Is there a W rule of thumb?
Reactions: eriksquires
@Galu
Thanks for that. I'm honestly a little surprised the typical subwoofer crossover area (~80Hz) doesn't reduce power nearly as much as I though. I thought that would be the 40-50% point. That doesn't happen until ~ 300 Hz according to that.
I'm thinking a lot about 2-way vs. 3-way speakers and 2-way vs. 2-way plus subs as I approach my next project. I'm converting a 2-way with 6.5" mid-woofer to a 3-way and based on this chart it seems the reduction in energy in the (currently) midwoofer is substantial.
I guess they were assumimg equal efficiency over all the ways. When a sub is capable of really deeeeeeeep bass then it usually has amn efficiency that is much lower than all the other drivers in the speaker. In this case the "150Hz/80% above" rukle will not be valid anymore.
Charles
Right, but I wasn't really thinking about efficiency so much as how crossover points affect the power level of a specific driver.
We often say that a high pass filter on your satellites will reduce the power the main amps need to produce and therefore what the satellites get but that is apparently is a lot less than I imagined.
