Jean Hiraga MC circuit
I am planning on building the so called Symmetric Hiraga MC amplifier. PCB is almost ready, but I would like to have opinions on grounding scheme. As you can see, at the moment GND is separated on the PCB between the PSU and the MC amp.
Could the grounds be connected at J2?
Should I split ground in the MC section and connect "ouput ground" to PSU ground?
Thanks!
🙂 morten
check out this thread:
I don't like this topology without DC protection and prefer a topology with electrolytic capacitors between moving coil cartridge coil and MC amp input as used in Mark Levinson's JC-1DC. Schematics are to find in PDF attachments from post #8 under
Reactions: m0rten
