John Curl's Blowtorch preamplifier part III
The issue started with Scott Wurcer denying that there were problems with dirty contacts not passing signal until a voltage threshold was reached and then they would work.
Just saying never observed it, never had a young guy get confused by lab measurements and ask what's up with this, never worked on a physics project for space or terrestrial work where it was common practice to undo and clean contacts on any kind of schedule, never heard any anecdotes from guys like the ones at LIGO about interconnect problems messing up a science run.
It does happen rarely i.e. the super-luminal neutrinos (cost people jobs).
And once again, any sudden discontinuity in conductivity is rectifying, your own reference cites it.
So please there must be more important things to discuss. BTW we use Teledyne miniature RF relays in the most critical spots, very expensive.
Joe Rasmussen said:
And somebody (me) should tell "DF" that complex numbers are not needed to explain something that can already be explained by Ohm's Law.
I will take that as an admission that you don't understand complex numbers and therefore cannot understand impedance. In turn this means that all your ramblings are based on elementary fallacies. However, I applaud your persistence. I expect somewhere Solomon said something about people who regard their own ignorance of accepted facts as being a more advanced form of wisdom.
Now please explain:
F = BLi
So what is F in this instance?
F is force, not speaker output.
Why don't you try cleaning the contacts in your sound system, see if it makes a difference.
It is not a sudden discontinuity, it is a sudden continuity.
You can't prove anything. It's up to the "creators" to provide evidence that they might be right.
Yes, I guess you are right. After reading reams and reams of stuff, and no longer knowing who is right, or what is right, or even what is even being talked about, my instinct tells me not to no longer believe anything. Self preservation of my precious sanity, I suppose.
Now you are starting to wise up. You were rude previously to people you were convinced were totally wrong. You tried to get them to shut up and go away. There are people talking past each other here, some people are much more educated than others, some with much more skilled hearing than others, and some who make mistakes and get fooled at times when listening despite being mostly skilled. Then there are some who are sometimes excessively intolerant of those who are unlike themselves. Welcome to your new perspective here on the thread, you will probably figure it out for yourself after expending some time and effort, and after doing some introspective thinking too.
All the foregoing IMHO only, of course.
When we went from tube PAmps to SS, we noticed, by listening, that the bass was deeper, tighter, more accurate. Same effect occured when we used very thin speaker wires compared to thick (large AWG). Larger affected the bass ... deeper,louder etal.
So what do EE do? They measure the damn wire by itself and proclaim nothing there... small Rs. Cannot have any affect on the sound. If I stick a series Resistor in the speaker line(s) and the bass or other freq response areas sound affected..... what do the EE do? They take the resistor and measure it and claim it cannot do anything like what we heard.
Then some bright guy thinks maybe it is an intereraction with amp and speaker and Rs.... like maybe Damping Factor and output Z.
Time and time again and again this is played out every time someone does something and people hear a change. Never look at the whole... only the part.
Instead of being so narrow in view, how about figuring out why/how something simple could make a difference.
THx-RNMarsh
Really.
-Richard
Oh please. Such drama. KMA.
Go ahead Joe R..... tell more.
THx-RNMarsh
What helps your claim is quoting those who did what you say they did.
