The Dayton Wright LF resonance is around 40 hz when loaded with SF 6, and rises if the gas leaked from tears in the Mylar covers. The maximum bias voltage level reduces in air, also the bass cancellation frequency would increase so you knew if you had a leak .......
One or two users over the years tied to refill the speakers with methane after sealing a mylar leak - 😱
No. With the corrected square wave coming from the transformer they had
a nice top end. Interestingly, the higher mass of the Sulfur Hexaflouride bath
exaggerated the curve of the diaphragms when it met the outside air, so the
high frequency dispersion was quite good, much better than you see elsewhere
for large ESL's.
Sulfur Hex is apparently listed as a carcinogen. I remember Dan D' Agostino
(then the rep for DW) inhaling it so as to talk with the big deep voice...
Of course, not nearly as bad as the Ozone from the Ion Cloud Loudspeakers.
How's the move going NP ....?
OK, question to those who have more experience in the field..
Is it possible in 'real life' to drive either Q3 or Q4 into saturation in the schematic shown? Conditions: +/-15V supply, closed loop gain of the 'opamp'=3 or so.
Thanks,
Thanks,
Depending on current level check for quasi-sat on the datasheet, otherwise there would not be much of a problem. Quasi-sat is when there are two breakpoints in the output resistance characteristics.
