1. Iancanada -- EssController …
2. Crom 1 x FifoPi, 3xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT (and if you have any left: The RPi I2S adapter that enables the ESS controller to be used as an external controller)
3. Oyvind 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
4. Pistollero 1 x FifoPi, 2xLifePO4 power
5. MikeyFresh 2x FifoPi, 1x LiFePO4 power, 2x ESS Controller, 1x dual mono ES9038 DAC, 1x ES9028 DAC, 1x Transformer I/V PCB mini kit, 1x Std I/V stage
6. Randytsuch 1 x FifoPi, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1x transformer pwb, 1 x xo adapter, 1x opa adapter, 1x standoff kit, 2 x I/V STD standard I/V stage pwb, 4 x lt3042 pwb
7. necplusultra 1 x FifoPi, 1xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
8. szczemirek 1 x FifoPi, LifeO4 pure power supply, Transformer I/V PCB mini KIT, I/V STD standard I/V stage, CCHD957 XO adapter kit
9. casshan 1 x FifoPi, 1 x LifiPO4 power, 1 x Ess Controller
10. zapio : 2 x FifoPi , 4 x LifiPO4 power, 1 x Ess Controller, 1 x transformer I/V PCB mini KIT 1 x I/V STD standard I/V stage, 1 x Dual Mono ES9038Q2M DAC HAT
11. trung224 : 1xLiFePO4 power
12. Sq225917 : 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
13. passive420: 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
14. comickitkit: 19 xFiFopi, 5xLifepo Power Supply, 11xESS Controller, 7xDual Mono ES9038 Dac, 3xES9028 Dac, 5xI/V STD OPA Stage, 1x Trans I/V PCB mini KIT, 5xESS Controller KIT, 15xPackage of CCHD957 PCB KIT, 11x2’’ double-ended U.FL cable, 1x2.5mm metal standoffs, 8xLT3042 PCB, 15xI/V stage empty PCB, 1xMcfifo, 1xMcdualXO
15. crymen: 1 x Fifopi, 1 x LifePO4 power
16. ppap64: 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
17. Greg Stewart: 3 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 DAC hat, 1 x 9028 DAC hat, 1 x ESS controller extension kit, 3 pks CCHD957 XO Adapters, 8 x 2" u.fl silver-plated extension cables, 5 x RPi metal standoff sets, 5 x LT3042 regulator boards
18. jacklee: 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
19. kenlaumm: 1 x Fifopi, 1 x LifePO4 power
20.curryking: 1 x FIFOPi,1 x ES9038 dual mono DAC Hat, 2 x ESS Controller
21. Cerole: 1 x FifoPi, 3 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1*I2S FIFO 2 Kit, 1*Dual XO clock board, 1*SPDIF interface, 1*I2S to PCM, 1*FIFO II isolator PCB
22. Big bird: 1 x Fifopi, 1 x LifePO4 power, 1 x ES9038 dual mono DAC Hat,1 x I/V STD standard I/V stage, 1xLL1544A Transformer I/V KIT, $19.00, 1 x ESS Controller, CCHD957 XO adapter kit, ESS controller extension kit, 2” double-ended silver plated U.FL coaxial cable, 4x 6"double-ended silver plated U.FL coaxial cable
23. wealas: 2 x LiFePO4 power
24. ernesternest: 1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
25. nounouchet: 3 x LiFePO4 power
26. mjensen: 1 x FifoPi, 2 x LifePO4 power, 2 x ESS Controller, 1 x Dual Mono 9038 Dac Hat, 1 x I/V STD standard I/V stage, 1 x Transformer I/V PCB
27. janho12345: 1x FifoPi
28. Forane12: 2X FifoPi , 3X LifiPO4 pure power supply, 2X ESS controller, 2X Dual Mono ES9038Q2M , 2X ES9028Q2M DAC HAT, 2X I/V STD standard I/V stage, 2X Transformer I/V PCB
29. Joseacm08: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M , 1X ES9028Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
