. A single 15"er, IMHO they sounded 'slow and muddy'. However that just my opinion. Good luck.
Best Regards,
audiomachines
Best Regards,
audiomachines
@sir audiomachine
sir im planning to buy lexus audo speaker 15 inches carpeted around 7,200 pesos what can you say about that speaker? is it good or i would go for b3 speakers around 11thou? i want clarity and crisp sound speaker . i heard lexus speaker and it sounds good crisp and clear. but im not very sue what speaker im going to buy. please give some advice . or i would other brand? im also planning to buy K4 amp. pleasea dvice me i have 14thou for my speakers . i have w-bin for my bass . so im planning to buy lexus audio speaker or B3 speaker. pls give advise. thnx
@olaop,
The B3 speaker has a good reputation, it does a good job as a stage monitors and for FOH too. I would suggest that if you go for the B3's get the one with the wooden enclosures (personally I don't like the ones with the molded plastic enclosure). The Wharfdale EVPS or LX models would be a good choice also and I think it would fit your budget. I have personally use the EVPS and LX line, they don't sound as powerful as the B3's BUT they were more smooth sounding especially the hi, smooth and extended..Hope this helps.
best regards,
audiomachines
best regards,
audiomachines
Midhigh box
Sir Audiomachine,
if I prefer to use this electro tech midhigh what size of speaker is the best and brand affordable but sounds good. use mention here 12 inch is better than 15 inch. surely i will follow your suggestion your the expert. I will use it for PA and disco I have 4 pcs.18 inch sub.
Sir Audiomachine,
@sir audiomachines
ok thanks for the advice about B3 speakers , how about the lexus audio speaker 15" carpeted @ 7,200 pesos each. what can you say about lexus speaker? im going back to stage point at raon im going to test the wharfdale speaker . im planning to buy wharfdale or lexus audio speaker? w/c is better of the two? 14-15thou for my pair of speaker. first week of december im going to buy my speaker when i receive my 13month pay . thanks for the advice .
@edu,
No sir I am no expert, I am just sharing what I have gathered/learned from my colleagues (in the sound system biz), costumers (some of them where really "old timer") and from personal experience. Yes a 15''er will sound muffled on your electrotech (too much midbass and it's gonna rattle the fiberglass horn) I have a pair here loaded with JBL E120 and it sounds good. I can only suggest/generalize that you use a 12"er on your electrotech with a 3in voice coil (minimum) and look for a speaker with a smooth cone not the ribbed one's, the ribbed ones are for midbass applications. P.Audio and TnT has some affordable 12''er. Hope this helps.
best regards,
audiomachines
best regards,
audiomachines
@olaop,
I would definitely go for the Wharfedale speakers over the Lexus. They are made in China but they are British and they are no amateur in the speaker manufacturing biz. Check this link http://www.wharfedalepro.com/Default.aspx?dsplType=1&cid=46&ParID=1&IdLang=1 Hope this helps.
best regards,
audiomachines
best regards,
audiomachines
ok thank you very much ill go for wharfdale sir. but what can you advise between lx and evp . the price of evpx15 is 7600/pc and lx12 is 10,500 and lx15 is 12,00/pc / what can you advised about that speakers / i want to buy evp series because of the price , but if lx performs better ill go for lx / but if this lx and evp performs always the same , ill go for evp so i can buy 1pair for my budget. any suggestion between evp and lx , is there any big diffrence between these two series? so i can make invest more money to LX series if theres a big diffrenece between evp and LX . lolz this my christmas gift for myself thats why i want to make sure what speaker to buy and im not going to regret . thks for the advised master audio machines
@olaop,
the LX line handles more power than the EVPS but the sound quality is the same. I think if I remember it correctly some of the early LX line I had had diecast woofers (the EVPS uses stamp steel baskets). You'll be surprise with the sound of this speakers they don't sound like P.A. speakers.They are articulate but won't cause you hearing fatigue.
Best Regards,
audiomachines
Best Regards,
audiomachines
@audiomachines
can i use this speaker for outdoor?
i want to use this speaker for indoor and outdoor , would it perform well either lx or evp outside my house? im very noob about this matter thanks for your patience master audiomachines / i want to use this wharfdale speaker also during parties other occasions like christmas and new year's eve including my 15" wbin /.what do you think and please give some advise / im planning to buy also K2 or K4 amp to drive this speakers . please advise also what power amp to use. im going to raon this afternoon to test this wharfdale speaker . thank you for the advised
@olaop,
sure you can use the speakers outdoors, just don't get them wet (rain). A k4 or k6 would be enough. The EVPS were rated 300W continuous, 1200W peak. The LX were rated 400W continuous, 1600W peak.
Best Regards,
audiomachines
Best Regards,
audiomachines
@audiomachines
sir ive been there to stage point , we have tested evpx 15" and lexus lvp15 carpeted 15" , both sound good, wharfdale was good , wharfdale good in bass , but lexus was good in mid and high freq based on me hearing. after tested the speaker , i went ito electrotech store and we have tested B3 TS260 plastic 15inches 250watts RMS . and it sound good also , for me it is a mix of wharfdale and lexus . wharfdale for bass and lexus for tweeters equals to B3 TS260. B3 was very good very crisp and clear. im very confused what speaker to buy, any comment about B3 TS260? is it good speaker than wharfdale and lexus, TS260 around 9thou each? ill extend my budget to 20 thou for 1pair of my speaker . just give advised if it is worth it to buy B3 TS260 or i would still go for EVP series? or any suggestion about B3 Speaker around 20 thou . thnks
Guys,
it keeps me thingking on your inputs of different speakers, actually I need speakers box for midhigh but can be use also as full range on other occassion if needed i dont like to bring my sub for small occassions. sir audio machine your input please shall i use 15 inch or 12 inch. is wharfedal and lexus available in raon? particular store I can visit.
lexus and wharfdale are available in raon also you request to test those speakers . im still thinking if im going to buy the B3 TS260 speaker if it i worth in than wharfdale evpx 15".
- Live Sound
- PA Systems
- Konzert Amp & Speakers Website
