It doesn’t get any simpler than that you can find in his speeches (for every topic ) and in his student lectures (for physics)
Are we so used to the ‘Cargo Cult’ ?
It seems so. Someone tried to make it clear to us.
http://www.amazon.com/Science-Analog-Circuit-Design-Engineers/dp/0750670622
George
There's a substantial and amusing error on the Amazon page under Editorial Reviews, About the Author: three people completely unrelated to the book. Fortunately, they get to the correct Jim Williams a bit later on the page.
I first studied Quantum Mechanics from Feyman's book (Vol.3) in my senior year, 50 years ago and I have remained an ardent follower of his since then. I have almost all his books in my library. I don't find them an easy read, especially for beginners.
This 'cargo cult' thing is something that my critics like to put on me, but I don't go along with it. IF you can make an electronic design that will be virtually perfect (within reason) both by measurement and by listening by critical listeners in open listening, then my hats off to you. If you can't, and can only make products that sound the same in double blind tests, then you have a lot to learn about audio design.
Postscript, what am I missing here? Read it yourself right of off Rossi's own data sheet, ECAT 1MW Technical Data.
Capacity of "1MW generator" heating of 1500kg/hr. (max) of water approximately 100C. That's 6.6 gallons per min. (2.5 water saver showers worth), mixed down that's maybe 10 or so hot showers a couple of point of use hot water heaters worth.
By coincidence the calculated power to heat the water is 175kW, the rated input power. :rofl:
You know who you are you can't be that stupid.
I have never designed an awful audio product, BUT I have designed amps (for example) that measured great, yet were sincerely disappointing to independent listeners. In two cases with power amps, I had to completely go through the amp and change it significantly. Once, I removed an IC. Another time, I changed the bypass caps, feedback resistor and a number of other things, and made a very successful power amp from it. We even bought amps from Parasound and modified them, for ourselves and other enthusiasts. The standard measurements would not show any significant difference. That is the dilemma.
I noticed a substantial mistake in one recent item. But I'm not 100%, only 99%. Interesting factor is that it's only a problem when mixed with certain other equipment.
But really, Parasound doesn't come to you askijg to design the $100 product.
Sometimes I am asked to do $100 products, but I usually decline. If I were a chef, I would not necessarily be able to make a $0.50 hamburger either, to my satisfaction. Same thing. I will let you guys do the $100 stuff. '-) The Chinese make the best 'bang per buck'. I just got a 15W/ch triode amp from China. Great product (for what I am using it for).
Another good read is "The Hunt for Vulcan..." by Levinson. More approachable than Feynman, but motivated me go back and re-read "Six Not-So-Easy Pieces"
I did study QM in my senior year, but I did not really understand it well. I WAS more comfortable with classical physics.
You, SY, however, are known to be an expert in QM, so I will defer to you, except where Jack Bybee comes in, because he was a consultant for Richard Feynman when Jack worked at Hughes and he was loaned to Richard Feynman to get him up-to-date on superconductivity, back in the 60's (I'm pretty sure, as I don't know the exact date they worked together). If you had had a little more faith in me back when we first got together perhaps 10 years ago, I could have introduced you to Jack, and you could have personally evaluated his background first hand, including his interesting stories of working with Feynman at Cal Tech, etc.
By definition, amps that are truly high fidelity should sound the same as they neither add or detract from the signal being amplified, so what you are saying is high end audio is voiced... to sound different.....
Not really. What John has always said is that well-engineered amps can sound different as long as you can see the nameplates. When you can't peek, your ability to tell them apart ears-only vanishes. It's remarkable, especially given the sensitivity of skilled listeners to detect really minute differences in important variables (e.g., frequency response, data compression, interchannel level differences...) ears-only.
If one accepts that amplifiers can be subjectively different, then by extension one can deduce that perhaps one amplifier is 'correct', and all others are not.
Voicing is making the errors subjectively acceptable.
Subjective opinions do converge.
The skill is in building gear that is aurally highly accepted.
High aural acceptability is not by fluke.
Dan.
Problem is that if 2 amplifiers measure below know levels of audibility on all measured parameters I don't accept that they can be subjectively different.
Plenty of highly rated high end products are measurably different to the point where you could easily conceive someone preferring Fubar Frequency Response (FFR) or nice added harmonics (NAH). But away from the part of high end that eschews high fidelity they should be the same.
