kicker 1500.1
Ok I have a question Like an idiot i was tired and put the class D board in backwards and powerd it up. Now it goes into protection. Yeah i know im an idiot.
Wondering if you think i damaged something on the main board or did i damage something on the class D board??
The gate drive signal for the power supply MOSFETs doesn't look right.As Perry said it causes cross conduction,that is why it has higher idle current.The falling edge of the pulses shouldn't have this slope.Try MJE171 and MJE181 for the MOSFET drivers for example.This problem needs to be taken care of,so it doesn't cause problems again.
Don't worry about the output inductor getting hot.The material used is 60(hi temp 200C Micrometals).Thermal runaway and aging will not be a problem.Also it uses the top plate as a heatsink to help with cooling.Anyway,I am working on improving this with a new lower loss Magnetics core.
I will send you MOSFETs ,but be carefull next time
I don't know about this amp but on other amps, it was possible to blow the outputs with no remote voltage applied. The energy stored in the rail caps was enough to blow the outputs when removing/installing driver boards. Allow the rail caps to drain completely before removing/installing the driver board.
Perry ,
I should be getting the parts later today for this amp.
The orginal gate resistors were mark 1000 so i figured they were 100 ohms gate resistors thats what i put in the amp.
The orginal fets were irf3205's i replaced them with Irf3205's but wondering if the fets could be the problem with this amp? (not enough dead time)
Yes he does and im am very very thankful and appericate it alot that he sent me the rectifiers for it.
Ill try what he suggested for the drivers.
I also found a bad transistor in the output section so im gonna replace that when replacing the outputs.
I actually designed the ZX1000.1 and ZX1500.1 5years ago.
Mike,change the driver transistors as I previously said.Also,I am sending you 8pc IXTQ36N30 today.
Perry,you are of huge help in the forum ,please keep providing your opinion.Obviously you have long experience in car amp repair .I personally have shown your BCA website to many people who want to learn more .It is pretty well done 🙂.
Hi guys, I happened upon this thread and thought I would offer a hint that has helped me a lot in the past. I used to repair most of the car amps in Kansas City years ago. One of the best troubleshooting tools I had was an adjustable bipolar power supply. You can feed the amp section directly by clipping onto the rectifier leads and with current limited, you can trace where the short/dc offset is occurring.
A lot of amps would produce audio as long as the turn on lead had 12 volts (not the main power lead). This would eliminate the power supply and possibly save it from damage.
Regards, gearheaddruid.
