John/ Charles/Nelson
Is there any point in terminating the speaker end of a speaker cable with something like .01uf 10 ohms RC network to terminate the load end at RF frequencies?
Yes. See my article on speaker cables from 1980. Lot of nice high frequency
square waves and stuff.
FIRST WATT
Hi John, ok interesting statement.It can tame a difficult to drive cable.
What do you mean by this....RLC or something more involved like dielectric/conductor/pair behaviors perhaps ?.
Dan.
Spectrum.....Dynamic Spectral Behavior....Dynamic Spectral Noise Behavior.How is dielectric performance any different from LRC for a speaker cable?
Dan.
Nothing as complicated as that. Some amps don't like seeing certain loads at RF frequencies; a design error in my view. However, given one of these amps you can sometimes rescue the situation by ensuring that the speaker cable looks vaguely resistive for RF. A simple way to do this is to add a CR at the speaker end, so the cable sees something like a resistance at RF frequencies. Ideally the R should roughly match the cable RF characteristic impedance - often around 50-100ohms for normal speaker cable but lower for some abnormal speaker cables.
Yes.Nothing as complicated as that. Some amps don't like seeing certain loads at RF frequencies; a design error in my view. However, given one of these amps you can sometimes rescue the situation by ensuring that the speaker cable looks vaguely resistive for RF. A simple way to do this is to add a CR at the speaker end, so the cable sees something like a resistance at RF frequencies. Ideally the R should roughly match the cable RF characteristic impedance - often around 50-100ohms for normal speaker cable but lower for some abnormal speaker cables.
Particular/SOT values of CR should be at both ends of the cable ?.
Amplifier build out L is another part of the equation.
Dan.
CR at speaker end will do. An 80ohm cable with 80ohms across the far end will look like 80ohms at the near end too.Max Headroom said:Particular/SOT values of CR should be at both ends of the cable ?.
Alternatively, use a proper Zobel network at the amplifier end so it doesn't see the cable at RF frequencies.
R.Cordell has a short secton in his book. I can't recall if it came up in the interviews series.Nothing as complicated as that. Some amps don't like seeing certain loads at RF frequencies; a design error in my view. However, given one of these amps you can sometimes rescue the situation by ensuring that the speaker cable looks vaguely resistive for RF. A simple way to do this is to add a CR at the speaker end, so the cable sees something like a resistance at RF frequencies. Ideally the R should roughly match the cable RF characteristic impedance - often around 50-100ohms for normal speaker cable but lower for some abnormal speaker cables.
I think the RC at the speaker end and across the amplifier's speaker terminals will also work for interference impinging on the speaker cable.
I have only added the amp terminals RC (the Pi version of the Thiele Network).
Maybe I should try the speaker end as well.
IME putting "ideal" (large value ex military styro) CR netwoks across each of two drivers paid huge dividend in terms of perceived distortion, depth information and power handling....'downside' was source polarity dependence...ie programme AP is revealed.R.Cordell has a short secton in his book. I can't recall if it came up in the interviews series.
Dan.
We miss Jneutron and we suffer from short memory.
It’s good that DF96 is around.
George
If your amp is well-designed then there is no need. You already have a pi network at the amp end so that will partially isolate the cable for RF.AndrewT said:Maybe I should try the speaker end as well.
Wouldn't it be simpler to use a less difficult (which usually means less expensive) cable? It seems to me that the only "difficult" load an amplifier should see ought to be a loudspeaker. If a cable makes the load more difficult it should be discarded.
Except that at rf the primary determinant of interaction with the amplifier is simply the speaker cable's exact length, modified by other TL parameters and the load. So in the case of an rf unstable amplifier, it's a crapshoot as to whether any specific cable might or might not interact with any specific unstable amplifier. I'm with DF96, it's an amplifier design issue and that is where the solution should lie, so that it's unconditionally stable.If a cable makes the load more difficult it should be discarded.
Some expensive cables may be difficult to drive. An example might be one which foolishly tries to provide 8ohms characteristic impedance (not realistically possible at audio frequencies!). This would provide a low and capacitive reactance at RF, so could upset an amplifier more than a normal cable with a higher impedance.
So if an amp misbehaves with an ordinary cable it is the amp's fault. If it misbehaves with an exotic cable then it is the cable's fault.
Interesting that the speaker cables are not viewed as an antenna connected to the amp's output. It would be interesting (well at least to me) to know how many of these wire gurus have solid backrounds in rf or transmission line theory .If your amp is well-designed then there is no need. You already have a pi network at the amp end so that will partially isolate the cable for RF.
In my exoerience, owners of reel to reel, and even the better cassette decks, were by and large not convinced by most cable vendors. Just as owners of setups which needed to run uncommonly long speaker cables (due to room architectural reasons) mostly stayed with normal cable, perhaps of a larger gauge (as in my case, 2*5.5 mm2, 2*256 Litz wires, but I am forced to use 2*6m or 2*19 ft cable runs, and I love them there amps being able to hop along).
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part II
