I read somewhere that you can?!
Ha ha, I haven't a clue, hopefully someone will tell us......
Hello Pano,
It seems you and me have both been in Paris at the time ( early eighties) when there were lots of Hiraga amps around. Back then the French diy community did do lots of test, trying to improve it.
I can imagine they did! Would love to see those threads
Actually now there are still people using this amp in France. At Melaudia forum you can read what they did try about improving the power supply.
]MELAUDIA :: forums - Résultats de la recherche
YEEESSSS!! Thank goodness for google translate looking forward to going through this for inspiration
SMPS too but most of them agree that with amp you need a classic power supply with big caps.
At that time i did ask the staff in the shop in Paris that sold this amp if it would be a good idea to use CLC power supply instead of CRC because they just did make a choke for their Nemesis amp. They said SURE so i did.
Right now Lundahl is making some high current chokes that would be even better.
I will check this out
I did mention them before here on several threads.
Send me the the link to the thread please:
R-core, double C-core or even EI core usually sound nicer than the ones everybody is using. But Pano we dont have to listen to these amps so why worry?
Greetings, Eduard
My choice will be EI maybe double c-core, its true do not have to listen to the amps 😀 . But you gave me some good information which will benefit
Hello,
When i bought mine in Paris the double C core were out of stock. Normally they had one for the 20 and one for the 30 watt Hiraga.
Finally i decided to use a 500 VA EI core that they were using for another amp after waiting months for the C cores NOT arriving.
Why not use a so called Rcore . The internet is full of them. Try to have one made with a static screen.
In the past i did get mine at Selectronic in france but i think they are out of business.
You can find my post about the lundahl chokes for sure.
Greetings, Eduard
P.s the Lundahl chokers can be found at Jacmusic or Thomas Mayer both in Germany
It's very difficult to find a RCORE transformer here in the uk, especially one where i need a minimum of 400va. Some goes for a Double C core. It seems that i have to get these specially made! Its very easy to find toridol and EI transformers.
I looked into Lundahl chokes, again difficult to get the power ratings i need, seem these would be ok for something like the Higara 8W.
Looking into different companies offering handmade transformers built to specification.
Hello,
Greetings, Eduard
Transformer, Capacitors!
Transformer_James transformer-custom toroidal transformer|R core transformer|O core transformer|C core transformer|EI transformer
Looks promising a company who will make all types of transformer!
Going to get a quote for R-Core and Double C (ED Type) as i do have budget.
Now i have a question about capacitors which is confusing me at the moment.
I want to provide each amplifier board with around 0.5F of capacitance.
I see many Electrolytic capacitors for sale for example:
B41456B7220M | EPCOS Aluminium Electrolytic Capacitor 0.22F 40 V dc 76.9mm Screw Terminal B41456 Series Lifetime 12000h | EPCOS
SPECS:
http://www.mouser.com/ds/2/400/TDK_01302017_B41456_B41458-1089857.pdf
for example this is 40V @ 0.22F and costs £134 for two giving me 0.44F
Or i can buy these:
33000uF 35V ALC10C KEMET HQ Class A Audio Mosfet Capacitor 18pcs | eBay
SPECS:
http://www.mouser.com/ds/2/212/KEM_A4020_ALC10-535355.pdf
Which are smaller being 35v @ 56000uf and i get 18 units for £35!!
Meaning i get 0.5F with 9 of these in parallel.
So my question is which is better? To have bigger capacitors like the EPCOS but less of them or to have multiple units like the KEMELs that make the capacitance i need?
Decisions decisions.
SPECS:
Or i can buy these:
SPECS:
Hi Eduard
https://www.audiohobby.eu/en/lundah...36-lundahl-filament-current-choke-ll2733.html
Are you saying these would be suitable for my Hiraga Build? I haven't found anyone as yet who have used these. So if i could and wanted to use these i would need two?
Hello Pano,
If you use the lundahl LL2733 and put the 2 coils in parallel you will get a 100mH choke with 3,4 current rating ( will saturate at 5,4 A ) and a 0,85 ohm dcr. In the USA they are 100$ a piece and you need two.
I have been using lundahl chokes in many designs. Even with big currents and choke input they will not protest ( buzz)
You could try serial connection but i never use that one for a solid state power amp. Maybe dcr will be to high.
A vietnamese friend will use the LL2733 for choke input in a Nelson Pass design.
Later on the hiraga people did also start using chokes.
The ll2733 is 1,35 kilogramme so not that heavy, not that big. And if you think 200$ is to expensive you better not build a Hiraga amp. Remember these chokes have infinite lifetime.
And most of the words dedicated to the Hiraga amp in the past were about the power supply.
greetings, Eduard
With the low input impedance of a SS power amp circuit I suppose you could get away with low value chokes. It's not like a tube amp. I haven't done the math.
As for caps, the original used screw terminal caps for a reason. That reason being the copper bars used to connect them together. The copper bars offer a very low DCR, which helps a number of things, not the least the poor PSRR of the amp.