30. ccliu: 1X FifoPi , 2X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M , 1X ES9028Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
31. e-yakovkev: 1 x FifoPi, 3 x LifePO4 power
32. minivan: 1xfifopi ,1x Lifepo4 pure power
33. StarLex: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
34. Akasaka: 1x FifoPi, 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT
35. Yatsushiro: 1X ESS controller
36. luchoh:1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage,
37. nielsek:1xFifoPi, 1x LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage
38. emynet 1x FifoPi, 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT
39. cspirou: 1*I2S FIFO 2 Kit, 1*Dual XO clock board(no XO), 1*SPDIF interface, 1*I2S to PCM, 1*FIFO II isolator PCB, 1*RPi I2S PCB adapter, 6*LT3042/LT3045 PCB, 1*I/V STD stage, 1*transformer I/V PCB kit, 1*LifiPO4, 1*McDualXO, 6* U.FL coax (any length), 1*SMT XO adapter package, 1*I2S backdoor kit
40. Brumjam: 1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT
41. misterdog:1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
42. palmito: 1*FifoPi, 1*LifiPO4 power, 1*ESS controller, 1*Dual Mono ES9038Q2M, 1*I/V stage, 1*Transformer I/V PCB mini KIT
43. flowerpot: Withdrawn (After some consideration decide to withdraw from this GB)
44. _oxygen: 2x FifoPi, 2x ESS controller, 1x Dual Mono ES9038Q2M DAC HAT, 1x ES9028Q2M DAC HAT, 2x I/V STD standard I/V stage, 1x Transformer I/V PCB mini KIT, 2x ESS controller extension kit, 2x CCHD957 XO Adapter kit, 2x OPA1622 Adapter kit, 2x 2" U.FL coaxial cable, 6x 2,5mm standoffs, 1x Buffalo I/V board adapter kit
45. SonofThor: 1x FifoPi, 1x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1x STD standard I/V stage, 1x Transformer I/V PCB mini kit
46. Morde: 1x FifoPi, 2x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1x STD standard I/V stage, 1x Transformer I/V PCB mini kit
47. 1001meier: 1xFifoPi, 1x LifePo4 power
48. deenoo: 1*FifoPi, 1*I/V STD standard I/V stage, 1*Package of dedicated CCHD957 XO adapter kit, 2*LT3042 low noise regulator PCB (free); 1*LifePo4 pure power supply
49. Rrbs : 1*FifoPi, 1* LifePo4 power, 1*ESS controller, 1*I/V STD standard I/V stage, 1*Transformer I/V PCB mini KIT
50. linh0983 : 1xLiFePO4 power , 1xDual Mono ES9038Q2M , 1x FifoPi
51. JoeyDD: 1*LifePO4 power, 1*ESS controller
52. pierantonio: 1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
53. xaled: 2x FifoPi, 2x LifePo4 power, 2x ESS controller, 2x Dual Mono ES9038Q2M, 2*Transformer I/V PCB mini KIT
54. Duanbui: 1xLiFePO4 power
55. maartn: 1x FifoPi, 1 x ESSController, 1 x ESS controller extension kit, 4 x double-ended silver plated U.FL 178 coaxial cable, 2 x LT3042 low noise regulator PCB (free)
56. syracuze: 1 X FifoPi , 3 X LifePO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
57. Flyingsparks: 2X FifoPi , 2X LifiPO4 power , 2X ESS controller, 1X Dual Mono ES9038Q2M , 1X ES9028Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
58. number9, 1x FifoPi, 1x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage
59. duc985: 1x FifoPi, 1x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage,1X Transformer I/V PCB
60. Lucser: 1xIsolatorPi II, 2 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage, 1xI/V trasformer board, 2x CCHD957 XO adapter kit, 4*LT3042 PCB, U.FL Ccables; and, if completed, 2 x I2S to LVDS HDMI Tx modules as per #2602 post.
