John Curl's Blowtorch preamplifier part III
I was actually thinking about the possibility of having the open loop gain dependent on the output current. It can't be abrupt, as the output can saturate. But gentle, that may work.
Jn
Oh, edit: I'm not thinking of suspension non linearities, but magnetic force/acceleration non linearities.
Dumb question time. If we are considering smarter drive, should we consider smarter speakers? At the moment they are not like motors as the restoring force of the suspension doesn't allow you to put them in one place and for them to stay there. So you are fighting a whole load of sources of inaccuracy that you don't need to. Pig meet lipstick.
You mean something like this ? MFB LF section
Indiglo: That looks very similar to the infinity servostatik. I need to compare with my old sub. I was thinking going a few steps further and trying to move towards the sort of promise that NXP claimed and never delivered. Segmented electrostatics also show promise with enough segments, but they bring their own slew of problems 🙂.
Throw enough tech at the problem and sure we can reduce something by a gnats chuff!
There's lots of ways to measure position, fast and with precison, without loading a cone these days - if anyone wanted to do it they could. You could even use several, and try and compensate for the cone distorting in shape. No one seems to be doing it, either amateur or pro.... I wonder why....
His work could be as simple as you said, but not enough was shown and his explanation defies understanding !!!???... 😕
Yes, Joe does use inappropriate terminologies and this causes confusions.
The key to what Joe is saying is that reactive currents need to be contained within the loudspeaker 'system' and then the loudspeaker appears as an 'ideal' resistive load to the driving amplifier.
The crux of the matter is that most (economical) amplifiers that are blameless when driving pure resistance loads are not 'blameless' when driving strongly reactive loads.
Dan.
Running over the same point again and again. How many times?
Why the objection? Persistence is not a bad thing. Besides, there has been a LOT of progress and there is now more traction on this than ever. We are able to draw on other people's experiences, even some really good raw and solid measurements. I give others credit where it's due. a new more high resolution measurement is being developed - once a train gets momentum, then it becomes harder to stop. So maybe get on board rather than trying to stop it.
Back-EMF and flat impedance
George
George, you do realise that a moderator must have started that thread!!!
I certainly have no memory of doing it - and I would not have used "Back-EMF and flat impedance" as the title. So I definitely did not start it. (Did Pano?)
So maybe you have over-rated my efforts? Never mind. Sigh.
Cheers, Joe
PS: As it seems I have the right to edit the first post, so I did, just to set the record straight - so check it out.
www.diyaudio.com/forums/solid-state/329854-emf-flat-impedance.html#post5572601
Its not as simple as you think and nothing Joe has stated is anything new...
What is this obsession with the 'new' word. I haven't even used that word.
Philips... and Panasonic were aware of these issues since the late 60's.
That made me chuckle.
My Dad used to work for Philips as an engineer.
I used to work for Panasonic.
In a few days I will be 67. You would be surprised at my track record. I have been around, know what I mean? 🙂
Cheers, Joe
Sorry, completely wrong. It is the complex load nonlinearity that creates the distortion seen.
You have missed the obvious. The distortion is current distortion of the amplifier. The amplifier is only able to keep distortion low when looking at the voltage. This is a clear as the nose on your face. I am sorry, but not getting it, you are completely wrong.
In case of linear complex load, there is no distortion - attached. "Back EMF" view is a nonsense.
Not at all. RM has just posted shortly ago that he senses that back-EMF is at the heart of this. Indeed the mechanism that explains it is rather straight forward, if not entirely obvious. The back-EMF modulates the current side of the amplifier and creates current distortion. The current sense resistor converts this into an accurate representation of what the current of the amplifier is triggered into doing. This now becomes the input of the speaker, not the voltage, but the current. This now becomes what is translated into dB-SPL that we hear at the front of the driver in a box.
There is absolutely nothing new here. This is always how it has been.
It also proves why a current source produces less distortion than a voltage source. Now the back-EMF cannot modulate the current of the amplifier, now the voltage across the current sense resistor looks a lot cleaner. A current source cannot supply reactive current, the voltage source does so happily, and now we got audible and measurable increase in distortion, but via microphone and on the current (actually the input) side of the speaker.
It also proves once and for all that a dynamic driver ignores the voltage of a voltage source, it simply reacts to the current that the amplifier supplies, the voltage becomes secondary.
The voltage of the amplifier tells us what we should be hearing, but the current tells us what we are actually hearing.
And at the heart of this altered current is the back-EMF impedance of the driver. Yes, I said impedance, because at any frequency you can indeed measure that back-EMF impedance and give it an Ohm value.
And thus it has always been. Just take a closer look. 🙂
Joe Rasmussen said:
But there there seems to be some difficulty in grasping that in controlling the voltage, the voltage source relinquishes control over the current.
I don't have difficulty grasping that. In fact I expect that. That is what is meant by a voltage source. Where are all these people who think otherwise?
I am afraid the rest of your paragraph got lost somewhere between what you mean to say, and what I seem to be reading on the screen. Maybe you are saying that the load impedance sets the current drawn from a voltage source? Such deep thought!
