Ian asynchronous I2S and S/PDIF FIFO KIT group buy
Hi Ian,
Are the isolator Pi and FIFO MC two different boards please ?
May you please, or someone else, explain what is the role of the DoP board ? And the way it is stacked on the other boards ?
regards
@Eldam
IsolatorPi and MC FIFO are different project.
DoP decoder daughter board works with IsolatorPi to make all current RPi player capable for native DSD playback/output.
More details are here:
http://www.diyaudio.com/forums/pc-b...tor-hat-native-dsd-decoder-8.html#post4902154
Regards,
Ian
wow.... best porn I ever seen 😀 ! Awesome....
Hey you have always one of my PCM pcb left I had broken ? Suceedet to fix it ?!
Looking Forward to have your conclusion about the sound with the new Crysteks and your new boards !
@ JP
Hi Ian,
How are you testing the MC FIFO?
Have you tried it with an 8CH source and an 8CH DAC?
thanks
JP
I have a test fixture for 14 ch I2S and 8 ch DSD loop testing. My MC FIFO /MC clock board combination passed both I2S 384KHz and DSD512 bit-perfect test for more than 24 hours without any bit error.
I also did test on my ES9018 BII DAC with good result.
The next, I'm gonna test at home theater system, I'm considering pick-up signals from my Marantz SR7010, which I bought on last black Friday😀.
Regards,
Ian
@ JP
Regards,
Ian
Thanks Ian.
There is a shortage of good multichannels DACs.
I am planning to try the MC FIFO with DIYINHK MC XMOS USB board and MC 9016DAC board.
Any comments on these?
1. StuderB67: 2x I2StoPCM
2. Hopkins: 1x S/PDIF interface board, 1x RPi Isolator
3. mk57:S/PDIF interface board
4. sckramer 2x RPi isolator boards
5. MikeyFresh: 2x RPi Isolator, 2x DoP Decoder
6. Greg Stewart 3x RPi isolator boards
7. Ben Mah: 1x RPi Isolator
8. bigpandahk : I2S/DSD FIFO
9. brother c : 1x MC FIFO & MC XO, 1x Raspi/Odroid isolator
10. ernesternest: 1x RPi isolator
11. RollE2k: 1x RPI/ODROID isolator HAT, 1x DoP decoder board, 2x TPS7A4700
12. tracer5: 1. Raspberry Pi /ODROID I2S/DSD isolator HAT
13/ diyaudnut: 1x MC FIFO & MC XO
14. tsuntaro: 1x MC FIFO & MC XO
15. jonners: 1x RPi Isolator
16. Yatsushiro: 2x RPi Isolators
17. vzs: 1x RPi Isolators
18. clivem: 10x RPi Isolators
19. supra I2S/DSD FIFO KIT, Raspberry Pi /ODROID I2S/DSD isolator HAT
20. ed linssen: I2S to PCM board (1x), TPS7A4700 reg(or alike) (1x).
21. Morde: 1x RPi Isolator HAT board
22. curryking: 1x SPDIF interfaceboard,1x I2S Isolator,1x I2S FIFO II Kit,5 x Dual Clock II
23. minio: 1x Rpi Isolator
24. number9: 2 X RPI Isolators & 2 X DoP decoder
25. Oyvind 2xRPI Isolators, dual clock board
26. bobsherman
27. pierantonio: 2 x RPi Isolator boards, added 2017: 1x I2S FIFO II Kit, 1x Dual XO II Clock Board 45/49 XOs, 1 x Finished FIFO isolator board. 1x Finished TPS7A4700 LDO, 1x Package of Universal SMT XO Adapters, 4x Anti-vibration screw grommet set
28. BarG01: I2S to PCM board (1x), 6" double-ended silver plated U.FL coaxial cable (6x), Package of Universal SMT XO Adapters KIT lot of 5 ,
29. Josoeff: 1 x S/PDIF interface boar
30. superberg: I2S to PCM board (1x) + Raspberry Pi /ODROID I2S/DSD isolator HAT (1x)
31. larsth: 2x RPi isolator boards, 1x finished I2S FIFO board, 1x finished Dual XO Clock Board
32. savvas: I2S to PCM board
33. bommetje: 2x rpi isolator
34. minionas 1x RPI/ODROID isolator HAT; 1x DoP decoder board; 1x S/PDIF Interface Board; 1x SMT finished Battery Management V2.5 Mini KIT; 5x SMT U.FL socket
35. percival007 (3X) I2S to PCM PCB
36. boulogne75: 2 x RPi/Odroid Isolator Boards
37. Blitz: 1x MC isolator+clock. BBB/Rpi isolatorx1
38. Abartels1965: 1x RPI/ODROID isolator HAT
39. Crom: 1 x FIFO DSD Kit & 1 x RPI isolator hat
40. hires: 1x MC FIFO + 1x MC XO board + 1x Rpi/Odroid isolator
41. mvagusta22: 1x FIFO Isolator and 1x Rpi/Ordoid isolator
42. xaled: 1x MC FIFO + 1x MC XO board + 2x Rpi/Odroid isolator + 1x I2S to PCM board
43. JimS: 1x MC FIFO, 1X MC XO
44. mjensen: 1 x MC FIFO, 1 x MC XO, 1 x RPI isolator, 1x DoP decoder board
45. hileman65: 2x I2S to PCM, 4x TPS7A4700 reg, 6x 6" double ended U.FL coax cable
46. marcus1: parts no longer required.
