Ian asynchronous I2S and S/PDIF FIFO KIT group buy
1. StuderB67: 2x I2StoPCM
2. Hopkins: 1x S/PDIF interface board, 1x RPi Isolator
3. mk57:S/PDIF interface board
4. sckramer 2x RPi isolator boards
5. MikeyFresh: 2x RPi Isolator, 2x DoP Decoder
6. Greg Stewart 3x RPi isolator boards
7. Ben Mah: 1x RPi Isolator
8. bigpandahk : I2S/DSD FIFO
9. brother c : 1x MC FIFO & MC XO, 1x Raspi/Odroid isolator
10. ernesternest: 1x RPi isolator
11. RollE2k: 1x RPI/ODROID isolator HAT, 1x DoP decoder board, 2x TPS7A4700
12. tracer5: 1. Raspberry Pi /ODROID I2S/DSD isolator HAT
13/ diyaudnut: 1x MC FIFO & MC XO
14. tsuntaro: 1x MC FIFO & MC XO
15. jonners: 1x RPi Isolator
16. Yatsushiro: 2x RPi Isolators
17. vzs: 1x RPi Isolators
18. clivem: 10x RPi Isolators
19. supra I2S/DSD FIFO KIT, Raspberry Pi /ODROID I2S/DSD isolator HAT
20. ed linssen: I2S to PCM board (1x), TPS7A4700 reg(or alike) (1x).
21. Morde: 1x RPi Isolator HAT board, 1x DoP decoder board
22. curryking: 1x SPDIF interfaceboard,1x I2S Isolator,1x I2S FIFO II Kit,5 x Dual Clock II
23. minio: 1x Rpi Isolator
24. number9: 2 X RPI Isolators & 2 X DoP decoder
25. Oyvind 2xRPI Isolators, dual clock board
26. bobsherman
27. pierantonio: 2 x RPi Isolator boards, added 2017: 1x I2S FIFO II Kit, 1x Dual XO II Clock Board 45/49 XOs, 1 x Finished FIFO isolator board. 1x Finished TPS7A4700 LDO, 1x Package of Universal SMT XO Adapters, 4x Anti-vibration screw grommet set
28. BarG01: I2S to PCM board (1x), 6" double-ended silver plated U.FL coaxial cable (6x), Package of Universal SMT XO Adapters KIT lot of 5 ,
29. Josoeff: 1 x S/PDIF interface boar
30. superberg: I2S to PCM board (1x) + Raspberry Pi /ODROID I2S/DSD isolator HAT (1x)
31. larsth: 2x RPi isolator boards, 1x finished I2S FIFO board, 1x finished Dual XO Clock Board
32. savvas: I2S to PCM board
33. bommetje: 2x rpi isolator
34. minionas 1x RPI/ODROID isolator HAT; 1x DoP decoder board; 1x S/PDIF Interface Board; 1x SMT finished Battery Management V2.5 Mini KIT; 5x SMT U.FL socket
35. percival007 (3X) I2S to PCM PCB
36. boulogne75: 2 x RPi/Odroid Isolator Boards
37. Blitz: 1x MC isolator+clock. BBB/Rpi isolatorx1
38. Abartels1965: 2x RPI/ODROID isolator HAT & 2x DoP decoder board
39. Crom: 1 x FIFO DSD Kit & 1 x RPI isolator hat
40. hires: 1x MC FIFO + 1x MC XO board + 1x Rpi/Odroid isolator
41. mvagusta22: 1x FIFO Isolator and 1x Rpi/Ordoid isolator
42. xaled: 1x MC FIFO + 1x MC XO board + 2x Rpi/Odroid isolator + 1x I2S to PCM board
43. JimS: 1x MC FIFO, 1X MC XO
44. mjensen: 1 x MC FIFO, 1 x MC XO, 8 x u.fl both ends 4" cables, 1 x RPI isolator, 1x DoP decoder board
45. hileman65: 2x I2S to PCM, 4x TPS7A4700 reg, 6x 6" double ended U.FL coax cable
46. marcus1: parts no longer required.
