Infineon MA12070 Class D
I have 2 of these boards...symmetrical entries.
The quality of the components and assembly is exceptional!
Huge sound across the entire spectrum and surprising clarity (all the details are there), better than any TPA and ice power I've tried.....
This is huge for a 7mm x7 chip. Neutral amp, quality DAC and high resolution files required!👍
@mamocel
How is the KSD 2200A amp, in comparison to these mono amps?
I understand that you do have the KSD 2200A. Just curious how well it can match up with these very nice looking mono amp boards with apparently better quality parts.
Also changed to MA5332MS. A bit more sturdy compared to MA12070 I hope. IC is less developed and slightly more noisy so the wait is for new multilevel class D chips. There are some new versions but these have no analog inputs. Possibly Infineon and their main customers see digital inputs as the way to go. Truely skips DACs, opamps, coupling caps, DC servos and transformers too 🙂
Only had one MA12070 breaking down but the chips seem to die in a few devices.
The 2 x 63W MA2306xxx (datasheet February 2024) are already discontinued just like MA2304xxx, MA12070x and MA12040x. In short all multilevel class D chips by Infineon are discontinued. Mmmm...real pity! Maybe they abandoned low power multilevel class D chip technology in favor of the higher power MA5332MS etc. as discontinuing new ICs after only a few months is odd.
Instant TDA1541A status for MA12070 🙂
Reactions: douede
Possibly because they subjectively don't sound a good as the multilevel* class D chips and one also does not need the ridiculous output power. Another reason could be that these are not integrated solutions but have a need for many external parts. Large board area, hard to obtain MOSFETs, complexity, choices to make, higher costs....
*Do you want a sophisticated low noise fine sounding maximum of 2 Watts (that is very loud) flowing through the speakers or a device with higher noise, higher costs and able to deliver 200W that you'll never use?
Reactions: douede
My note is pure technical one.
It seems like the Merus chips are quite forgiving. They don’t need an advanced external input stage. The output filter can be medium quality. The routing and PCB dont need to be state of the art. (Stray capacitance). And the cooling is also modest. Still it measures and sound great.
Make me think of the 5532 opamp. There are better opamps but most often thay are much more prone to design degradation if not done 100% righth
Yeah and devices with it are very cheap. So cheap that DIYing make little sense. The BRZHifi costs only 26 Euro.
The output filter and routing/PCB should be high quality for it to perform best. At least that is where the differences are found in ready made devices and where the average DIYer can improve matters. For a few Euro extra one can have excellent performance (for the money). Pity that it needs an army of ceramic caps. For the inputs just 4 film caps make it sound nicer.
Past tense really from now on.
I wouldn't know. I only know GaN from USB-C phone chargers that last a maximum of 2 months. Since it became the buzz word in chargers they started to have a very limited lifetime so the emotion is to keep clear from anything GaN 🙂 The impression is that not all developments are invented for a long useful lifetime.
It helps to keep the non PD USB-A charger on the side as a spare.
