Hello I found JLH 2003 ver. pcb on ebay. 4 output transistor
probably more than power JLH 69.
have any information about JLH2003 or schematic ?
Thank you all.
Pure Class A OCL Sepp Amplifier Bare PCB JLH 2003 | eBay
Thank you all.
Ask the Retailer for some Customer Support.Hello I found JLH 2003 ver. pcb on ebay. 4 output transistor
Thank you all.
Got the idea to use a tube instead of BJT at the input. In order to make it work all semis has to be PNP.
The first amp i diyed was the 2N3055-version and I loved it!
Did you build the hybrid?
Im doing something similar to jlh but with 12au7 and resistor loading. no ccs
Could anyone please let me know how does jlh perform with smps power supply?
I have already purchased jlh assembled kit from Jim's Audio. As per jim, the kit requires +33v. Now I am thinking about connexelectronic 300 smps with 30v output rail.
http://connexelectronic.com/product...ucts_id/128?osCsid=o5bk9v9mv2uhvhm9h3c99buea5
Will that be fine or should I go for linear psu with 22v transformer?
Sent from my Nexus 5 using Tapatalk
Connexelectronic
I would recommend SMPS from Sami (www.diysmps.com)
at info@diysmps.com
His SMPSes are really good for audio. I'm using his products in my amps.
Ipsu you mean trafo, rectifier, caps? Not more?
Yes. I was trying to mean trafo, rectifier and crc filter. Nothing more. Not a cap multiplier.
Thanks again. Will go for single 300 w smps only. I will invest more on my upcoming OB project instead.
Open baffle speakersWhat an OB,-?
Thanks. You just boosted my confidence.Not easy, but possible. I love the clean, clear "bass". Much much better than every "closed" rumbling, roaring wooden box,-)
Necessary to use a very good amp! Like a JLH,-!
I'm planning to drive a pair of full range speakers with jlh. I'm thinking about a pair of subwoofer drivers to be driven by class d amps. All in active xo configuration.
C-:
My mind: I would avoid a separate sub with separate amps. Except you want listen very very loud.
I would use bigger fullrange, 12" as example, and modify and damp these.
If separate subs, place behind or, if there no place, very close the monitors, to cover, or to get no direction of, the rumbling and resonating sound of the sub-casings. To get not separate sound.
My mind.-)
My mind.-)
- JLH 10 Watt class A amplifier
