The high side out will either work or not and is totally dependant upon the output stage it is connected to.
The best test rig is an amplifier with no load.
I would make up a test rig similar to infineon's data sheet.
generally,because, if the irs21844s fail all the fets blown in the most cases i want to be sure the way to check the drive signals.....i mean the low side looks ok but i wanna be sure both the high side with the oshilloscope....to be ok all the drive signals...sorry for the bad eiglish!!
Without information about the scope settings, those are essentially useless.
Timebase?
Vertical amp setting?
Was the vertical amp set to 'cal'?
Was the probe set to 1x or 10x?
Was the trace set to the reference line prior to measuring?
AC coupling should almost never be used. Use DC coupling.
Do you know how to use your scope in differential mode?
Timebase?
- General Interest
- Car Audio
- irs21844s help..
