regarding - slot shape, maybe you can look at Fulmer's patent - hope link works
N.C Fulmer Loud-:Speaker system
http://www.google.com/patents?vid=USPAT2787332&id=yh9qAAAAEBAJ&dq=2787332
I have generated a more complete iBIBk document
http://p10hifi.net/tlinespeakers/FH/download/iBIBk-FE12x-map-060307.pdf
dave
dave
Re: Newbie question wrt K-slot and suprabaffle
We really are in new territory here... a triangle may work.
dave
FlorianO said:How important is the K-slot exponetially increasing width shape ? Can a triangle do ? If so, any guidelines wrt the shape ?
dave
Dave,
Thanks for your reply.
At the moment I will try to dig up my old math skills and -- while respecting the width and length of the slot in your drawing -- draw the parabolic curvature such that I get the right area.
Am I on the right track ? What is tried and what not ?
Still learning...
TIA,
Florian
Still learning...
TIA,
Florian
FlorianO said:At the moment I will try to dig up my old math skills and -- while respecting the width and length of the slot in your drawing -- draw the parabolic curvature such that I get the right area.
What i drew was just a freehand approximation. The height can probably change (i think i had a reason for the height i chose but can't think what. The Area is important becasue it adds to the height of the box off the floor to give Sm.
At this point yes. JohninCR is our sole example so far.
dave
I did a series of tapers...
a few years back and the triangle did not work. I found that the top part of the taper and the bottom were the most influential parts. I ended up with a curve that looked a lor like a tractrix expansion which I had terminate at the top edge of the driver on the canted baffle. I that case i was loading a Fostex FE166/7 driver and wanted full range output from the driver wizzer not firing into the tapers.
I have a bunch of pictures of Dutch designs but either they are too large to post or in the wrong format to post and I am getting frustrated trying to post them now. Sorry.
johninCR said:Here's my iBIBk's using 127's. I've been too busy with a bunch of construction projects to tune them, experiment with supra-baffles, or apply finish. They're definitely the deep bass champs of the small driver lineup, and Dave's idea for the extension to make the 3 point stance is a great use for driver cutouts which add nice visual appeal, especially for those of us lucky enough to have some real wood cutouts. They make even an unfinished cab appealing, even though my pic may not show it.
My limited understanding of the K is that only the higher frequencies fit through the smaller portion (readily audible with your ear near a K-slot), and this results in a terminus that is variable in size based on frequency (someone please correct me if I'm out in left field).
Hi John,
Very nice job. I'm eager to read a follow-up after you've fine tuned it, and what supra baffle you'd use. I think the truncated pyramid would be nice. But maybe with just 2 layers (~1.5" thickness) so it wouldn't be too top heavy.
regards,
fred
planet10 said:I have generated a more complete iBIBk document
http://homepage.mac.com/tlinespeakers/FH/download/iBIBk-FE12x-map-060307.pdf
dave
Hi Dave,
Thanks for the detailed plans.
How do they sound?
Isn't the Voight Pipe a 1/4 wave and the BIB a 1/2 wave enclosure? Is there an advantage of one over the other? I would like to use a enclosure like this for the 4.5" hemp acoustics that will be available one day or for a pair of FE127Es. Just looking for an opinion. I am limited in available space in my listening room but I would like to try a BIB with a small driver like the 127E. I will post a diagram of my other idea. Maybe one of them has merit.
Here is another idea. It is not to scale and obviously my skills in Paint could use some help. The front and rear baffle would be extended to mount to a base plate with cutouts on the side for venting. Maybe it should just vent torwards the nearest corner? I know that this is similar to the version using the Karlson slot but I get the impression that the slot tuning fro a Karlson is more luck than solid formula.
G said:Here is another idea. It is not to scale and obviously my skills in Paint could use some help. The front and rear baffle would be extended to mount to a base plate with cutouts on the side for venting. Maybe it should just vent torwards the nearest corner? I know that this is similar to the version using the Karlson slot but I get the impression that the slot tuning fro a Karlson is more luck than solid formula.
Hi Gavin
Looks like a vofo to me, that is if you really mean the driver to be in that position. Check out my website if you want some dims.
Hi Scott
In the supra design the driver rear fires off into the void which to my mind creates too many I/f waves to be predictable. just a thought!.
Ed
Someone commented a while back that they thought the terminus on the design was a little small. My experience with the original BIB design is that they are prodigious bass producers and the terminus has to be heavily restricted to keep things in proportion.
Restricting the terminus also helps smooth things out.
Shoog
Shoog
vitalstates said:Hi Scott
In the supra design the driver rear fires off into the void which to my mind creates too many I/f waves to be predictable. just a thought!.Ed
Hi Ed
It was the vent layout I was primarily referring to. No argument from me though -the driver positioned like that is a bad idea IMO. Yet another reason why so many of the old folded TQWTs were rubbish. Too much HF leakage down the rear of the line, right where you don't want it. Not good. Worse, those Supravox cabinets (which I suspect were based on the old Weems calculations, which were never much cop) don't have anything like enough volume for the driver.
- Full Range
- iBIBk developement thread.