61. Stokessd: 1x FIFO, 1x ESS Controller, 1x Dual Mono ES9038Q2M DAC HAT, 1x Transformer I/V PCB mini KIT
62. tomcoppa 1*FifoPi, 1*LifiPO4 power, 1*EssController, 1*dual mono 9038 dac hat, 1*I/V STD standard I/V stage, 1*transformer I/V PCB mini KIT
63. Blitz: 3xLifePO4 Power, 1*transformer I/V, 1*I/V Standard
64. Chipno :1 x FifoPi , 1 x LifiPO4 power
65. simon dart: 1x FifoPi, 1x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage,1X Transformer I/V PCB
66. kolossos4730: 1 x FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 1 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage
67. mksung: 1 x FifoPi, 1 x LL1544A Transformer I/V KIT, 2 x Package of OPA1622 adapter PCB kit lot of 5, 1 x IsolatorPi II RsapberryPi/ODROID I2S/DSD/DoP isolator
68. stavros61:1 x FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 1 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage
69. cjunkk: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
70. bartb: 1x McFIFO, 1x McDualXO, 1 x FifoPi
71.JimS::1 x FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 2 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage
72.KenI:1*FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 1*ESS controller, 1*Dual Mono ES9038Q2M DAC HAT, 1*I/V STD standard I/V stage
73.kvl: 1*FifoPi, 1* LifePo4 power, 1*ESS controller, 1*Dual Mono ES9038Q2M ,1*I/V STD standard I/V stage, 1*Transformer I/V PCB mini KIT, 1* ESS controller extension kit, 1* Package of OPA1622 adapter PCB kit lot of 5, 4* LT3042 low noise regulator PCB, 1* I/V STD standard I/V stage empty PCB.
74 secanbj 1*FifoPi, 1*ESS controller, 1xDual Mono ES9038Q2M ,1*I/V STD standard I/V stage
75.deanoUK :1 x FifoPi 768KHz 1 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M
76. cubano: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage
77. Hellokitty123: 1X LifiPO4 pure power supply / 1X I/V STD standard I/V stage 1X / Transformer I/V PCB mini KIT
78. nori1000: 1 x FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 1 x LifiPO4 pure power supply, 1 x ESS controller, 1x ESS controller extension kit, 1 x Dual Mono ES9038Q2M DAC HAT, 1x I/V STD standard OPA I/V stage, 1x I/V STD standard I/V stage empty PCB, free, 4x 4” double-ended silver plated U.FL coaxial cable, 1x 2” double-ended silver plated coaxial cable, 1x Package of dedicated CCHD957 XO adapter kit
79. Rowli: 2 x LifiPO4
80. Sidiropa: 1*LifePo4 power
81. stephengrenfell 1*FifoPi, 1*LifiPO4 power
82. Mindfunk: 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
83. tanelip: 1*FifoPi, 1*CCHD957 XO adapter kit
84. sbiswas-1: 1 x McFIFO, 1x McDualXO,1x LifiPO4 pure power supply
85. Jjazz: 1 X FifoPi , 1 X LifePO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini kit.
86. s666foto: 1 X FifoPi , 1 X LifePO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini kit.
87. niner: 2 x LifiPO4
88. maui: 1 * FifoPi, 1 * LifePO4, 1 * I/V STD standard I/V stage, 1 * I/V STD standard I/V stage emty PCB, 4 * 2" U.Fl wire double ended, 1 * CCDH957 XO adapter kit lot of 2, 1 * ESS Controller, 1 * ESS controller extension kit, 1 * dual mono ES9038Q2 dac, 1 * LT3042 low noise regulator PCB
89. ofswitched: 1X FifoPi, 1x Dual Mono 9038 DAC HAT, 1x I/V STD standard I/V stage, 1x Buffalo I/V Adaptor, 2x CCHD957 XO Adapter kit, 1 X ESS controller extension kit
90. neslo: 1 X FifoPi , 1 X LifePO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini kit.
91 AlanElsdon: cancelled
92 cv: 2 x FifoPI
93. chi0001: 1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x Package of dedicated CCHD957 XO adapter kit , 1 x dual mono 9038 dac hat, 1X I/V STD standard I/V stage, 1 x transformer I/V PCB minit kit, 4 x LT3042 low noise regulator PCB
94. cps3113:1 X LifePO4 pure power supply.