47. Eldam : 1x low noise TS7A reg for Clock II + 1 x Odroid isolator HAT
48. rredline: 1x DoP decoder board, 1x RPi/Odroid Isolator Board
49. rmpfyf: 1x MC FIFO, 1x MC XO, 1x I2S to PCM, 2x isolator
50. hpn5350: 1x RPi Isolator Board, 1x I2S FIFO II Kit, 1x Dual XO Clock Board, 1x I2S Isolator, 1x SPDIF Interface, 1x TPS7A4700 Regulator
51. Canvas: 1x MC FIFO, 1x MC XO, 2x I2S to PCM, 1x RPI isolator
52. franz159: interested in two Raspberry Pi I2S isolator HAT
53. trung224: 1x RPI/Odroid Isolator
54. duster1: 1x I2S/DSD FIFO, 1x XO, 1x RPI/Odroid isolator
55. kolossos4730 2x RPi Isolators, 2x DoP decoder board
56. Flyingsparks: 1x MC FIFO, 1x MC XO, 2x RPi Isolator Board, 2x DoP Decoder Board, 1x SPDIF Interface, 4x Rubber Grommet Screw set
57. tubesguy: RPi isolator
58. tods: 1x MC FIFO, 1x MC XO, 4x RPi Isolator Board
59. Brumjam: 1x stereo FIFO, 1x dual XO board with clocks, 1x finished isolator board, 1x SPDIF board, 1x low noise regulator board, 1 x pack of universal XO adapters, 1 x set of 6 double-ended UFL cables 6", 1 x standoff pack, 1 x Pi I2S cape adaptor PCB
60: Jp85: i2s to PCM board x1, rpi/odroid isolator x1, 1x set of 6 double-ended UFL cables 6"
61. Sidiropa: 2x MC FIFO, 2x MC XO
62. dorkus: 1x Raspberry Pi I2S isolator HAT
63. badboygolf16v: 3 x RPi Isolator, 1 x I2S/DSD FIFO, 1 x MC XO, 1 x SPDIF, 4 x low noise regulator board, 1 x Pi I2S cape adapter, 4 x CCHD 957 adapter board, 3 x SMT finished Battery Management V2.5 Mini KIT, 1 x I2S to PCM, 1 x Stereo FIFO, 1 x Dual XO, 1 x Dual XO isolator, 4 x 4" uFL cable, 6 x 6" uFL cable
64. audiopassion: 2x MC FIFO, 3x MC XO, 2x RPi Isolator Board
66. flowerpot 1x I2S/DSD FIFO, 1x Rpi/Odroid isolator, 1x I2StoPCM
67 ianrt 2 x RPi isolator HAT
68 malarkey 2 x RPi isolator HAT(bidirectional)
69 myint 67 1xrpi isolator hat ,1x I2s/dsd fifo ,1MCXO
70. lindamar: 1x MC FIFO & MC XO, 2x RPi/Odroid isolator
71. nautibuoy: 1x RPi Isolator, 1x DSD decoder
72. bismuth: 1x RPi Isolator
73. Clemmaster: 2x RPi Isolator HAT (bidirectional), 1x I2S FIFO II Kit, 1x Dual XO Clock
74. Nikola Krivorov: 1x RPI/ODROID isolator HAT; 1x DoP decoder board, 1x I2S FIFO II Kit, 1x Dual XO II Clock Board no clocks, 1x Finished FIFO Isolator board,4x Anti-vibration screw grommet set
75. Juancho 3 x RPI isolator
76. nounouchet: 1x multi-channel I2S/DSD FIFO, 1x Package of Universal SMT XO Adapters KIT lot of 5
77. tecd: 1x I2S FIFO II board, 1x Dual XO II Clock Board 45/49 XOs, 1x I2S to PCM converter board, 1x Finished FIFO Isolator board, 1x Finished TPS7A4700 LDO regulator, 1x S/PDIF interfact board, 1x Battery Management PCB, 1x BIII adapter PCB, 1x Package of Universal SMT XO Adapters lot of 5, 4x Anti-vibration screw grommet set, 15x SMT U.FL socket, 3x 4” double-ended 50 ohm silver plated coaxial cable, 4x 6” double-ended 50 ohm silver plated coaxial cable