47. Eldam : 1 x RPI isolator + DoP
48. rredline: 1x DoP decoder board, 1x RPi/Odroid Isolator Board
49. rmpfyf: 1x MC FIFO, 1x MC XO, 1x I2S to PCM, 2x isolator
50. hpn5350: 1x RPi Isolator Board, 1x I2S FIFO II Kit, 1x Dual XO Clock Board, 1x I2S Isolator, 1x SPDIF Interface, 1x TPS7A4700 Regulator
51. Canvas: 1x MC FIFO, 1x MC XO, 2x I2S to PCM, 1x RPI isolator
52. franz159: interested in two Raspberry Pi I2S isolator HAT
53. trung224: 1x RPI/Odroid Isolator
54. duster1: 1x I2S/DSD FIFO, 1x XO, 1x RPI/Odroid isolator
55. kolossos4730 2x RPi Isolators, 2x DoP decoder board
56. Flyingsparks: 1x MC FIFO, 1x MC XO, 2x RPi Isolator Board, 2x DoP Decoder Board, 1x SPDIF Interface, 4x Rubber Grommet Screw set
57. tubesguy: RPi isolator
58. tods: 1x MC FIFO, 1x MC XO, 4x RPi Isolator Board
59. Brumjam: 1x stereo FIFO, 1x dual XO board with clocks, 1x finished isolator board, 1x SPDIF board, 1x low noise regulator board, 1 x pack of universal XO adapters, 1 x set of 6 double-ended UFL cables 6", 1 x standoff pack, 1 x Pi I2S cape adaptor PCB
60: Jp85: i2s to PCM board x1, rpi/odroid isolator x1, 1x set of 6 double-ended UFL cables 6"
61. Sidiropa: 2x MC FIFO, 2x MC XO
62. dorkus: 1x Raspberry Pi I2S isolator HAT
63. badboygolf16v: 3 x RPi Isolator, 1 x I2S/DSD FIFO, 1 x MC XO, 1 x SPDIF, 4 x low noise regulator board, 1 x Pi I2S cape adapter, 4 x CCHD 957 adapter board, 3 x SMT finished Battery Management V2.5 Mini KIT, 1 x I2S to PCM, 1 x Stereo FIFO, 1 x Dual XO, 1 x Dual XO isolator, 4 x 4" uFL cable, 6 x 6" uFL cable
64. audiopassion: 2x MC FIFO, 3x MC XO, 2x RPi Isolator Board
66. flowerpot 1x I2S/DSD FIFO, 1x Rpi/Odroid isolator, 1x I2StoPCM
67 ianrt 2 x RPi isolator HAT
68 malarkey 2 x RPi isolator HAT(bidirectional)
69 myint 67 1xrpi isolator hat ,1x I2s/dsd fifo ,1MCXO
70. lindamar: 1x MC FIFO & MC XO, 2x RPi/Odroid isolator
71. nautibuoy: 1x RPi Isolator, 1x DSD decoder
72. bismuth: 1x RPi Isolator
73. Clemmaster: 2x RPi Isolator HAT (bidirectional), 1x I2S FIFO II Kit, 1x Dual XO Clock
74. Nikola Krivorov: 3x RPI/ODROID isolator HAT; 2x DoP decoder board, 1x I2S FIFO MC Kit, 1x Dual XO MC Clock Board no clocks, 1x Finished FIFO Isolator board,4x Anti-vibration screw grommet set
75. Juancho 3 x RPI isolator
76. nounouchet: 1x multi-channel I2S/DSD FIFO, 1x Package of Universal SMT XO Adapters KIT lot of 5
77. tecd: 1x I2S FIFO II board, 1x Dual XO II Clock Board 45/49 XOs, 1x I2S to PCM converter board, 1x Finished FIFO Isolator board, 1x Finished TPS7A4700 LDO regulator, 1x S/PDIF interfact board, 1x Battery Management PCB, 1x BIII adapter PCB, 1x Package of Universal SMT XO Adapters lot of 5, 4x Anti-vibration screw grommet set, 15x SMT U.FL socket, 3x 4” double-ended 50 ohm silver plated coaxial cable, 4x 6” double-ended 50 ohm silver plated coaxial cable
78. urien: 1x I2S FIFO II Kit, 1x I2S Isolator, 1x XO board, 1x I2S to PCM
79. ermine22: 2x MC FIFO, 2xMC XO, 1xRPI isolator
80. erikdebest: 2xRPI isolator
81. Stunts: 1x I2S/DSD FIFO, 1x I2S/DSD Isolator, 1x DSD Dual XO w/CCHD957 sockets and low noise regulator, 1x BIII adapter+connector, 1x RPi adapter cap
82. shochu: 1x RPi I2S/DSD Isolator (version that works with kali+piano)
83. s3gfault: 1x RPi isolator
84. M_Balou: 1x RPI Isolator
85. Znarfomat: 1x Finished FIFO Isolator board, 1x RPi I2S isolator HAT
86. nielsek: 1x MC FIFO, 1x MC XO, 1x RPI Isolator, 1x DoP decoder board, 1x S/PDIF Interface Board
87. ebrondolo : 1x I2S/DSD FIFO, 1x I2S/DSD Isolator, 1x DSD Dual XO w/CCHD957 sockets and low noise regulator.