95. ilgavro 1x fifopi 2x lifepo4 power 1xesscontroller 1x dual mono 9038 da hat 1 x std standard I/V stage
96. ykharlamov: 1 x LifePO4 power, 1 x McFIFO, 1 x McDualXO
97. M_Balou: 1*FifoPi
98. yaboin: 1*FifoPi, 1*LifePO4 power, 1*ESS Controller, 1*dual mono 9038 dac hat, 1*I/V STD standard I/V stage, 1*transformer I/V PCB mini kit
99. stenachio: 1*FifoPi, 1*LifePO4 power, 1*ESS Controller, 1*dual mono 9038 dac hat, 1*I/V STD standard I/V stage
100. ilraffa 1x fifopi 1x lifepo4 power 1 x esscontroller 1 x dual mono 9038 da hat 1 x std standard I/V stage
101. ermine22. 2X FifoPi , 1X LifiPO4 power , 2X ESS controller, 2X Dual Mono ES9038Q2M, 2X I/V STD standard I/V stage
102. cesare2K. 1x fifopi 1x lifepo4 power 1 x esscontroller 1 x dual mono 9038 da hat 1 x std standard I/V stage
103. artmic: 1*FifoPi, 1*LifePO4 power, 1*ESS Controller, 1*dual mono 9038 dac hat, 1*transformer I/V PCB mini kit
104. lugo689:1x fifopi 1x lifepo4 power 1 x esscontroller 1 x dual mono 9038 dac hat 1 x std standard I/V stage
105. tods:2x fifopi, 1x lifepo4 power, 1 x esscontroller, 1 x dual mono 9038 dac hat, 1 x std standard I/V stage
106. copper31: 1 x FifoPi, 1 x LifePO4 power
107. plsm: 1*FifoPi, 1*ESS Controller, 1*dual mono 9038 dac hat
108. Gabry63: 1x fifopi 2x lifepo4 power 1xesscontroller 1x dual mono 9038 da hat 1 x std standard I/V stage
109. dynpro100: 1 x I2S to PCM converter board, 1 x Finished TPS7A4700 low noise regulator board, 1 x RaspberryPi I2S adapter PCB/connector package
110. sp502: 1 x McFIFO, 1 x McDualXO, 1 x Finished TPS7A4700, 9x U.FL. coax cable (4",7",12"), 10x U.FL. sockets, 1x SMT XO Adapters KIT, 4x 767KE-ND
111. Pinnocchio: 1x FifoPi, 2x LifePO4 power, 1x ESS Controller, 1x Dual Mono 9038 DAC HAT, 1x I/V STD standard I/V stage, 1x Buffalo I/V Adaptor, 1x ESS controller extension kit, 3 pks CCHD957 XO Adapters, 1x 2” double-ended silver plated U.FL, 1x 4” double-ended silver plated U.FL
112. hiroyuki.t: 1X FifoPi , 1X LifiPO4 power , 2X ESS controller, 1X Dual Mono ES9038Q2M , 1X ES9028Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
113. rudra: 1 x FifoPi, 1xLifePO4 power, 1 x RaspberryPi I2S adapter(transmitter)
114. jp2017: 1 x i2stopcm
115. stones: 2 x FifoPi, 1 x LifePO4 power, 2 x Ess Controller, 1 x ESS controller extension kit, 2 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage, 1 x I/V STD standard I/V stage empty PCB, 1 x transformer I/V PCB mini KIT, 2 x LT3042 low noise regulator PCB, 1 x I2S to PCM, add UFL cables if needed
116. adelias 1 x FifoPi, 1 pkg CCHD957 XO adapter kit, 3 x 2” double-ended silver plated U.FL coaxial cable
117. ngocpham: 1xLifePO4 power
118. marcus1: 1xLifePO4 power
119. vanofmonks 1x FifoPI, 1x Es9028 Hat, 1x I/V, 1x ESS
120. Val33 : 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
121. cristianr: 1xLifePO4 power
122. triodehunter: 1x McFiFo, 1x McDualXO
123. TirNaOg: 2 x LifePO4 power
124. Dave S: Nothing
125 spm FifoPi, LifiPO4, ESS controller, Dual Mono ES9038 HAT, I/V STD and Transformer
126. quick16 2 x FifoPi
127. mige0: none
128. fm804: 1 x FifoPi, 1 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard OPA I/V stage, 1 x Transformer I/V PCB mini KIT, 1 x ESS controller extension kit, 3 x CCHD957 XO adapter kit, 1 x OPA1622 adapter PCB kit, 5 x 2" double-ended silver plated U.FL coaxial cable, 1 x Buffalo I/V Board I/V adapter KIT, 1 x I2S to PCM converter board V2.0, 5 x 4" double-ended silver plated U.FL coaxial cable, 5 x 6" double-ended silver plated U.FL coaxial cable
129.AcDcMan1: 1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
130. APK : 1 x FifoPi , 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x Dual Mono ES9038Q2M DAC HAT
131. miklau: 1*FifoPi, 1*CCHD957 XO adapter kit, 2*LT3042 low noise regulator PCB, 1* I/V STD standard I/V stage empty PCB.
