Not that Stanley:YouTube
But, well, Stanley Clarke was quite a good bass player.
He deserves the indulgence of the jury if he bears the proof that it is he who plays on his records. ;-)
Clark Stanley - Wikipedia
So, like all of us, you just try to sell snake oil. It is well known.
I don't think that is fair to either side.
Indeed, Stanley Clark was found to sell mineral oil , not the real snake oil...basically snake oil is full of omega 3/6...so it should be at least an anti inflammatory medicine.If a small percentage of the poison is spread in its body, then the snake oil might indeed have some other properties as snake poison is used to made very effective medicines.
Not that Stanley:
My jokes always fall flat. It's Belgian humor.
(I love your "real snake oil" ;-)
It was second degree. I am tired of these eternal lawsuits of intention.I don't think that is fair to either side.
You're right, it's unfair, but "life is unfair".
Do-you mean that, because you are in the chemistry business, you are allowed to sell snake oil ? ;-)I should sell it for real as i hold a diploma in physics and chemistry...most of my ex-mates from highschool are medical doctors...
<snip>
Between you and me, why do-you loose your time in even answering ?
Never give up on a struggling soul....
Could be you are creating some of the struggle (against certain pre-existing beliefs, and maybe personality type).
Why not "The hifi company" ?I should be...Not yet , but that might change .
I'd like to make an audio company named "The snake oil company". This way i'd be true to my clients .
(As Hifi is, anyway a make believe game, OMHO, while we all try (tried) our best, hoping that our clients will be "hifi").
Might be...it's not taken yet, but it's much easier to make high end products than hi-fi products.
For some weird reason all the respectable guys here launched their best products the same year i was born...JC, RF, JH...I already feel special.I wonder who launched me ))This is over-long, but might be interesting for the perspective on old media tech:
YouTube
Just promised a good friend to look at his broken Spectral amp and found this looking sideways.
All good fortune,
Chris
Don't you need a Recap ?For some weird reason all the respectable guys here launched their best products the same year i was born.
You call it nonsense. As you described it, your own judgement, it's your own opinion, a biased one.I can only judge on his writings and as he wrote:
"Since sheer quessing will yield the correct answer 50% of the time, a minimum of 12 trials is needed for statistical validity (16 is better,20 better yet)."
(Peter Aczel; The Ten Biggest Lies in Audio; The Audio Critic, Issue No. 26, 6)
which is nonsense. What you´ve quoted, is just opinon based on lack of information. Of course it is possible that he knew better but nevertheless wrote this nonsense.
Not everyone in audio business does what you do.Wasn´t Peter Aczel also in the audio business?
Just show the proof that level matched DBT of DACs or other audio electronic components in chain prior to speakers wasn't audibly distinguishable when the stress of DBT plagued the listener but when the stress is gone, it became distinguishable.No, the evidence shows that the different test protocols have an impact on the response of the participants. Conjecture (partly) is the thinking about the internal mental processes that are the reason for these different response patterns.
See for example these numbers for an experiment from one of the mentioned often cited publications (attached gif). It shows the number of correct responses (expressed as percentage correct) for the various test protocols.
The same sensory difference (onedimensional) was presented to the same group of participants under three different test protocols as mentioned in the table. Samples presented in random order, retasting allowed, rinsing with water included. Graphic produced from: Yu-Ting Huang,Harry Lawless; Sensitivity of the ABX Discrimination Test; Journal of Sensory Studies 13 (1998) 229-239.
Once again, you are just repeating your tried & failed shill tactic.Nice advice in hindsight but unfortunately nobody told the listeners back then that they should train under the specific test conditions, that they need accommodation time and that positive controls are mandatory (negative controls as well).
Which publications i´ve cited in other threads on this topic do you have read? Don´t be shy, explain in detail where the authors failed to do propper work and were publishing just opinion and "conjecture"
Oh, Vicki Melchior! Thanks for putting it up!Attached is an AES paper collecting many of the latest info on high resolution audio.
I recall reading that when it was published. It was the first I'd heard of "The Audio Critic" (I've not read many audio/hifi magazines other than The Audio Amateur). I found the dozen or so issues he had put online, read them, and it makes me want to read the others. From what I read he really was (other than the speaker as mentioned) a no-BS person, and one of the rare few in the audio publishing field.Yes, he lost credibility, and rightly so, when he favorably reviewed a speaker that he designed.
On Peter Aczel's Retirement - Audiophile Review
I found this portion of one comment interesting:
As is often the case with extreme conflicting points of true the truth is usually somewhere in the middle. Most people who've conscientiously worked with audio know that (contrary to what Aczel) there are many audible differences between amps and preamps even though they don't readily show up in instantaneous switchover tests but are instead revealed over long term listening.
One could easily enough (okay, it would take some time and expense setting it up, but hardly more than a "real time" ABX test) set up two amplifiers with switching equipment (carefully level-matched, etc.) that selected one or the other, and only switched once every (for example - the time period could be something else) 7 to 14 days, and only when there's no signal passing through (perhaps it switches at 3 to 4AM, when no one is in the room so no one hears any relays or such). The date and time is recorded in internal memory, and can be recalled later, but the listener has no idea when the switchover(s) happen during the listening test. Could someone such as the commenter quoted above, after weeks or months of listening, hear the difference and recognize the switchover date(s)? And would this be something that could NOT be reliably heard in a "real time" ABX test?
From my reading of the recording professionals on rec.audio.pro 20 years ago (I learned to trust what they said they could hear, (sometimes I could verify it myself through audio files they posted), those who wrote about audible differences between various amps and preamps COULD tell the difference instantly, or at most in a few seconds. I don't recall anyone discussing differences only heard over the long term.
Jacob, I really admire your inexhaustible energy.I can only judge ...
The ADA4898-2 can get burning hot when one of it's inputs
is open. That would belong into the data sheet. At least it won't die on the spot.
mea maxima culpa. Gerhard
How on earth are going to clean that up?
...all over the Internet, entirely dedicated to put down any attempt to rely on ABX for identification or preference tests, disregarding how carefully and throughout they are designed (e.g. there is always the “missing positive control” BS used when everything else fails).
To my long years experience on multiple audio related forums, it is useless to argue about (which, ahem, I’m just doing ); you’ll always get back at best a theoretical word salad, lacking any practical suggestions to improve tests (if possible), if not nitpicking, obfuscating, etc... All while having little to no doubts and an unusual tolerance to casual (read: peeking) listening tests results. And always missing the “extraordinary claims require extraordinary proof” principle which is at the foundation of each and every experimental science.
To quote Jakob(X), “it is kind of sad”.
Vienna puts me in combative mood, I guess
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part III
