But I'm out. bad music to find and threads which are not as toxic.
That's getting to be more my feeling about it too. It was once more gentlemanly, more professional. The trolls are pulling it down to their level. That's the way it is. The neighborhood has badly gone downhill, one can fight back they way they fight or worse, be overrun, or leave.
But this is typical of so-called "objectivistist" that we see on audio forums - they are, almost by definition, not curious enough to investigate outlying phenomena. I'm not saying the Bybees have or have not an audible effect or have/have not a coating on the foil which is where the thousands of virtually nearly invisible devices" exist but I've seen SY's 'analysis' & he is very much the "performance artist" that he accuses others of being - much like Randi
I look forward to your much deeper analysis. I'm sure it will benefit from your extensive knowledge of auditory perception.
(oops, I didn't post the second post earlier, here it is)
The Gedlee Metric Demystified
I still see this as only a moderate improvement. It still uses a single number that's a conglomerate of several effects.
So here's my thing:
I propose TWO numbers, one for the amount of, say, second, third and (maybe) fourth harmonics, and the other for the amount of fifth and higher harmonics (the exact composition and proportions of these should be determined experimentally). The first could be called "Low Harmonic Distortion" (LHD) and the second "High Harmonic Distortion" (HHD).
A higher LHD number would come from tube designs and low-feedback solid-state designs such as Pass' DIY amps (and the quadratic and cubic distortion curves that PMA mentioned).
A high HHD number would be from traditional high-feedback solid-state designs which are not executed well, and which (attempt to) rely on feedback to reduce distortion inherent in the design.
Ideally in a good device both of these values would be low, but a higher LHD number would not be nearly as objectionable as a higher HHD number.
It's always been hard to quantify sound difference vs. measured distortion (THD or IMD). The measured values of THD and IMD became common because they are (relatively) easy to measure, but they don't correlate well with the sounds of different amplifiers (or other audio electronic devices). Here's one attempt to make an improved measurement value:I think I understand what you meant. But then it will be even more difficult to quantify non-linearity and relate it with perceived sound difference.
So here's my thing:
Exactly, excellent observation.I think that the non-linearity is a well defined term. The problem is that when a common audience says "distortion" they in fact mean any difference from the original. This may contain frequency response amplitude/phase change (which is a linear effect, "linear distortion"), creation of new frequencies not present in the original ("nonlinear distortion"), or irregular sounds like speaker mechanical problems.
When the EE educated person says "distortion", he means a nonlinear distortion, i.e. creation of new frequencies not present in the original signal. He does not speak about changes in frequency response, which is a linear effect. Unless same and correct terms are used, there is always a misunderstanding in a written communication. Both camps understand same words in a different way.
Here, this should tie it all together:Did you watch Uri Geller on the Tonight Show, quite a performance. I guess Johnny "cheated" by farkleing all the magician's props before the show.![]()
YouTube
YouTube
Brilliant actually, I figure this is what would happen when certain people were confronted with a no cheat DBT.
OK badly recorded ska covers of beatles tracks is my current hunt.
YouTube This is great. ToS should be amazing out your cornucopia
I loved it, especially the boozy drumming. Takes a lot of talent to hip-sway the beat like that, and to be honest, the band out beatled the Beatles.
You wanna check out ‘London Zulu’ by Doreen Thibokele. Soweto dancehall meets Brixton funk.
ToS
There is a saying in the Pass Labs forum, "no pics, it didn't happen" 😉
Elsewhere on the internet it means "show me the photos of your naked escapades that you just bragged about"
generally written
Pics Or It Didn't Happen
You won't beat the trolls by claiming you can hear -120dB IMD, THD, whatever. You only demonstrate your own trolling skills.
Know what's funny? I can leave this thread whenever I may think I've had enough of it, like SY and so many other already did; you and your mmerrill99, Jakob(x), JC and the rest of the gang can't; it's your raison d'etre in audio 😀.
So how about describing how IMD 'reflects in sound' for the benefit of all.IMD is just his imagination. I am sure he has no clue how it reflects in sound.
I have been on both ends.It probably seems more petty the more one likes Sy, misses him, and wishes for his return. If one has been ridiculed by Sy, then pointing out Sy's imperfections may seem much less unfair.