132. Aronier : 2*FifoPi, 2*LifiPO4 power
133.JimmyThinker: 2* FifoPi , 1* ESS controller, 1* ES9028Q2M DAC HAT, 1* I/V STD standard I/V stage, 1* ESS controller extension kit, 2* Package of dedicated CCHD957 XO adapter kit lot of 2, 1* I/V STD standard I/V stage empty PCB, 1* RaspberryPi I2S adapter PCB/connector package, 3* U.FL coax (4”)
134. BachAudioDK: 1 x I2S to PCM, 2 x OPA861 I/V converter
135. Jorgen E : 1 x LifiPO4 pure power supply
136. Patjr : 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
137. markhw4: 1 x McFifo, 1x McDualXO, SMD XO adapter kit, 4* ADM715X ultra-low noise LDO PCB (free)
138 ollux: 1*FifoPi, 1*LifiPO4 power
139 TioFrancotirador 1*FifoPi
140 Tml: 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
141 iggy111: 1x McFiFo, 1x McDualXO, 6x 4” double-ended silver plated U.FL coaxial cable, 10x SMT U.FL socket
142 kirks: 1 x FifoPi , 1 x LifiPO4 power, 1 x ESS Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
143 prohvesor: 1 x LifiPO4 power
144. derekv: 1 x FifoPi, 1x Dual Mono ES9038Q2M DAC HAT, 1 x Transformer I/V PCB mini KIT
145. aguaazul: 1x FifoPi, 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT, 1X ESS controller extension kit, 2X CCHD957 XO adapter kit lot of 2, 1X OPA1622 adapter PCB kit, 4X 2” double-ended silver plated U.FL coaxial cable, 2X LT3042 low noise regulator PCB, 2X I/V STD standard I/V stage empty PCB, 3X RaspberryPi I2S adapter PCB/connector package,
146. Supersurfer: 3*FifoPi, 2*LifiPO4 power, 1*EssController, 1* Dual Mono ES9038Q2M DAC HAT, 6* 4" double-ended silver plated U.FL coaxial cable, 4* 7" double-ended silver plated U.FL 178 coaxial cable, 12* SMT U.FL socket, 2* RaspberryPi I2S adapter PCB/connector package, 4* ADM715X ultra-low noise LDO PCB (free), 1* I/V STD standard I/V stage, 1* CCHD957 XO adapter kit lot of 2, 1* ESS controller extension kit, 1* Package of OPA1622 adapter PCB kit lot of 5, 1* 2” double-ended silver plated U.FL coaxial cable, 3* 2.5mm metal standoffs for RPI lot of 4 sets, 2* LT3042 low noise regulator PCB, 2* I/V STD standard I/V stage empty PCB
147. CAAD: 1* FifoPi, 4* ADM715X ultra-low noise LDO PCB (free)
148. atom6422 : 1 x FifoPi, 2 x LifiPO4 power, 1 x EssController, 1 x ES9028Q2M DAC HAT, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage, 2 x transformer I/V PCB mini KIT, 1 x OPA861 I/V converter, 1 x I2S FIFO II (I2S) KIT, 2 x Dual XO II Clock Board without XO and socket, 1 x FIFO II isolator board mini KIT (finished), 1 x FIFO II isolator board mini KIT (unfinished), 1 x S/PDIF Interface Board for FIFO II, 1 x I2S backdoor KIT for S/PDIF board, 5 x Battery Management board PCB, 2 x Package of Universal SMT XO Adapters KIT lot of 5, 3 x Anti-vibration screw grommet set(767KE-ND), 4 x ADM715X ultra-low noise LDO PCB (free)
149. johnyn: 1xFifoPi, 8 x 4" double-ended silver plated U.FL coaxial cable
150. acg 8 x LifePO4 power
151. RonR: 1*FifoPi, 1*I2S to PCM, 1*ESS controller, 1*CCHD957 XO adapter kit, 4*U.FL coax (4”), 4*U.FL coax(6”)
152. Raj1: 2 x LifePO4 power
