When we think about watts in a multi way speaker, are there any convenient, fact based rules for how power is distributed in music an therefore drivers?
According to Eminence:
"As a general rule of thumb, we estimate that the high frequency driver will see about 20% of the system power with a 1.5 kHz-2.5 kHz crossover, 15% with a 3.5 kHz-5 kHz crossover, and 10% with a 5 kHz and up crossover (all based on a minimum 12dB/octave slope)."
https://eminence.com/blogs/blog/high-frequency-driver-power-handling
With a 2-way crossover, the 50-50 power split is generally something in between 300-500 Hz in most types of music.
I thought you might find this interesting. It's the spectral content of music visualized. You can see the tonal balance of different types of music.
The graphs below are FFT analysis of different music genres. The files analyzed for the this test are the average of approximately 112 different recordings in each genre. I averaged those recordings and plotted the spectrum.
Note that the graphs do NOT show how loud the tracks were mastered, because all tracks were normalized before averaging them. That allows for the overlay on one of the plots. The plots just show tonal balance. You...
- Pano
- Forum: Everything Else
From the Eminence Loudspeaker Book:
Crossover frequency (Hz) | Percentage power above crossover point |
150 | 80 |
200 | 72 |
300 | 55 |
500 | 40 |
1000 | 25 |
3000 | 20 |
5000 | 10 |
Rule of Thumb. On second read I found the meaning changed quite for the better 😀that old RoT
@Galu
Thanks for that. I'm honestly a little surprised the typical subwoofer crossover area (~80Hz) doesn't reduce power nearly as much as I though. I thought that would be the 40-50% point. That doesn't happen until ~ 300 Hz according to that.
I'm thinking a lot about 2-way vs. 3-way speakers and 2-way vs. 2-way plus subs as I approach my next project. I'm converting a 2-way with 6.5" mid-woofer to a 3-way and based on this chart it seems the reduction in energy in the (currently) midwoofer is substantial.
I guess they were assumimg equal efficiency over all the ways. When a sub is capable of really deeeeeeeep bass then it usually has amn efficiency that is much lower than all the other drivers in the speaker. In this case the "150Hz/80% above" rukle will not be valid anymore.
Charles
Charles
Right, but I wasn't really thinking about efficiency so much as how crossover points affect the power level of a specific driver.I guess they were assumimg equal efficiency over all the ways. When a sub is capable of really deeeeeeeep bass then it usually has amn efficiency that is much lower than all the other drivers in the speaker. In this case the "150Hz/80% above" rukle will not be valid anymore.
We often say that a high pass filter on your satellites will reduce the power the main amps need to produce and therefore what the satellites get but that is apparently is a lot less than I imagined.
I have had four and five way big systems for a couple of decades now and when working out how much power was required for each band I used a 70 volt / 600 Watt into 8 Ohm amp. Via oscilloscope I measured peak voltage and current with a current loop.
The fact the subs took the lions share of the current was no surprise. What I did not expect was the peak voltage requirement was in the mid bass-lower midrange.
Barry.
Barry.
@1audiohack Good insights. I think it's still true in multi-way systems as we tend to prefer 4 Ohm drivers for the mid-bass or in 2-way systems we often find the minimum Z at around 150 Hz or so.
The crossover points will affect the average power level distribution between drivers.Right, but I wasn't really thinking about efficiency so much as how crossover points affect the power level of a specific driver.
Assuming flat response and equal sensitivity and impedance for each driver in a multi-way system, the peak voltage required for each driver will be identical for peaks of the same sound pressure level.We often say that a high pass filter on your satellites will reduce the power the main amps need to produce and therefore what the satellites get but that is apparently is a lot less than I imagined.
I made a spreadsheet a while back that would calculate approximate power to drivers across a 4-way crossover. You should be able to do the same pretty simply, just a matter of plotting a matching curve to that scatter chart (Eminence data) and then doing the formulas from there.
Mine wasn't based on the Eminence data (I think I got the info from a reference on Elliott's pages) but it's likely to be very similar.
Thanks for all the ideas everyone. my needs are a lot less elaborate than many of you imagine. The eminence table will really help me going forward.
- Is there a W rule of thumb?