I do not have to like a person to know that they are upstanding.
If everybody "yessed" me, I would worry.
Sy's analysis, as much as I've seen, is above reproach.
Of course, that is just my opinion, worth very little.
Jn
'Dialing in' in this context is physical changes that improve clarity and discrimination and intelligibility in the sound and nothing to do with 'warm up' or 'break in'. Dialing in is physical changes like speaker positioning, speaker mounting, cables, power filtering, crossover capcitors etc that can help to reduce distortions and maskings that obscure low level information in recordings such that this detail is 'magically' revealed.“Yes, as the system 'dials in' as you say new sounds can appear as if by magic. ” The only systems that dial in are ones that perhaps need a few minutes for bias to stabilize or tubes to heat up.
I have no doubt that your 3 months in the bush heightened your expectation bias and that after a few days reality struck home that the system that you imagined was not so good after all. This is perfect example of your deluding yourself, my brain<>ear does not lie to me like that, I am yet to hear an unchanging system where my initial impressions changed with exposure, rather my initial impressions are confirmed with exposure. I can learn to maybe tolerate an aurally unpleasant system but I never learn to like or enjoy such a system and most certainly I never consider such a system as great. I do not claim superiority in this point, it just means that I have heard so many components or systems in so many situations that I have learned to not pre judge and just listen in order to understand the sound and do it quickly.......live sound mixing is a good teacher.In my not too inconsiderable listening experience, it’s your brain<>ear system that tunes in. I’ve heard systems that were initially very aurally unpleasant but after a few days, sounded great. In another life, I was in the military and would go away for 3 months. I remember coming back from the bush and my system would sound absolutely fantastic for a few days before it returned to sounding good. As far as I know, there wasn’t any communication going on between the electrons flowing around my gear and my commanding officers.
I have not mentioned -80dB distortion but would say that IMD distortion sensitivity is much greater than THD sensitivity especially with 'dense' music and further noise floor level and spectrum sensitivity is greater than we give credit for. What these levels are is open to speculation and probably not definable because of many dynamic system interactions, but it is certain that one relatively minor change in a system can cause relatively major change in system sound output. I do wish that you would accept that THD numbers do not describe sound and that other people do reliably notice changes due to seemingly minor system changes.I do wish folks around here would accept that the stuff they hear (here’s looking at at you Dan,mmerill, et al) is generated for the most part between their ears. You can’t hear -80 dB distortion products (ie below music peaks) but you sure as hell imagine you can.
But that is coaching.....😉.Why do people forget that using things like Reaper to learn the differences in sounds is totally on the palette for testing. The process of testing BEGINS with educating the ear and mind to the sounds you are trying to differentiate. That is not only allowed, but called for.
Then, after you think you can differentiate the sounds, take the bloody ABX test. p=0.95, yah, I really can hear it! p=0.5, oops, try again. p<0.4, you're listening to the wrong thing!
Cheers
Alan
Heard just this evening that "Obla Dee, Obla Da" was written as a tribute to Desmond Dekker. It's also the closing song in _Yesterday_ (recommended).OK badly recorded ska covers of beatles tracks is my current hunt.
All good fortune,
Chris
I wouldn't know and didn't say that, as you well know. More dirty politics debating games. Bye.
If you can probe someone's brain to determine for sure what their ears transmitted to it, then sure, it is probably "real."I have to defend Dan's 'Goop' as doing something real, and perhaps very useful. It would not be the first offering of such a substance. Peter and May Belt offered something like it in previous years, and perhaps still do. I hold that 'if you hear a difference, it is most probably real'.
Since you can't do that, then the only data is what the person has perceived which is made up of many things beside what they "hear." We don't do controlled tests because we are stupid. We do them because they are necessary.
Well put, some of "the bored old men" (Mark's descriptor) are probably just here for entertainment and aren't very interested in proper tests and evidence apparently
Is there any other value? Interests are many but none to the actual sound reaching the ears. 🙂
It seems to me that is the main interest of those that are serious, "the actual sound reaching the ears"
Speakers don't get discussed much here and drivers are not easily DIY'd. Distortion figures aren't often published. But measuring at the listening position is very informative. Who can or wants to listen nearfield?
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part III