153. alazira1: 3 x LifePO4 power
154. malcox11 1*FifoPi, 1*LifiPO4 power
155. Emi90: 1xLifePO4 power
156. 1x FifoPi, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT
157. diyiggy : 1*FifoPi
158. AndyN: 1x FifoPi, 1x ESS Controller, 1x Dual Mono ES9038Q2M DAC HAT, I/V stage board, 1x (or 2 for dual mono?)Transformer I/V PCB mini KIT
159. Dadbeh : 1 x FifoPi, 2 x 1 x EssController, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 3 x Anti-vibration screw grommet set(767KE-ND), 4 x ADM715X ultra-low noise LDO PCB (free) 1 x Package of dedicated CCHD957 XO adapter kit lot of 2, 1XPackage of OPA1622 adapter PCB kit lot of 5, 1X 2” double-ended silver plated U.FL coaxial cable, 1X 2.5mm metal standoffs for RPI lot of 4 sets 1x LT3042 low noise regulator PCB, 1x I/V STD standard I/V stage empty PCB
160. homing1974 1 x FifoPi
161. malarkey : 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
162. Daniel Lin: 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
163 fergas: 1 x FifoPi, 1x Dual Mono ES9038Q2M, 2 x LT3042 PCB, 1 x I/V STD standard I/V stage empty PCB, 1x ESS Controller
164 Murdoc: 1x LiFePO4 power
165. Paul Hirst: 1x FifoPi, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage
166. 808EENGR: 1x FifoPi, 1xLifiPO4 power, 2x Package of dedicated CCHD957 XO adapter kit lot of 2, 4x 4" U.FL cables, 2xADM715X pcbs, 2x LT3042 pcb
167. NicMac: 1 x FifoPi , 1 x Ess Controller
168. Prakit: 1 x FifoPi, 1 x ESS Controller
169. jsyu: 1X FifoPi, 1X LifiPO4 power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT, 1X ESS controller extension kit, 1X CCHD957 XO adapter kit lot of 2, 1X OPA1622 adapter PCB kit lot of 5, 2X LT3042 low noise regulator PCB, 2X I/V STD standard I/V stage empty PCB
170. Heathkit: 1 x LiFePO4 power, 1 x FifoPi, 2 x ADM715X ultra-low noise LDO PCB (free)
171. chih: 1X FifoPi, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT, 1X ESS controller extension kit, 1X CCHD957 XO adapter kit lot of 2, 1X OPA1622 adapter PCB kit lot of 5, 4X LT3042 low noise regulator PCB, 1X I/V STD standard I/V stage empty PCB, 4X ADM715X ultra-low noise LDO PCB
172. adrian311: 1x FifoPi, 1x ESS Controller, 1x ESS Controller extension kit, 1x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage,
173. andrea_mori 4 x FIFO II isolator board
174. wcwc: 1 x FiFoPi
175. redjr 1 x FifoPi, 1x ESS controller, 1x Dual Mono ES9038Q2M DAC HAT, 1x I/V STD standard I/V stage, 1x ESS controller extension kit, 4x LT3042 low noise regulator PCB, 10P 1.0mm FFC/FPC cables combo (3 cables)
176. sampsonite:1 x FifoPi; 1 x LifeO4; 1 x ESS controller; 1 x ESS controller extension kit; 1 x Dual Mono ES9038Q2M 1 x I/V STD standard OPA I/V stage; 1 x CCHD957 XO; Package of OPA1622 adapter PCB kit
177. AudioDac:1 x FifoPi; 1 x ESS controller; 1 x ESS controller extension kit; 1 x Dual Mono ES9038Q2M 1 x I/V STD standard OPA I/V stage; 1 x CCHD957 XO;
178. Lindamar : 1 x FifoPi ; 1 x LifiPO4 ; 1 x ESS controller ; 1 x I/V STD standard I/V stage ; 1 x Transformer I/V PCB mini KIT
