Installing IEC socket in AMP.
If the person were floating in the air, like a bird on a power line, nothing would happen, no shock.
If the bird had one leg on phase 1 hot and the other leg on phase 2 hot, the bird would burn.
That's an important fact about GFI: if you connect yourself like a Load, power is delivered.
No ground involved.
Yes that would also be the case without the RCD. Touching both L and N is not a clever action, same counts for touching line voltages.
The RCD is also not meant to protect against stupidity 😉
Thankfully most birds are too small to touch two powerlines. I think Pterosaurs would have a hard time surviving this modern world.
