I'm going to build a Pass XOno.
Thanks for everything, Wayne,🙂
But my I ask you to be more precise, what can I do for bettering this equipment?
Not that it would not be good enough for now.😀
So I know, not the type GR or BL matter really, but actual Idss of devices. (GR=2,6..6,5mA, BL=6,0..12mA V=10,0..20,0mA)
What do you advice to me (us)?
Forgive me, I can not english and electronics as well.
I read it now:
Nelson has commented that the sonics are better at higher currents, the V might be best here.
George
The upper base resistor on the cascode was last a 7.3 K Ohm to give a bit higher voltage for the 2SK170 inputs. No more than 15 volts for noise to be best. I never really like Q15 the inverting buffer in the front end but besides keeping the phase correct it may actually contribute to the sound in a positive way. You could try to just bypass it if you don't care about phase or swap cartridge leads.
