JL Audio 1000/1v2
Solder a bridge between pins 6 and 7 on U517. That should give you an approximate 50% duty cycle drive on all gate pads for the output transistors.
Here is what I get on the following
Q500,501,506,507
The last pic is what I get on Q502,503,504,505
The high-side is floating. There should be no voltage on the source leg of the high-side FETs. Confirm and then (if there is o voltage) ground the scope probe to the FET source leg and re-check. This is best done in differential mode but using the ground clip will work if there is no voltage.
