Is there a W rule of thumb?
Reactions: eriksquires
@Galu
Thanks for that. I'm honestly a little surprised the typical subwoofer crossover area (~80Hz) doesn't reduce power nearly as much as I though. I thought that would be the 40-50% point. That doesn't happen until ~ 300 Hz according to that.
I'm thinking a lot about 2-way vs. 3-way speakers and 2-way vs. 2-way plus subs as I approach my next project. I'm converting a 2-way with 6.5" mid-woofer to a 3-way and based on this chart it seems the reduction in energy in the (currently) midwoofer is substantial.
I guess they were assumimg equal efficiency over all the ways. When a sub is capable of really deeeeeeeep bass then it usually has amn efficiency that is much lower than all the other drivers in the speaker. In this case the "150Hz/80% above" rukle will not be valid anymore.
Charles
Right, but I wasn't really thinking about efficiency so much as how crossover points affect the power level of a specific driver.
We often say that a high pass filter on your satellites will reduce the power the main amps need to produce and therefore what the satellites get but that is apparently is a lot less than I imagined.
I have had four and five way big systems for a couple of decades now and when working out how much power was required for each band I used a 70 volt / 600 Watt into 8 Ohm amp. Via oscilloscope I measured peak voltage and current with a current loop.
The fact the subs took the lions share of the current was no surprise. What I did not expect was the peak voltage requirement was in the mid bass-lower midrange.
Barry.
The crossover points will affect the average power level distribution between drivers.
Assuming flat response and equal sensitivity and impedance for each driver in a multi-way system, the peak voltage required for each driver will be identical for peaks of the same sound pressure level.
I made a spreadsheet a while back that would calculate approximate power to drivers across a 4-way crossover. You should be able to do the same pretty simply, just a matter of plotting a matching curve to that scatter chart (Eminence data) and then doing the formulas from there.
Mine wasn't based on the Eminence data (I think I got the info from a reference on Elliott's pages) but it's likely to be very similar.
Go on the wayback machine for art ludwig's sound page. He did both peak and average power requirements for music samples and found that while average requirements declined with rising frequency, peak requirements didn't decline so much. You could use somewhat less power per octave in higher frequencies, but perhaps not as much as some of the charts specify. You can get by with much less robust power supples in the treble than in the bass, though.