88. analog_sa: 1 x S/PDIF Interface Board
89.clsidxxl:1x RPI Isolator
90. chevron: 1x RPi isolator
91. GaryB 1x I2S to PCM converter board
92. xedox 1 x USB to PCM converter board
93. gtose: 1x I2S FIFO II KIT, 1x Dual XO II Clock Board with 45/49 XOs, 1x S/PDIF Interface Board, 1x TPS7A4700, 4x Anti-vibration grommet set, 1x I2S to PCM
94. Brycej 1x RPI Isolator, 1x DoP decoder board
95. Miggie78: 1x RPI Isolator (bidirectional)
96. luchoh: 1x RPI/ODROID isolator HAT; 1x DoP decoder board; 1x SMT finished Battery
97. jazzbear: 1x RPi I2S/DSD Isolator (version that works with kali+B III 9018); 1x DoP decoder board
98. Surfchampion: 1xRPI/ODROID isolator HAT; 1x DoP decoder board; 1xMC FIFO; 1xMC XO; low noise regulator
99. comickitkit: 1x I2S to PCM
100. ppap64: 2 x Rpi/ODROID I2S/DSD isolator HAT
101. Mikhail Vorozhtsov: 1x FIFO isolator, 2x TPS7A4700 regulator, 4x screw grommet set, 8x 4" silver plated U.FL cable, 20x SMT U.FL socket, 2x Universal SMT XO Adapters KIT (or 1 lot of 5)
102. Kvl:1xRPI/ODROID isolator HAT, 1x DoP decoder board, 2xMC FIFO, 2xMC XO, 1x S/PDIF interface board
103. Stijn001 1xRPI/ODROID isolator HAT
104. Giordano 1x I2StoPCM
105. JeffreyD 2x RPI isolator HAT
106. recca: 2x I2S to PCM, 2x I2S FIFO II Kit, 2x Dual XO II Clock Board w 45/49 xo's
107. redjr: 3 x RPi isolator board, 2 x DoP DSD decoder board, 1 x I2S to PCM
108. casshan: 1 x RPI isolator, 1 x Dop DSD decoder board
109. wizardofoz 2 x RPI isolator, 2 x Dop DSD decoder board (possibly 3 of both cost permitting)
110. davej: 1x MC FIFO, 1x MC XO
111. seh: 1x MC FIFO, 1x MC XO
112: 4me2ctv: 1xRPI/ODROID isolator HAT, 1x DoP decoder board, isolated power supply?
113. PAX 1x I2StoPCM
114. Mike311063: 1x RPi isolator (version that works with Kali reclocker and Mamboberry ls dac)
115. kazap: 1x MC FIFO + 1x MC XO board + 2x PCM + cables
116. deanoUK 1x MC FIFO + 1x MC XO
117. Andresas: 1x RPi isolator
118. Athos56: 1 x RPI isolator, 1 x Dop DSD decoder board
119. darkmansk: 1 x RPI isolator, 1 x Dop DSD decoder board
120. tadek 2xRPi isolator, 2 x PCM , 4 UFL both ends 4 inch cables
121. s80044: 1x RPI 3 Ultra Low Jitter Reclocker + Isolator (on Rune Audio) with DUAL USB 2 + SPDIF out supporting DSD signal to external DAC
122: necplusultra: 1xRPI/ODROID isolator HAT, 1x DoP decoder board, + new version of FIFO?
123: devodad: 2xRPI/ODROID isolator HATs, 2x DoP DSD decoder boards, 6x u.fl both ends 4" cables
124. BDL: 1 x RPI/ODROID isolator HAT
125 lucser: 1xRPI/ODROID isolator HAT, 1x DoP decoder board, 4 x u.fl both ends 4" cables
126. Patjr : 1 x RPI/ODROID isolator HAT, 1 x Dop DSD decoder board
127. alexanderbax : 1x MC FIFO + 1x MC XO
128. petestorms : 1 x RPI/ODROID isolator HAT
129. hui13: 1xRPI/ODROID isolator HAT, 1x DoP decoder board, 4 x u.fl both ends 4" cables
