Almost doesn't bear commenting on 😉 Be interesting to see how he rephrases that one 🙄Feedback does not go round and round it reaches a steady state. .
This does not happen, and there are no words to describe it. Feedback does not go round and round it reaches a steady state. You keep stating that no amplifier can drive a load with nonzero phase without being "tricked" into having bad reactive current. This does not belong in a technical discussion.
You might very well run across bad amplifiers that oscillate with your cable/speaker combo, get rid of them.
I am afraid no reasoning with this guy makes any sense. He seems not to understand even elementary circuits, not speaking about feedback. This just illustrates that audio business may be operated by anyone without even basic knowledge.
"an impedance is the degree to which current is impeded, not voltage"
U=I*R
sounds like
A speed is the degree to which time is limited, not distance.
D=T*S
Where did I fail?
U=I*R
sounds like
D=T*S
Where did I fail?
It seems those results reflect more the microphone itself than the speaker. ECM8000 and its likes are as such unsuitable for any distortion measurement, at least at such a close distance (9 cm), because of the known issue of their distortive common-source FET front stage.PMA said:Measurement results
No improvement in nonlinear distortion was observed for tweeters and midrange speaker. The only notable improvement was for a woofer, below 100Hz, at a closed box.
Proudove buzeni repro a zkresleni repro
With a non-distorting microphone, current drive usually shows drastic reduction in odd-order distortion products outside the bass region. Current distortion does translate very well into acoustic distortion, as it forms the dominant source of it (except for the resonance region), and gets yet magnified by the horn effect of the cone. Typical H3 and odd-IMD reductions are around 15 dB with aluminum coil formers and 30 dB with non-conductive formers.
Nonlinear distortion measurements of loudspeakers - voltage and current control
Comparative Measurements on Loudspeaker Distortion: Current vs. Voltage Control | MERILAINEN | Archives of Acoustics
U=I*R
sounds like
D=T*S
Where did I fail?
I don´t know if i understand correctly what you mean, but if you are looking at the definition of the resistance then you´ll see that it is based on current but not on voltage. 🙂
I do not agree, because I check distortion measurements by moving microphone to 50cm, 1m, for the reason you are describing. I am quite sure that the distortion was because of not very good drivers measured. One of them was Beyma T2030, which is behaving very badly. Several months ago I have made a similar set of measurements with better drivers (Seas Excel range), same microphone etc., the distortion is now only low order. I do not suspect the microphone in the measurements shown.
Iirc Mills and Hawksford had published also measured distortion reduction in their publication from the ?1990s? about current drive....
OK, but I hope you would agree that with almost ideal voltage source (negligible distortion, very low output impedance) the current follows voltage divided by impedance and if impedance is nonlinear then current is distorted. I hope you are not going to support foolish and conspiracy engineering pseudo-theories, at least not in the matter that obvious like this.
Maybe you could try to step a bit back from being too dogmatic?
If you find some errors in my posts please refer to them and i will follow on arguments but i surely don´t plan to add a list of safeguards (against imagined supports of something) to each of my posts. 😉
I was wondering why current could not be defined as voltage divided by resistance. I know what you meant by "definition", but I assume it irrelevant to the technical discussion about distortion in current resulting from nonlinear impedance connected to almost ideal voltage source.
I quoted to what i wanted to respond, what else could i do?
TNT expressed mystification about the "impedes current" part and i - while admitting that i might have misinterpreted his post - pointed to the fact that the definition of resistance is based indeed on this "impedes current" property.
Please Jakob, Joe is not talking about current drive (not even a little). He is creating a nonsense about voltage mode power amps and reactive loads.
My point was that these entities are not a duo, but a trio, relation.
But maybe I'm wrong about that?
Please Scott ( 🙂 ) but ETM and PMA did talk about current drive and i remembered a publication from the mentioned authors; in the meantime i even found it in my archive:
Mills and Hawksford. Distortion Reduction in Moving-Coil Loudspeaker Systems Using Current-Drive Technology. JAES, Volume 37, No. 3, March 1989, 129.
Two's company, three's a crowd. That pesky speaker LCR and more besides, darn it!My point was that these entities are not a duo, but a trio, relation.
@Jakob: However the whole arguing with Joe is about distortion in current under voltage drive (which he considers as an amplifier problem), as Scott has correctly stated. So there may be 2 issues confused.
an ideal sine voltage source keeps the sine wave voltage output with zero distortion regardless load impedance and load variances. Load current is then voltage divided by load impedance and if impedance is nonlinear, current must be nonlinear
I find that this can be a good base for agreement.
George
You are 100% correct but Joe is talking about the amplifier not the speaker, his examples are speaker with shunt network to make it a purely resistive load to the amplifier. The voltage amplifier is still directly connected to the speaker. This is not current drive, it is simply modifying the load seen by the amplifier.
The stuff published by his "mentor" is packed with things that are simply wrong. IME getting anyone to let go of this type of baggage after a certain length of time is frankly a waste of time.
George
And then time and mass get in there and make mess of it all....
Dang that real world!
(Edit: PMA is not agreeing with me, I snuck this one in)
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part III
