John Curl's Blowtorch preamplifier
Also, how did Charles Hansen and I deal with this problem with mosfets in our designs in the 1980's. And how did Toshiba deal with this problem with its jfets?
I don't really know what you and Toshiba did decades ago, but it is not a secret about FETs, that one can alter some parameters of a FET by changing it's geometry (e.g. channel width against length) in order to reach a certain gm.
At a given chip area/capacitance you can then at least adjust gm to a certain target value, while leaving the capacitances rather untouched.
This kind of "matching" would lead into two "complementary" devices, which are perhaps equal in two or three parameters, but the rest would vary even much more (think about Early effect, leakage currents etc. etc.).
The trick to select simply a higher voltage rated N-Device will probably lower the differences in the above described manner, but it will never ever solve the matching problem.
The best solution for the matching of complementary devices is not using them in a complementary way, so you needed decades to solve a problem with your Blowtorch, which actually never existed !
The best matching of complementary FETs was btw. probably reached with the power V-FETs (SITs) from Sony in the early seventies.
john curl said:
Mosfets too?
MOSFETs are my preferred output devices. No second break down, a lot faster and less high order crossover harmonics (7th!!!).
But listen John, I've learned a lot from from you, for example that JFETs are (slightly) less noisier than BJTs. But.. please.. don't provoke me with that Bybee BS (or burning in of wires). If you do so you, I really can't resist the temptation to poke fun at it.
Edmond.
john curl said:
Many here, especially my critics, may wonder why I ask these questions about complementary FET matching. It is not to be negative, but to show people who find these questions difficult, that they are significantly behind on how the BLOWTORCH, AYRE, and many other fet topologies actually work, and the problems we have solved over the decades.
I would think that it should be a prerequisite that a certain level of understanding should be attained, before judging what you didn't design, and really don't know much about.
Real men don't match FETs. Real men use feedback.
(This is also a joke. OK, that's the intend.... I think.)
Jan Didden
SY said:
Are you going to talk about the different carrier mobility?
Too esoteric. The majority carrier mobilities in the N vs P FETs cause several problems. The match of the "beta" parameter between, for instance, the 2SK170/2SJ74 is actually pretty good. That means the gm's at equivalent Id's are fairly well matched. The doping concentrations unfortunately give large differences in Cgs/Cgd as well as not very well matched output impedances. The P FET's remain free of excess gate current as a side benefit.
That, but mostly the 2...3 factor in area. Matching P/N gm requires W/L 2...3 times larger. Hence, larger area, Cgs and Cgd. The lack of excess gate current in P devices follows the same electron/hole assymetry. Holes have lower diffusion coefficient, hence lower diffusion current in the gate region. BTW, "beta" is proportional to the majority carier mobility.
