Some of these types of rounding errors had nasty consequences:
Computer Arithmetic Tragedies page of Kees Vuik
ZAP
And, the processors do this in-flight ! The supercomputers at LLNL often run over night at their max speed doing calculations for hours on codes. The end results may be just a few digits change or a few added decimal places. But it must give the same number every time the calc are done. In the case, i decribed, the slower machine was more consistant but the researchers could not get the extra places they needed.
THx-RNMarsh
HTML:
        {               _  _            }
        {        |_||\ |_)|_)\/         }
        {      _   _ ___    _           }
        {     |_)||_) | |_|| \|\ \/     }
        {     |_)|| \ | | ||_/|-\/      }
   {                 _                       }
   {               |/ \|_||\ |               }
   {             (_|\_/| || \|               }
  (jgs)((@))((@))((@))((@))((@))((@))((@))((@))
I would like to report that analog design is still alive and well, even though some of its most famous designers have passed away. The 'Analog Aficionados' event was brim full of both younger and older analog designers, some even older than me! And the conversation was brisk with notepads open and people sharing circuits there.
From the DIY people sometimes here, both Ron Quan and Kirkwood Rough were there big time, sharing their thoughts and opinions along with everyone else.
Kirkwood showed me a very interesting circuit that he had some problems with. I told him that he was 'nuts' to even attempt that design. '-) Ron reminded me that there really was a difference between PIM and FM distortion measurement, although I suspect that they both come from the same distortion mechanism.
There were lots of interesting people there, some really, really sharp.
The event was sponsored by Linear Systems, the fet source for DIY. Their work is progressing and their yields are increasing, leaving the future of complementary differential jfet input stages both possible and even 'improvable' with newer devices in future. Personally, I would rather go to this event than any other in the Bay Area. Of course, that's me, not most audio amateurs.
So J-fets still on the table for the foreseeable future .. ... 🙂
Hey jan..
Still workin the article.
Had to go through most of the IR hexfet line to characterize the thermal resistance of their products. I'm finding some really interesting things.
jn
Hey Inductive man, whats causing the rise, too much mass or too low a BL..
I will rely on my personal experience, thank you, on this.
Right now I just started playing a pristine direct disc vinyl recording 'The Missing Linc' from Sheffield records in the 70's. Wow! And better to come when I improve my system even more.
Of course I am using my own electronics thru-out.
The $30,000 speaker set-up doesn't hurt at all, but we have known for more than 40 years that you cannot equate static speaker distortion specs with distortion from electronics. This is what I do for a living---try to make sense of it all. This cannot be matched or better by any digital source that I can muster.
This one's been quoted a few times.
It appears your definition of quality is a personal experience. No room for advancements here. Everybody's definition of quality becomes their own experience. Yuck.
Sure, you can make a tape free, digital free one take recording direct to cutter. Modulation distortions of tape and digital are gone, leaving distortions of cutter system, and those of pickup system.
In vast majority of phonograph recording pickup systems, freely pivoting tonearm with mass orders of magnitude greater than stylus and cantilever system of cartridge, also with relatively high mass is used. Stylus provides both desired signal of recording, and groove pitch signal from cutting lathe. Cantilever suspension must deal with both. Modulation distortion is rampant.
Once in a while, somebody posts a recording made from phonograph. Here are two examples:
And:
For comparison, a CD track with characteristics similar to numerous CD recordings I've looked at:
Low frequency resonance of phonograph players is gross.
Speaker drivers do similar transformations, but require sparser spectrum such as two tone, with at least one of the tones close to driver resonance to see what is happening, and correlate it with what is heard.
In case of phonograph players, once the correlation is made by a listener of IM effects, the turntable mostly stops spinning. Others revel in the IM effect, and its exacerbation of similar effects in speaker drivers.
Once again, with a DUT when all other variables are held constant, they may individually all be of dubious characteristics, yet reveal audible difference in test devices.
Your are electronics artist, well versed in your medium, but ignore the elephants in the room.
Fantastic electronics exist. Some are yours.
Single greatest impact on sound quality is audio transducers. 40+ years of experiences of mostly just plugging them into speaker sytems, with variation on a theme of crossovers, and mostly ignoring what they do with drive signals, instead forming lots of jargon that passes as description of quality.
Toole's and a few other studies only find general preference for speakers with flattest response, and broadest coverage angle. From here it tends back to head scratching and tongue wagging as to which of the flattest responding speakers sounds more realistic.
