Kenwood KAC-9104D drawing high current
Have a Kenwood KAC-9104D that powers up and has output but draws high current and cuts off when played moderately. The power supply feeds it 13.65v which pulls down to 11.7v when the amp switches on. The output inductor gets hot at idle. The PS Gets gates have 4.46v on each bank. The rail voltage is ±69v. Legs 1-3 reads 5.0v on positive outputs, and 5.2v on the negative outputs. Across the speaker outputs reads 700mv. I have tried a different known good inductor with the same results. I am posting pics of scope readings at various locations, with probe grounded to GND terminal.
There may have been a sticker or something on the board previously but the black residue wiped off with acetone. The inductor seems to be evenly heated all around. Touching it would cause me to pull away my finger in 2-3 seconds from anywhere around it. The one I swapped in behaved identically.
This is the other side of the board. It looks mostly original except for R903 and R904 and some of the SMD components in that area.
Using the OWON VDS1022I instead. Please excuse the monitor screen distortion.
Posting screenshots of pin1 and pin7 of IC7 (NJM 4560).
Yes, there is clean audio from the amp. Posting a scopeshot of the speaker terminal. I placed the board back in to check for audio. I will remove it again to check for the triangle wave on pin1 of IC6.
The problem with this amp was that it drew higher current than normal, and it cut off when trying to raise the volume.
Earlier, you stated that there was no audio being driven into the amp. The signal seemed to be modulated. That's why I asked if there was any output (of any sort) from the amp... with no audio being driven into it.
I'm assuming that that's music and not a sine wave. Is that correct?
There was no audio/signal being input to the amp before now. The shot from the speaker terminal was audio, but that same waveform was present with the music playing and with the RCAs unplugged, just that when the music plays it vibrates/shakes but the waveform remains the same.
Make sure that you're seeing the actual v/div that you're marking the photos with. For example, the triangle waveform should be about ±4v.
Repost the previous 2 images but connect the scope ground (the scope probe's ground clip) to pin 3 of IC6 (or any close ground) for the triangle waveform photo. Ground the scope to the negative speaker terminal for the speaker output waveform.
The settings that are marked on the pics are the settings I have to use to get the complete waveform displayed and about three cycles. The triangle waveform cannot be displayed completely when set to 5V/div, not even at 10V/div. Only set at 20V/div can the complete top and bottom of the waveform be displayed.
on 5v/div, if you touch to the 12v supply, do you get a deflection of just over 2 major divisions?
The 9104 doesn't have waveforms but the 9103 is very similar and does have waveforms. Look at pin 1 of IC32 (same as IC6). The triangle wave shouldn't swing more than about ±4v.
