I bought at local shop.
There is enough space there even if heat sink is too big.
How about this one?https://www.mouser.jp/ProductDetail/Wakefield-Vette/274-3AB?qs=8GtUBYxqNFCzw%2BhYO2j/LQ==
They said thad maybe some Greedy boys have extra Iron Pumpkin Pre to sell because Papa do not have enough good pumpkins to feed Greedy boys hearts. 🤣
what's D/M?
if Dual Mono - not possible, except using 1pcb/channel (sans one channel buffer and autoformer)
but, I cheated, in case of SE .......... :
Iron Pre for F4 - calc is simple, 12db as max fain for SE and fixed 6db of gain for Bal, so you can fire up your Korg B1 and do your calc
if resulting voltage swing is enough for you, more than OK .......... but Iron Pre will not make even a drop of F4's sweat ......... because they're simply not made for that
insert another autoformer in between Iron Pre and F4, or add another gain stage, in separte box
with or without autoformer in Iron Pre, your taste should decide
- shunt reg is damn good life source for loads, minimizing crosstalk
- there are rails cap multipliers for each buffer, more than potent to actual job
Yes. That was my 'guess' but as I embarras myself all the time I refrained from mentioning.if Dual Mono - not possible, except using 1pcb/channel (sans one channel buffer and autoformer)
Agreed, you mentioned that and I ordered autoformer will install and will run other pre's built BA-3 high gain piggy back.insert another autoformer in between Iron Pre and F4, or add another gain stage, in separte box
Even Balanced Iron Pre? Into bridged F4 and or MoFo? At 100W?but Iron Pre will not make even a drop of F4's sweat ......... because they're simply not made for that
What pre will make MoFo and F4 sweat? I'm finishing up multiple pre's to stack, waiting for parts...
Danke H.
Danke H.
let teach you how to calc
take that nowadays sources are 2Vrms
then - Iron Pre SE is having gain of either +6db or +12db;
+6db=2V/V=2*
+12db=4V/V=4*
so, you have either 4Vrms or 8Vrms at output
Power is easily calculated :
P=Urms^2/Rload
so, 4Vrms gives 2W@8R, 8Vrms gives 8W@8R
math is same, be it SE or Bal - voltage is voltage and speaker doesn't care in which fashion you are conditioning signal
so, for Iron Pre Bal
find your souurce Vout, multiple by +6db, calc power from that voltage swing
say blindly that your bal source is shootin' 4Vrms out
4Vrms times +6db=8Vrms
gives 8W@8R
of course that you can easily calc what's happening if you insert autoformer (for SE) or xformer (for Bal) in between pre and amp
just multiply what's going from preamp with xformer gain and calc power from that swing
Vunce
Tried doubling R3/4 and was near. Will be trying stacking BA-3 and FE 22.FE 2022
That was a while ago. Parts still coming in. Have to finish high gain BA-3 to see how that does. All I can do is build, try, and if it fails there are 3 Subs breaking in that will give the desired SPL.Whoopsie,
Thanks H.
Any thoughts on implementation of a single passive input alongside the Iron Pre? Right now just planning to splice one pair of RCA inputs with the board outputs and connect both to the AVC input (sharing a single output). I have one setup where I prefer to use a passive AVC preamp, but I only need a single input (phono) for that. With other gear (F6, Aleph J), the multiple Twister inputs with various gain options will be useful. Not sure if anyone has any more clever ideas on having it both ways..
ZM
Thank you for reteaching how to calc power output. Been many, many years since I learned how to do that calc. Use it or lose it.
I built SE and Bal. Both singing beautifully.
IAIMH,
I realize that kits are sold out; but is there a chance I can buy just the PCB's? I need two SE boards.
Thanks.
nash
Thanks.
nash
- Iron Pre Essentials Kits For The DIYA Store - Register Your Interest
