Kicker KX600.1
This amp has the red board with the date of 2005.
Amp is stuck in protection mode all of the outputs test good .
TL494
Pin 1:0.00
Pin 2:4.96
Pin 3:0.05
Pin 4:0.00
Pin 5:1.47
Pin 6:3.65
Pin 7:0.00
Pin 8:0.61
Pin 9:0.03
Pin 10:0.04
Pin 11:0.63
Pin 12:13.65
Pin 13:4.96
Pin 14:4.96
Pin 15:4.96
Pin 16:0.00
Here are some pics let me know if you need more
R22 in this amp is not a 2k
More messing with this amp .
Both power and protection leds are lit .
Here is what I bet on the 494
Pin 1:0.00
Pin 2:4.97
Pin 3:0.05
Pin 4:0.01
Pin 5:1.48
Pin 6:3.68
Pin 7:0.00
Pin 8:6.24
Pin 9:2.39
Pin 10:2.39
Pin 11:6.20
Pin 12:13.39
Pin 13:4.97
Pin 14:4.97
Pin 15:4.97
Pin 16:0.00
I get + - 12 volts on opamps
I get + - 57 of rail voltage
Amp has no audio relay doesn’t engage and both leds are lit
Any ideas ?
Sorry I've been dealing with water damage at my place and haven't been able to attend this. I will be in and out for a while. The answer to your Posts 15 and 16 is No. There should be ~12 volts at Pins 8 and 11, which in turn will allow 5-6 volts on Pins 9 & 10.
There is something not allowing the soft start circuit to ramp and latch.
