J-Box III Speaker Measurement System Review
It's noise level is acceptable, similar to what you would expect from a budget USB audio interface. You may find measurements in my review of the noise floor (white trace)
...and I produced clean impedance measurement with the device:
I just ran some basic measurements, the intent of the review was mostly to show that the device is well functioning, not a scam or junk hardware, so there is less risk for anyone interested in purchasing and using it. Certainly a country mile better than some junk Behringer UCA202/222 that some have attempted to use for measurement purpose. Mentioned in my review, "I tested a high end speaker at 315mm, using the 4.9V output. Calibrated the mic SPL level, and adjusted the gain of both the M4 and Jbox to have 120dB of headroom. Actual SPL at the mic for this test is in the 96-97dB range."
I've not encountered any issue with linearity on any of the usb interfaces I've used (Scarlett 2i2, Steinberg UR22mkii, Motu M4), condenser mics are quite sensitive, I use a similar gain setting for either line or mic input. Mic input is often a higher impedance input than line level, perhaps is part of the issue you've encountered.
Give me a little time, I can compare noise floor level and gain setting linearity with mic input.
