Kicker ZX1000.1
How about it, the voltage does not drop, the fets are original (from another amplifier and from the same batch) based on the source it was an assumption, thinking about all the possible scenarios, now I see that it is not due to low voltage or amps but rather that it is protects and when protected the source is turned off
The red LED and pin 4 came on, I saw that it reached 8v and it did not send pulses to the u2 source fets.
I found this small 2t Q8 transistor with a leak between the collector and emitter, I changed it and it seems to be working well, it is no longer protected, I will continue pressing the amplifier to see how it reacts
