John Curl's Blowtorch preamplifier
Apparently, I was incorrect that PMA was rewarded by Parasound. However, his associate was. Sorry about that.
There is a paper in the AES preprints that talks seriously about two stage compensation. I suspect that it might have a complex transient response, because of this. The circuit I designed was for continuous tone operation, so it didn't matter.
scott wurcer said:
We still make this one. From a 10-20 Ohm source where would you bias this one?
I have a question for Scott: I wonder how the first graph looks like for Ic greater than 1mA. Is hfe still constant between 1mA and 20mA?
In particular I'm interested in hfe linearity when operating the MAT02s at around 10 - 12 mA.
Thanks for any info you might be able to provide
The 1978 paper presented at the AES (LA) that goes into 2 pole equalization is:
'Design and Construction of High Slew Rate Amplifiers' by Takahashi et al, from Sansui.
As I feared, the transient response is suspect, with 2 pole compensation, BUT that might still be OK. It might have gone to the JAES, but I don't have that reference at this time.
engineering is always about tradeoffs - saying you will not accept any overshoot closes off the possible gains elsewhere in the amplifier performance
pushing more than single pole gain into the outer loop will extract some cost in overshoot/frequency response flatness at high requencies - but for typical SS amps this occurs way beyond "audible" frequencies
10-20% overshoot that can be compensated by ~200KHz lpf would seem to be a possibly good trade off for >20 dB more gain over the entire audio spectrum - leading to as much as 100x reduction in input pair distortion from 3rd order gm nonlinearity
an additional "cost" is considering overload recovery of higher order gain systems - "nonlinear compensation" in the form of diode clamping or more complex schemes enable higher loop gains with reasonable overload/clipping response:
http://www.diyaudio.com/forums/showthread.php?postid=512806#post512806
for tailoring loop gain for "Bode's maximum gain" B J Lurie's book and Mitchell's papers are useful:
http://www.luriecontrol.com/index.htm
http://ukacc.group.shef.ac.uk/Control_Conferences/Control2004/Papers/063.pdf
