I guess in my case, still...when wanting best latency I naturally have to pick IIR...so thats settled but When I'm wanting best SQ...will I land at the same destination regardless of latency, looking at those two paths???
linear phase XO(hp/lp) and linear phase correction downstream.....
vs
minimum phase XO(hp/lp) and linear phase correction downstream...
It is more complicated than that and trying to make it simpler will lead to misunderstanding.
FIR filters can be minimum phase and to all practical purposes have no appreciable latency. It then depends on how the convolver works as to whether it will add latency, but that is not then due to the filter but the software processing.
If the FIR filter is linear phase or mixed phase it will have some latency depending on the length of the filter and where it's impulse centre is located.
As krivium said above it is adding a time based correction that causes latency to be added. In order to process something that has already happened you delay the signal to allow it to be processed before being heard so you don't have to bring out the time machine.
Whether you can improve the sound by using an FIR filter is a difficult question. If you know what you are doing and why then I think the answer is yes. But on the flip side you can totally destroy the sound as well.
Using a linear phase crossover filter does have some potential benefit over a minimum phase one especially as it gets steeper. But as always the best result for a particular situation can't be decided based on rules you read on the internet 😉
I did already understand the weightings but I don't think I was understanding the context of your reply. Did you mean that the true SPL could be up to 12dB higher than shown on the meter depending on the weighting used?dB(A) is like a bandpass filter which cuts off the high and low frequencies. dB(C) has only a mild high and low cut. Hence for the same broadband signal dB(A) will read many many dB less than dB(C).
If you use IIR XO and a steep slope (causing high group delay)....and clean it up with FIR downstream isn't it essentially the same thing?
I couldn't figure out how to test the latency of my system but this is pretty ingenius...set my mic right next to my mouse with my first person shooter open....record a click...measure distance in between mouse click and gun shot lolThe test setup is always the following: HeSuVi is set up to use the SONIC- virtualization (like for the others, this results in 14 convolutions) and a graphical EQ on the binauralized stereo result (position and volume adjustments are used as well, but should not have any additional impact). I place my microphone and mouse between my headphone and record the microphone with Audacity. A click gets thus picked up but also triggers an AWP shot in CS:GO (03/2019), which will be output by the headphones. The difference between the two sounds is our audio latency.
Are there any threads dissecting the Dutch 8c? Is it as simple as I think it is and Akabak can get me there with a series of trial and errors to figure out offset of the side vents from front baffle....low tuning for the linear and wide vent performance.....
Jriver does have an ASIO input driver so you can use it to process audio in real time although I suspect you would need to test that properly with the latest version to see if it met your needs.Jriver is for playing back media? You run your XO crossovers through Jriver? Jriver is going to be a system wide crossover for me? I didn't think that thats what it did??
If you are already using DAW software then you should be able to set a convolution plugin either singly or in multichannel to process your mix straight out to your active system.
For playback of regular music files then Jriver is miles ahead, you could use both within the same system, just not at the same time.
I'm glad I am not the only one. I have everything R128 volume levelled so I end up somewhere around the -6dB from reference mark to take account of the dynamically challenged music in my collection 🙂In smaller room i usually find 83dbspl to be too loud for the kind of music i listen to ( they most of the time belong to K14 or K12, in other words typical 'pop' dynamic range).
For classic or jazz i think i could have that 83dbspl ref and like it however but for other reason: this is related to background noise. Typical domestic space have something like 50dbspl background noise so when you introduce 'high' dynamic materials you'll need to up the level a bit.
What i miss the most from professional control room is not the acoustic treatments but soundproofing: very quiet place.
Whith lower DR material i suspect our brain have a defense reaction in smaller room: to high an average level and our brain needs to protect the interface to the world so it tells us to lower volume.
I suspect this is ER related as i don't have this with headphones. But all this are speculations from my side.
My background noise is pretty low in the 30dB range to 40dB range, not the inky blackness of a studio but not bad for home with no real effort being made to get there.
You can use EqualizerAPO under Windows. All sounds from all aps go through EqAPO. Create impule response filters for crossover in Rephase. And load them in EqualizerAPO (FIR, IIR whatever you create in rephase)
I haven't got the latency tested yet but from what I've read I'll get 1ms from it.
So I installed it...so this can basically do for me what Jriver does also? If so, thats pretty cool.
At one point in space, yes, over a wider area is less certain.If you use IIR XO and a steep slope (causing high group delay)....and clean it up with FIR downstream isn't it essentially the same thing?
Is it simple, yes, is it easy to replicate with simulation, no. Modelling the frequency dependent time delay through the intended material is not so easy. I have had the same idea but shelved it.Is it as simple as I think it is and Akabak can get me there with a series of trial and errors to figure out offset of the side vents from front baffle....low tuning for the linear and wide vent performance.....
It is not the same thing but whether that makes any practical difference to how you use it is hard to say. Equalizer APO sends the audio through the windows subsystem, Jriver can use ASIO or WASAPI and bypass that. If you use metaplugin in Jriver then there really isn't anything that you can't do within the limits of the number of audio channels you have available.So I installed it...so this can basically do for me what Jriver does also? If so, thats pretty cool.
Damping material messing it up for everybody...