I have been talking about this topic for years and engaging many in it, but online it is far more difficult, and that is kinda sad. Yes, this is social media right here, even if some here would like to think otherwise.
I guess you could call DIYaudio social media. Online is not more difficult; you just have to use words to convey meanings. If people don't 'get it', it could be that they are thick or it could be that you are not expressing yourself clearly enough or it could be that they believe you are mistaken (and have probably tried to say so).
You just made my point perfectly. Yes, I recognise social media and the attitude it engenders when I see it. This combative style you have adopted, you aren't hiding it.
You treat us like idiots then complain about our attitude? Sorry, I am being combative again.
Makes you wonder why these audio manufacturers spent time and money in R&D for motional feedback loudspeakers then abandon it all some years later. Obviously they were aware of the benefits.
When you think about it measuring cone movement shouldnt be that difficult at all, inside an iphone is an integrated circuit only few mm in area that has both a 6-axis Gyroscope and Accelerometer.
Joe Rasmussen said:
What I am pointing out is that (and the idea is getting traction) is that the reduction in distortion under current drive is because the amplifier cannot produce reactive current. But under voltage drive, the amplifier readily produces reactive current. So the increased distortion we see (and the measurement can easily be repeated) is due to amplifier reactive current drawn by the back-EMF impedance of the driver. EQ the current and it should suppress the same distortions as current drive. Do you see what I mean.
When you say "back-EMF impedance" do you actually mean 'impedance'?
A speaker designed to give a good response from a voltage source will take whatever current it needs to achieve that. This is not a fault.
I assume the 'distortion' you mention is measured acoustically? An electrical measurement tells us nothing.
I only have a good feeling, but the 1R test is rough and ready, yet it points the way. So time, please, and more than one person will be doing the test, that is the idea, and reach consensus.
The 1R test shows us that the current is distorted. That may tell us nothing about acoustic distortion. It could be that the distorted current is partly cancelling acoustic distortion. So the 1R test does not point the way; it may confuse the way for some people.
The current revealed by the sense resistor is the real input to the speaker that we hear coming out of the speaker, garbage in, garbage out.
Surely the whole point of speaker distortion is that what we hear coming out is not what we put in? We know that the current drawn tells lies about frequency response, so how do we know that it tells the truth about distortion?
Why do you even have to say stuff like that? I just don't get it, maybe you are more concerned with ego than the science?
In fact, there has been some really good comments here, haven't you noticed?
Of course it does, maybe time to brush up on the topic.
I put this to an authority that must be respected (no, I am not going to do name dropping as that would be insensitive) and I stand by that statement and it is solidly based.
The motion of the coil responds only to the current in the coil, that response is an acoustic output. This shouldn't even be argued about. Classic 'garbage in, garbage out' and you can match the distortion of the current with the distortion of the dB-SPL of the driver - it can be measured. If you don't believe, then do the test, I challenge you.
Certainly, and that is why measurements on acoustical side are provided as well with conclusion
Measurement results
No improvement in nonlinear distortion was observed for tweeters and midrange speaker. The only notable improvement was for a woofer, below 100Hz, at a closed box.
Proudove buzeni repro a zkresleni repro
I am always assuming at least some elementary knowledge of circuit theory and acoustics - electric-acoustical transducers, so I assume people are not confused. Contrary to my optimism, even some people involved in audio design seem not to understand very basics.
Distortion seen in current with a voltage drive only reflects speaker nonlinearity converted to the electrical side. On the acoustical side, we can see both mechanical and electrical issues reflected in distortion.
No. The 'current distortion' does not come from the amplifier, it comes from the speaker. Whether this current distortion produces or partly cancels acoustic distortion is something you don't seem to have demonstrated - forgive me if I missed it. You talk as though the current distortion is necessarily a bad thing; you need to show this, not assume it. We know that the linear 'distortion' of the current (i.e. less current drawn near the bass resonance) is a good thing; so good that if you use current drive you need to achieve the same result via pre-compensation.
Maybe this is your fundamental misconception? Restated again as
Cheers, Joe
You are giving the impression to having found a new solution to decades of existing knowledge of which a number of companies already had products since the late 60's. Your solution of equalising the crossover network to appear resistive is not really inventive. The fundamentals of electromagnetism in a loudspeaker transducer is well understood.
I've always assumed that the amount of correction is small before the next problem gets the way* and, as the sub market got more competitive it wasn't worth the hassle. I think Demian knows a lot of what happened behind the scenes.
If you think infinity they had some eyewateringly expensive speakers that used the tech. The sub I have was $1600 in 1988 so $3500 now. The average sub sells for under $500! But a few still fly the flag for servo feedback.
*at the end of the day its the cone position you want to know and that might not be the coil position.
Agreed, you need to treat the entire loudspeaker transducer as a system.
This reminds me of monty python and the holy grail "Oh but if I went 'round sayin' I was Emperor, just because some
moistened bint lobbed a scimitar at me, they'd put me away!"
If said person WAS an authority AND spoke to you as an authority then he would have stuff to back up the statement that he would be happy for you to reference.
