Please consider the measured level. It is expressed in dBm, 0V dBm would be 224mV here. Top of the plot is -30dBm, and there are 10dBm per division.
So then in your last plot the marker is at -81.xx dBm that would then be -81.xx dBm re: 0dBm @ 224mV?
-80dBm would then be 22.4uV, correct? For 6dB higher as in the previous plot (-74dBm) that would be double, 44.8uV, correct?
jd
