Cables making poor contact and falling out of their sockets will not be a positive thing, sound-wise.
depends on what's playing...
SY I don't mean to be personal, but when have you ever worked for a company over 5 years in duration?
Most of my career. Why?
SY
Is the PC board connected to the back or bottom of the connector?
I don't know. Perhaps John does.
SY
If you actually look at the connector does it have a single fork contact or a tubular one? Also handy is either the main hole diameter or the mounting holes.
One version has the holes 2cm apart the other .75" x .947".
I use lots of these connectors and if you let me know I can get you the right parts.
My guess is that they are the forked type with the contacts mounted horizontally, implying a rear PC Card. The failure mode is there are audiophile XLR style connectors with oversize pins. Once they spread the fork contact the connector is ruined for all but oversize pins.
SY
Bottom.
se
What defines "back" or "bottom" of the connector ?
The back and bottom of the connector of course.
se
I never knew this. The plot thickens.The failure mode is there are audiophile XLR style connectors with oversize pins. Once they spread the fork contact the connector is ruined for all but oversize pins.
Or to put it another way...
Let's say you're sitting in a chair facing me. I'm looking at you as if I were looking into the connector. Your back is the connector's back and your bottom is the connector's bottom.
se
SY, if your boss is happy with the sound of this amp, why not fix the problem, or changing the XLRs, or adding a drop of solder on the cable's connector pins to tighten the contacts ?
This said, it is funny to see how reality grimaces after all this noise about silver contacts handcrafted by virgins. Here, we are in the real world with a real boring simple and stupid problem.
Warranty voided, time wasted (there would have to be machining done and PCB modified to correct a simple design error). John has already been clear about what should be done and what he thinks of his customers. I will honor his request and not recommend Parasound in the future.
So if I stand on my head my bottom is tops ? ....Or to put it another way...
se
I think Cole Porter wrote a song about that.
se
The XLR does not use the catch to prevent this - used on Pro gear's XLR.... not so much on consumer gear. Cables hanging down will tend to pull out under the cable own weight. Their might be an exact replacement XLR version with the catch/latch option. Or reposition the gear so the cable isnt pulling down and out. -RNM
- Member Areas
- The Lounge