78. urien: 1x I2S FIFO II Kit, 1x I2S Isolator, 1x XO board, 1x I2S to PCM
79. ermine22: 2x MC FIFO, 2xMC XO, 1xRPI isolator
80. erikdebest: 2xRPI isolator
81. Stunts: 1x I2S/DSD FIFO, 1x I2S/DSD Isolator, 1x DSD Dual XO w/CCHD957 sockets and low noise regulator, 1x BIII adapter+connector, 1x RPi adapter cap
82. shochu: 1x RPi I2S/DSD Isolator (version that works with kali+piano)
83. s3gfault: 1x RPi isolator
84. M_Balou: 1x RPI Isolator
85. Znarfomat: 1x Finished FIFO Isolator board, 1x RPi I2S isolator HAT
86. nielsek: 1x MC FIFO, 1x MC XO, 1x RPI Isolator, 1x DoP decoder board, 1x S/PDIF Interface Board
87. ebrondolo : 1x I2S/DSD FIFO, 1x I2S/DSD Isolator, 1x DSD Dual XO w/CCHD957 sockets and low noise regulator.
88. analog_sa: 1 x S/PDIF Interface Board
89.clsidxxl:1x RPI Isolator
90. chevron: 1x RPi isolator
91. GaryB 1x I2S to PCM converter board
92. xedox 1 x USB to PCM converter board
93. gtose: 1x I2S FIFO II KIT, 1x Dual XO II Clock Board with 45/49 XOs, 1x S/PDIF Interface Board, 1x TPS7A4700, 4x Anti-vibration grommet set, 1x I2S to PCM
94. Brycej 1x RPI Isolator, 1x DoP decoder board
95. Miggie78: 1x RPI Isolator (bidirectional)
96. luchoh: 1x RPI/ODROID isolator HAT; 1x DoP decoder board; 1x SMT finished Battery
97. jazzbear: 1x RPi I2S/DSD Isolator (version that works with kali+B III 9018); 1x DoP decoder board
98. Surfchampion: 1xRPI/ODROID isolator HAT; 1x DoP decoder board; 1xMC FIFO; 1xMC XO; low noise regulator
99. comickitkit: 1x I2S to PCM
100. ppap64: 2 x Rpi/ODROID I2S/DSD isolator HAT
101. Mikhail Vorozhtsov: 1x FIFO isolator, 2x TPS7A4700 regulator, 4x screw grommet set, 8x 4" silver plated U.FL cable, 20x SMT U.FL socket, 2x Universal SMT XO Adapters KIT (or 1 lot of 5)
102. Kvl:1xRPI/ODROID isolator HAT, 1x DoP decoder board, 2xMC FIFO, 2xMC XO, 1x S/PDIF interface board
103. Stijn001 1xRPI/ODROID isolator HAT
104. Giordano 1x I2StoPCM
105. JeffreyD 2x RPI isolator HAT
106. recca: 2x I2S to PCM, 2x I2S FIFO II Kit, 2x Dual XO II Clock Board w 45/49 xo's
107. redjr: 3 x RPi isolator board, 2 x DoP DSD decoder board, 1 x I2S to PCM
108. casshan: 1 x RPI isolator, 1 x Dop DSD decoder board
109. wizardofoz 2 x RPI isolator, 2 x Dop DSD decoder board (possibly 3 of both cost permitting)
110. davej: 1x MC FIFO, 1x MC XO
111. seh: 1x MC FIFO, 1x MC XO
112: 4me2ctv: 1xRPI/ODROID isolator HAT, 1x DoP decoder board, isolated power supply?
