Improvement the speaker with flat sandwich cone
Cool beans.
Reminds me of a Balanced-Mode Radiator (BMR).
Example:
Tectonic TEBM65C20F-8 3-1/2" BMR Full-Range Speaker 8 Ohm
Product Details
Tectonic TEBM65C20F-8 Balanced-Mode Radiator (BMR) features extended frequency response and wide dispersion compared to that of a conventional drive unit. It combines the benefits of Tectonic Elements bending-wave technology and pistonic modes of operation. It is ideally suited for compact audio applications that require a full-range, high performance acoustic solution such as a soundbar. An advanced ferrite-based motor is combined with special cone dampers to ensure a small size that outperforms conventional drivers, especially in off-axis performance.
What is BMR? | Cambridge Audio
Another benefit of BMR technology includes near-180 degree sound dispersion.
And these, Distributed Mode Loudspeaker Transducer.
Dayton Audio DML25-4 2" Distributed Mode Loudspeaker Transducer 20W 4 Ohm
..........Designed to behave like a conventional pistonic driver at lower frequencies and a DML (distributed mode loudspeaker) and higher frequencies............
...................Great off-axis directivity enables flexible placement options
This loudspeaker by Technics might be in the same technological family.
What do you think?
Speaker System SB-C700 | Premium Class C700 Series | Technics US
The flat coaxial two-way speaker drive unit is an original Technics development, designed for the faithful reproduction of mid-range and high-frequency sound. The flat woofer diaphragm has a sandwich-structure using lightweight, high-rigidity carbon fibre skins and a honeycomb core, and is designed for a highly accurate pistonic motion over a frequency range extending beyond the crossover frequency with the tweeter, thus ensuring smooth integration.
The flat design eliminates the frequency anomalies due to the cavity effect caused by conventional cone diaphragms, while the magnetic circuit employs a large magnet, copper cap and shorting ring, and a short voice coil with concentrated edgewise winding for high power with low distortion. The drive unit chassis is in highly rigid die-cast aluminium, with the chassis ‘legs’ having a resonance dispersing structure to eliminate even the smallest unwanted vibration, to help the drive unit deliver accurate and powerful bass.......
Hello Boden,
I don't make spiders myself, I take them ready.
The photo shows the upgrade process.
Taken from different columns. Relevant parts.
Photo of the next work.
The photo of the assembled moving parts shows traces of gluing the cap to the frame of the sound coil.
At the end of the assembly, the cone became solid in the radial direction.
It turns out that the extension of the voice coil is advantageous for ordinary speakers. Not just for flat "honeycombs".
We are under occupation. The city is blocked, no one from the family has a job. Products are running out, no supplies. The money will also run out soon.
There is no gas, as well as heating, and on the street at night minus 6, in the daytime zero.
It's good that the Internet is still working.
So the task is simply not to die of hunger and cold.
It's just genocide.
Reactions: havun
Reactions: esl 63
Дуже мило. Мені також подобається такий тип гри в динаміках.
Чи можу я запитати: чи є у вас спеціальний трюк, щоб розібрати магніт і полюсні наконечники? Виглядає як цільні литі рамки для глосників..
Domestic ferrite magnetic systems of loudspeakers are disassembled easily, purely mechanically. The glue is weak there. All others must be heated to 80-100 degrees Celsius.
Then a strong blade at an angle to the place of gluing. And a hammer blow. in most cases, the magnet is disassembled without damage.