179 : myint 67 1x Fifopi ,1x LifiPO4
180 : ICHIBAN Lenmeld : 1 x ESS controller
181. sfleming : 1*FifoPi; 1*LifePO4; 1*ESS controller; 1*I/V STD standard I/V stage, 1* Dual Mono ES9038Q2M DAC HAT
182. stockwolf3 1* FifoPi, 1*LifiPO4 power supply, 1* ESS controller, 1* Dual Mono ES9038Q2M DAC HAT, 1* I/V STD standard I/V stage, 1* Transformer I/V PCB mini KIT, 1* ESS controller extension kit, 1* CCHD957 XO adapter kit lot of 2, 1* OPA1622 adapter PCB kit lot of 5, 2* LT3042 low noise regulator PCB, 2* I/V STD standard I/V stage empty PCB,9. 2* I2S to PCM converter board V2.0, 8* grommet set(767KE-ND), 2* 4"SMT U.FL socket
183. Jogi: 1* FifoPi, 1*LifePO4 power supply, 1* ESS controller, 1* Dual Mono ES9038Q2M DAC HAT, 1* Transformer I/V PCB mini Kit, 1* ESS controller extension kit, 1X 2” double-ended silver plated U.FL coaxial cable,10P 1.0mm FFC/FPC cables combo (3 cables) $3.95.
184.thefirstdj: 1*FifoPi; 1*ESS controller; 1*I/V STD standard I/V stage, 1* Dual Mono ES9038Q2M DAC HAT, 1* CCHD957 XO adapter kit lot of 2, 1* ESS controller extension kit, 4* 2” double-ended silver plated U.FL coaxial cable
185. Studley:1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
92 cv: 2 x FifoPI
127. mige0: none
92 cv: 2 x FifoPI
127. mige0: none
186: jasontsai38: 1 * FifoPi, 1 * LifiPO4 power, 1 * ESS controller, 1 * Dual Mono ES9038Q2M DAC HAT, 1 * I/V STD standard I/V stage, 1 * Transformer I/V PCB mini KIT, 2 * CCHD957 XO Adapter kit
92 cv: 2 x FifoPI
127. mige0: none
92 cv: 2 x FifoPI
127. mige0: none
186. jasontsai38: 1 * FifoPi, 1 * LifiPO4 power, 1 * ESS controller, 1 * Dual Mono ES9038Q2M DAC HAT, 1 * I/V STD standard I/V stage, 1 * Transformer I/V PCB mini KIT, 2 * CCHD957 XO Adapter kit
92 cv: 2 x FifoPI
127. mige0: none
21. Cerole: 1 x FifoPi, 3 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1*I2S FIFO 2 Kit, 1*Dual XO clock board, 1*SPDIF interface, 1*I2S to PCM, 1*FIFO II isolator PCB, 1*ESS controller extension kit, 1*CCHD957 XO adapter kit, 4*6" double-ended silver plated U.FL coaxial cable, 1*Package of OPA1622 adapter PCB kit, 10*2.5mm metal standoffs for RPI, 8*2" u.fl silver-plated extension cables
92 cv: 2 x FifoPI
127. mige0: none
Edited Pos. 21 Cerole
92 cv: 2 x FifoPI
127. mige0: none
92 cv: 2 x FifoPI
127. mige0: none
187. edek44: 1 * FifoPi , 1 * LifiPO4, 1 * ESS controller, 1 * Dual Mono ES9038Q2M, 1 * I/V STD standard I/V stage, 1 pkg CCHD957 XO adapter kit, 3 * 2” double-ended silver plated U.FL coaxial cable, 3 * U.FL coax (4”), 3 * U.FL coax(6”), 4 * Anti-vibration screw grommet set(767KE-ND), 1* OPA1622 adapter PCB kit lot of 5
92 cv: 2 x FifoPI
127. mige0: none
92 cv: 2 x FifoPI
127. mige0: none
153. alazira1: 3 x LifePO4 power, 1 x FifoPi, 1x ESS controller, 1x dual mono ES9038, 1x IV STD, 1x ESS extension, 1x CCHD957 adaptor, 1x 1622 OPA adaptor, 1x LT3042 pcb
modified #153
92 cv: 2 x FifoPI
127. mige0: none
modified #153
92 cv: 2 x FifoPI
127. mige0: none
modified #89
92 cv: 2 x FifoPI
127. mige0: none
modified #89
dear Ian,
may I know payment and shipping detail .