Thanks guys for dealing with me...
its working using my Focusrite for output but I wouldn't know why I need to bypass the subsystem...sounds like Jriver is a little better option.Equalizer APO sends the audio through the windows subsystem, Jriver can use ASIO or WASAPI and bypass that.
Whats the path to super cardiod for someone like us..or you...or we...or me...??
Do I need to pick up four 10" sealed back woofers, place them on the sides of my boxes and tune them with dsp?
Phase can be flattened with Finite Impulse Response filters, in exchange for latency. The duration of the FIR filter needs to be at least twice the period duration of the lowest frequency it’s describing.I guess in my case, still...when wanting best latency I naturally have to pick IIR...so thats settled but When I'm wanting best SQ...will I land at the same destination regardless of latency, looking at those two paths???
1000ms/20=50ms, 50X2=100ms. That’s 100 ms at 20 Hz.
100ms of latency would make for an obvious echo or lag between a live source and the FIR output, but no problem for playback only.
Merlijn van Veen - The harmonics lead the fundamental
The above link has a video that allows you to audition between IIR with varying degrees of phase shift and FIR with flat phase.
Even using headphones with a flat phase response, I can not hear the difference between them.
That said, I could easily detect the comb filtered, messed up frequency response of the combined sound in the video linked in post #6471 at 5ms, while still not hearing an "echo" with that little delay.
I find the audibility of phase changes to be much more pronounced when it is done based on an in room measurement at low frequencies. If outdoors or anechoic I don't imagine I would be able to pick it at all.The above link has a video that allows you to audition between IIR with varying degrees of phase shift and FIR with flat phase.
Depending on the weighting and time constant (Slow, Fast or Impulse) used, the "true SPL" could be far more than 12dB higher than shown on the meter.I did already understand the weightings but I don't think I was understanding the context of your reply. Did you mean that the true SPL could be up to 12dB higher than shown on the meter depending on the weighting used?
For instance, a 30 Hz continuous sine wave would read 40 dB less than actual on "A" scale.
Dropping a spoon on a tile floor might read only 70dB SPL "Slow", while on "impulse", could read 110dB or more.
Why would you want a supercardioid pattern?Whats the path to super cardiod for someone like us..or you...or we...or me...??
Putting that question aside, rear or side speakers with dsp delay and filtering can change the polar pattern, like Kii uses.
Fulcrum acoustics has a patent on passive cardioid too, there is useful information on their site to look at.
At 2:00 he changes the xo and I can hear the phase shift after this....its subtle.
Its pretty bad test material...the music has all sorts of automated filtering going on lol...and the melodic notes rarely constant or short sustains, with the tempo....a very slow played piano with long notes in sustain would of been choice....00
ON second though maybe I'm just hearing the processing errors of the phase sweep? as it goes from one polar to the other?
I am just repeating things I've read that are likely incorrect...judging by the diagram you just provided (ty ty)... I don't know what type of cardioid pattern I'd be creating by placing one of these Beyma Speakers - Beyma 10MCF400Nd closed back carbon fiber midrange speaker with a neodymium magnet - Beyma 10MCF400Nd 400 watt AES 10" speaker for all midrange applications. Beyma 10MCF400Nd sealed midrange and other Beyma 10" speakers here. on each side of the mid box...or maybe between the the mid and horn even....those are pretty expensive though...I have enough amps...I wonder if it would be effective. What type of pattern do you get when you put the cancelling source on the sides?
I just learned you can use VCad to model it...but with something like the product I listed, used correctly...is that going in the "right" direction?
I like the "cardiod" options. Which is why I showed how to do this in my book both actively and passively, although I didn't discuss the use of side ports with damping. That is a good idea if all the gotca's have been worked out.
The Dutch 8c has left an impression on the Mastering Engineer community apparently....the only thing unique about it to me is the cardioid polar....The polar has been polished of course for sales but...non the less, it is apparent to me, that there is a rise in Sq to be had in every bit of deliberate directivity....so I kinda looked at it like, am I doing everything I can do....no....is active cardioid a possibility yes?....
The product I listed above, the Beyma, what you guys think of that mounted on the sides for the role? Maybe theres some better suited tactics for active cardioid?
You can get passive super cardioid by building the D&D but then opening up the back. Adjust the resistance medium, rockwool in my case. I thought it was going to be difficult but it was easy. The end result is not a product you can sell commercially or that would survive shipping but you can DIY it.
The 8C is a good all in one package for those that need or want to put the speaker near the front wall and don't want the speaker to be too big.The Dutch 8c has left an impression on the Mastering Engineer community apparently....the only thing unique about it to me is the cardioid polar
The midrange is passive cardioid and the polar looks to be quite consistent, but it is pretty wide from 1K down.
The back sub drivers operate below 100Hz and are designed to be used close to the wall behind them to leverage output and avoid the cancellation dip by putting it out of band for that driver.
They are not part of the cardioid arrangement.
You could look at the Genelec W371A Woofer box for some inspiration, wildly expensive but seems like a good idea.
The Ones | Designing the new W371 Adaptive Woofer System. - YouTube
- Is it possible to cover the whole spectrum, high SPL, low distortion with a 2-way?