113. PAX 1x I2StoPCM
114. Mike311063: 1x RPi isolator (version that works with Kali reclocker and Mamboberry ls dac)
115. kazap: 1x MC FIFO + 1x MC XO board + 2x PCM + cables
116. deanoUK 1x MC FIFO + 1x MC XO
117. Andresas: 1x RPi isolator
118. Athos56: 1 x RPI isolator, 1 x Dop DSD decoder board
119. darkmansk: 1 x RPI isolator, 1 x Dop DSD decoder board
120. tadek 2xRPi isolator, 2 x PCM , 4 UFL both ends 4 inch cables
121. s80044: 1x RPI 3 Ultra Low Jitter Reclocker + Isolator (on Rune Audio) with DUAL USB 2 + SPDIF out supporting DSD signal to external DAC
122: necplusultra: 1xRPI/ODROID isolator HAT, 1x DoP decoder board, + new version of FIFO?
123: devodad: 2xRPI/ODROID isolator HATs, 2x DoP DSD decoder boards, 6x u.fl both ends 4" cables
124. BDL: 1 x RPI/ODROID isolator HAT
125 lucser: 1xRPI/ODROID isolator HAT, 1x DoP decoder board, 4 x u.fl both ends 4" cables
125. Nedi : 1x low noise TS7A reg for Clock II + 1 x RPi/Odroid isolator HAT
126. Patjr : 1 x RPI/ODROID isolator HAT, 1 x Dop DSD decoder board
127. alexanderbax : 1x MC FIFO + 1x MC XO
128. petestorms : 1 x RPI/ODROID isolator HAT
129. hui13: 1xRPI/ODROID isolator HAT, 1x DoP decoder board, 4 x u.fl both ends 4" cables
130. RH75: 1 x RPI/ODROID isolator HAT
131. palmito: 1x MC FIFO, 1x RPi Isolator, 1x DoP Decode
132. Cheng : 1x RPi Isolator, 1 x I2S to PCM converter board V2.0, 1 x Finished FIFO isolator board V2.5
133. rrbs : 1xRPI/ODROID isolator HAT
134. JaimeSantos: 1 x RPi/Odroid isolator HAT for kali, 1x DoP decoder board, 4 x u.fl both ends 4"
135. Joseacm08: 1 x RPi/Odroid isolator HAT
136. CeeVee: 1 x RPi/Odroid isolator HAT with DOP decoder board, 1x MC FIFO.
137. wealas: 1x MC FIFO, 1x MC XO, 1x RPi Isolator, 1x DoP DSD Decoder board
138. marcelooms: 1x universal SMT XO adapter
139. Dimdim: 1x MC FIFO, 1x MC XO
140. crowlie: 1xRPI/ODROID isolator HAT
141. slartibartfasst: 1x MC FIFO, 1x MC XO, 2x RPi Isolator
142. C37: 1x MC FIFO, 1x MC XO
26. bobsherman
143. cyrilliu:1x MC FIFO, 1x MC XO with 45/49 XOs and sockets, 1 x RPi isolator, 1 x 10P 1.0mm FFC/FPC cables combo (3 cables), 1 X Standoffs/screws set(M3 4pcs, 15mm&8mm ), 1 X Finished FIFO isolator board, 1 X Finished TPS7A4700 low noise regulator board, 4 X Anti-vibration screw grommet set (767KE-ND), 8 X 4" double-ended silver plated U.FL coaxial cable, 1 X Raspberry Pi /ODROID I2S/DSD isolator HAT
21. Morde: 1x RPi Isolator HAT board, 1x DoP decoder board
26. bobsherman
26. bobsherman
74. Nikola Krivorov: 3x RPI/ODROID isolator HAT; 2x DoP decoder board, 1x I2S FIFO MC Kit, 1x Dual XO MC Clock Board no clocks, 1x Finished FIFO Isolator board,4x Anti-vibration screw grommet set
26. bobsherman
144. yoke : 1x MC FIFO & MC XO
26. bobsherman
145. gwikse: 1x Rpi/Odroid isolator HAT
Ian, can I ask if the I2S to pcm board's master clock input is 5v tolerant please?
I can see from the instructions that the I2S inputs are but no mention is made about the mclk.
If not, can I use a resistive divider eg 470r series, 1k to 0v on the input.
Thanks.
Hi Batteryman,
MCLK input on the PCM board is 3.3V logic. To work with 5V logic level, I would suggest you using a 100ohm series resistor together with a pull-up diode to shift the level. Please see the schematics as below.
...................... -------|>|-------3.3V
100ohm............|
5V logic output -> 3.3V logic input
Regards,
Ian
Hi Batteryman,
100ohm............|
Regards,
Ian
Many thanks.
(I asked because I am fitting a low jitter clock to the clock input on the SAA7220 in the cd player from where the I2S signals are extracted and also supplying it to the mclk input on the I2S pcb.)