130. RH75: 1 x RPI/ODROID isolator HAT
131. palmito: 1x MC FIFO, 1x RPi Isolator, 1x DoP Decode
132. Cheng : 1x RPi Isolator, 1 x I2S to PCM converter board V2.0, 1 x Finished FIFO isolator board V2.5
133. rrbs : 1xRPI/ODROID isolator HAT
134. JaimeSantos: 1 x RPi/Odroid isolator HAT for kali, 1x DoP decoder board, 4 x u.fl both ends 4"
135. Joseacm08: 1 x RPi/Odroid isolator HAT
136. CeeVee: 1 x RPi/Odroid isolator HAT with DOP decoder board, 1x MC FIFO.
137. wealas: 1x MC FIFO, 1x MC XO, 1x RPi Isolator, 1x DoP DSD Decoder board
138. marcelooms: 1x universal SMT XO adapter
139. Dimdim: 1x MC FIFO, 1x MC XO
140. crowlie: 1xRPI/ODROID isolator HAT
141. slartibartfasst: 1x MC FIFO, 1x MC XO, 2x RPi Isolator
142. C37: 1x MC FIFO, 1x MC XO
143. cyrilliu:1x MC FIFO, 1x MC XO with 45/49 XOs and sockets, 1 x RPi isolator, 1 x 10P 1.0mm FFC/FPC cables combo (3 cables), 1 X Standoffs/screws set(M3 4pcs, 15mm&8mm ), 1 X Finished FIFO isolator board, 1 X Finished TPS7A4700 low noise regulator board, 4 X Anti-vibration screw grommet set (767KE-ND), 12 X 4" double-ended silver plated U.FL coaxial cable, 2 X Raspberry Pi /ODROID I2S/DSD isolator HAT
144. yoke : 1x MC FIFO & MC XO
145. gwikse: 1x Rpi/Odroid isolator HAT
146. verwolf3: 2 isolator hats
147. koldby 1x I2S to PCM
148. androa76 1x rpi isolator reclocker hat
149. Aive: 1 x MC FIFO, MC XO
150. iestynrw: 1 x MC FIFO, MC XO
151. Nedi : 1x I2S to PCM board , 1x RPi/Odroid isolator HAT, 1x low noise TS7A reg
152. av-trouvaille 1x RPI/ODROID isolator HAT, 1x DoP decoder board, 2x TPS7A4700
26. bobsherman
153. ccliu: 1x RPI/ODROID isolator HAT, 1x DoP decoder board, 1x TPS7A4700, 1 X Finished FIFO isolator board
26. bobsherman
151. Nedi : 1x I2S to PCM board , 1x RPi/Odroid isolator HAT, 1x low noise TS7A4700 reg , 10x SMT U.FL socket
26. bobsherman
154. merlin el mago 1 x I2S to DSD FIFO
15. jonners: 2x RPi Isolators
26. bobsherman
38. Abartels1965: 1x RPI/ODROID isolator HAT
44. mjensen: 1 x MC FIFO, 1 x MC XO, 1 x RPI isolator, 1x DoP decoder board
47. Eldam : 1x low noise TS7A reg for Clock II + 1 x Odroid isolator HAT
74. Nikola Krivorov: 1x RPI/ODROID isolator HAT; 1x DoP decoder board, 1x I2S FIFO II Kit, 1x Dual XO II Clock Board no clocks, 1x Finished FIFO Isolator board,4x Anti-vibration screw grommet set
125. Nedi : 1x low noise TS7A reg for Clock II + 1 x RPi/Odroid isolator HAT
143 verwolf3 ; 2 isolator hat
, 1dop decoder board
26. bobsherman
146. verwolf3: 2 isolator hats, 1dop decoder board
155. adelias: 1xRPI/ODROID isolator HAT, 1xDoP decoder board
26. bobsherman
33. bommetje: 2x rpi isolator, 2x DoP decoder
26. bobsherman
140. crowlie: 1xRPI/ODROID isolator HAT, 1x DoP decoder board
26. bobsherman
153. ccliu: 1x RPI/ODROID isolator HAT, 1x DoP decoder board, 1x TPS7A4700, 1 X Finished FIFO isolator board, 1x MC FIFO, 1x MC XO with 45/49 XOs and sockets, 1 x 10P 1.0mm FFC/FPC cables combo (3 cables)
26. bobsherman
143. cyrilliu:1x MC FIFO, 1x MC XO with 45/49 XOs and sockets, 1 x RPi isolator, 1 x 10P 1.0mm FFC/FPC cables combo (3 cables), 1 X Standoffs/screws set(M3 4pcs, 15mm&8mm ), 1 X Finished FIFO isolator board, 1 X Finished TPS7A4700 low noise regulator board, 4 X Anti-vibration screw grommet set (767KE-ND), 12 X 4" double-ended silver plated U.FL coaxial cable, 2 X Raspberry Pi /ODROID I2S/DSD isolator HAT, 4x Universal SMT XO Adapters KIT (or 1 lot of 5)
updated
26. bobsherman
147. koldby 1x I2S to PCM, 1x MC FIFO, 1x MC XO
26. bobsherman
156. iancortez: 1xRPI/ODROID isolator HAT, 1xDoP decoder board