As I am not mistaking, Ian posted a few pages back that he's allmost ready to receive orders.
Keep an eye on his Github and your forum-messagebox. As I understand it, we will be able to place our orders via the orderform as soon as it's updated with the 2019 items. Ian will then send us the info we need to transfer all our money to his bankaccount
Untill then we are all very patiently playing the waiting game, giving Ian all the time in the world to make sure his products keep up to the high standard he stands for.
Ian, given the high price of the Lifipo4 Boards, is it possible to order in two stages, e.g. order one to understand sound improvement and order a few more once the difference has been confirmed in someones's system ? I guess as well that the difference is not in each system the same...
Yes, Yes, Ian is investing a lot of time and money in the 2019 items, he must be more anxious than us to transfer all our money to his bank account.
However, Ian pays more attention to his credibility. He will not mail the 2019 items before he is ready, and will not deceive us to collect money into his bank account first, and then send it out a long time later.
In general, Ian will continue to supply the modules he designed, so you don't have to worry about not buying them later. The modules Ian designed many years ago are still available today. In other words, if you are concerned that Lifipo4 Boards are not suitable for you, you can buy one before you buy another. Furthermore, Lifipo4 Boards are not very easy to DIY, because you have to spot welding the battery, not as easy as soldering. Maybe you will give up buying another Lifipo4 Boards after you actually try to spot welding.
I may be wrong on this but the group buys are only one per year so if you wanted to order another Lifipo4 PS (after this current GB) then you would have to wait until the next GB in a year's time?
I tried to order 2 very simple items: RaspberryPi I2S adapter PCB/connector package. Part of the previous offerings.
My reply from Ian:
Please register your ID to my GB interesting list. You will receive diyAudio message when they are available.
From this I learned to get what you think you will need, Perhaps an extra. I'm registered for 3 now.
We're running Ian's gear here, it's worth waiting for.
Aguaazul
You think too much, you can buy it anytime, not only once a year. The only difference is that the price of group buy has a chance for lower.
28:Forane12: 2X FifoPi , 3X LifiPO4 pure power supply, 2X ESS controller, 2X Dual Mono ES9038Q2M , 2X ES9028Q2M DAC HAT, 2X I/V STD standard I/V stage, 2X Transformer I/V PCB, 2X ESS controller extension kit, 2XCCHD957 XO adapter kit lot of 2,1X OPA1622 adapter PCB kit lot of 5, 3X 2” double-ended silver plated U.FL coaxial cable, 3X LT3042 low noise regulator PCB, 2XI/V STD standard I/V stage empty PCB
92 cv: 2 x FifoPI
127. mige0: none
Updated 28
92 cv: 2 x FifoPI
127. mige0: none
Updated 28
63. Blitz: 2xLifePO4 Power, 1*transformer I/V, 1*I/V Standard
92 cv: 2 x FifoPI
127. mige0: none
Updated 63
92 cv: 2 x FifoPI
127. mige0: none
Updated 63
47. 1001meier: 1xFifoPi, 1xESS controller, 1x Dual Mono ES9038Q2M DAC HAT, 1x CCHD957 XO adapter kit lot of 2, 1x ESS controller extension kit
92 cv: 2 x FifoPI
127. mige0: none
Updated 47
92 cv: 2 x FifoPI
127. mige0: none
Updated 47
Thanks guys, I'm almost ready. The GB will be start, I just need a couple of days more.
Ian
92 cv: 2 x FifoPI
127. mige0: none
188. delfimmarues: 1 * FifoPi, 1 * CCHD957daapterKIT, 1 * RpiI2SAdapter, 4 * 2inchU.FLcable
Updated 47
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
