Iron Pumpkin(s) and other smaller vegetable animals
to keep you busy : )
case almost done and i want to realize a mini jack input on the front (randomly people come by, saying "i got a version of Gary Peacock NOT messed up by Keith Jarret", but just on the i Pod..
But mini Jacks put gnd r/l together, does this mess up seperate ground scheme, or doesn´t it matter because it´s in front of the buffer?
tnx!
Edit: I have minijack that does not connect signalgnd to chassis
it is messing with overal GND scheme
however , considering that (separate) channel GNDs are meeting together at chassis , each having 10-15R NTC in line , that means they're separated effectively with 20-30R
when you introduce input having common ground for both channels , to avoid shorting your precious separated channel GNDs , series resistor in one lead is a must
Well, if we're going to go all "hillbilly" here, then I'm obliged to point out that this should really be the "Arn Punkin'" thread. 😀
Excellent work, sir. And it's nice to see more stuff from our friends at Modushop.