You really seem to have gone Off on a tangent.
Following the Audio Weenie belief that Boutique (pricier at least) parts make for a better sounding unit.
Good luck with that 😉
Circuit design is The determiner.
In that vein; why this older circuit rather than the more recent and proven excellent Pass designs ? Mere curiosity is all.
A simple and V well made Torriody Tx is More transformer than you will need Or hear.. 300VA is what Firstwatts come with 400va is what DIY'rs use .
Twin Tx is simply affectation imo.
More Uf can't hurt. Help though remains as an Open question.
But hey Your $.. your adventure.
G'luck.
G'luck.
Best Way i find for myself to learn, like thinking out fo the box
Actually read a number of threads on different websites including french,
russian etc I do believe a really good transformer can make all the difference, just getting ideas on whats best approach
Well when i started this hobby it was either a PASS or HIRAGA, i chose the latter because of curiosity and to get me learning. Plus its not a PASS design which is so popular. That will be next on my list
More is better! I am a diy man so there you go
G'luck.
Thank you!
Hello,
Sure this ll2733 is the one to use.
The people who did put the hiraga on the market started using chokes later on. They did agree that a choke would probably be a big improvement.
I have all the French publications on the hiraga and did use some ideas published in later designs.they wrote a lot about power supplies.
I would choose an r core. There are differences between caps. That is sure.
You will find publications about too on the Internet. The French magazine like audiophile can be found online.
Greetings, eduard
Greetings, eduard
woohoo.. looks like Hiraga 30W builders are having a party here..
what i really like is each one of us have followed different approach towards building this monster!
mine is a monoblock build..
Hello,
20 watt did use 6*68000µF caps
30 watt ( called Le Classe A) did use 2*68000 and 4*330000µF. That was the one i build with a 500VA EI core. Dcr of the chokes i used was about 1 ohm. No soft start used but the light would dim at switch on !! With a 500 VA toriodal you will need a soft start. 500 VA R core usually can do without a soft start.
Double c cores have tendency to buzz. The once sold in Paris were vacuum impregnated. The r cores from Selectronic ( now closed) always did give good results. The lundahl chokes can be mounted very close to the R core no problem.
Greetings, Eduard
The two people selling Lundahl in Germany offer good prices and they might have them in stock.
Greetings, Eduard
Sorry Bare, PSU is NOT off topic for this amp. What is an power amp anyway, but a fancy regulated power supply?
Yes, you can overbuild anything, but this power supply isn't overbuilt just for the sake of feeling good or bragging about it. The audio circuit itself is simple and does not have a high PSRR. That's a trade off for its stability and transparency. You will hear changes in the power supply on this amp. My first build used a big toroid transformer because it was cheap. Yes, it was good, but not as good as an EI or R core unit. The differences where subtle, but important.
I used my build mostly for powering doubled stacked Quad 57 ESL panels until a factory built unit replaced it. The double 57s are not an easy load to drive, but the Hiraga never complained. Other amps, both tube and solid state, would go into oscillation or have other problems. The Hiraga, never. I didn't think it would be enough amp for the double stacked panels, but it was always up to the task. Some of that is PSU, some of it other things.
Careful work on the power supply of this amp really pays off. If your room and speakers are up to the task, you will be well rewarded.
Hello,
Pano is absoletely right. The biggest return on investment for this amp would be the power supply.
The 330000µF were very expensive back in those days. I dont know if modern caps could be better. They were 25 volts and used close to that limit!!!. I would go for 35/40 volts models.
In my dddac i am using mundorf. The French used several brands in their Hiraga usually Sic safco or Cef. They prefered the ones with low esr and big current possibilties.
Greetings, Eduard
P.s in other publications they did talk about differences between crc and clc power supplies. The choke will offer way better filtering. More µF is used not for better filtering but for current capability. When they talk ( last few years) they say nothing compares to lots of µF . Regulation can work but it doesnt give a sound that shows power!!
Greetings, Eduard
Electrolityc Capacitor 560000uF (0,56 Farad) 35V 85°C (Screw) KENDEIL | eBay
Guys what do you think? This is really good value.
0.56F 35v only £63!
Think i will buy 4 of them.
0.56F 35v only £63!
Looking at Kendeil PDF(SCREW TERMINALS) i can't find this product😕Electrolityc Capacitor 560000uF (0,56 Farad) 35V 85°C (Screw) KENDEIL | eBay
0.56F 35v only £63!
Same here, not on the website and not the same product markings. You think they are fakes?
Well here in the USA Digikey has some nice 68000uF screw terminal caps made by TDK. They are low inductance and fairly low ESR.
https://en.tdk.eu/inf/20/30/db/aec/B41456_B41458.pdf
About $30 each for the 40V version.
They also carry the 220000uF for $81 each. Still very low ESR about 5mOhm. You'd need only 1 per side after filtering.
Don't know for sure but i'm afraid.
Why marketing is different ,no 560000uf in the pdf,no 02xxxxx code,no 35v version😕
- Jean Hiraga Super Class A 30w Build
