Ian asynchronous I2S and S/PDIF FIFO KIT group buy
One more order from me, thank you Ian!
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
5. AR2 2 x Si570 clock board - definitely!
6. wktk_smile
7. hirez69 1 x Si570 clock board, 2 x Isolator board, 4 x TPS7A4700 reg board, 2 x Battery management board
8. CeeVee - you bet!
9. number9 Si570 Clock Board
10. analog_sa - 2 x Si570 clock board, 2 x FIFO isolator, 2 x TPS7A4700
11. edbk
12. atom6422
13. misterrogers 1xI2S FIFO KIT, 3x Si570 Clock board, 1x FIFO isolator, 1x Battery management board
14. NicMac - as usual!
15. Zoran
16. PET-240- SI570 x1, Isolator Board(pre-tested?) x 1.
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
23. Greg Stewart: 1 x Si570, 2 x TPS7A4700 board, 8 x U.FL 2" cable (if they become available)
24. Vitalica (2 x Si570 clock board, 2 x Isolator board, 4 x TPS7A4700 reg board, 2 x Battery management board)
25. spm
26. Fridrik
27. ccliu
28. makumba1966 : 2 x Si570, 2 x TPS7A4700 board, 8 x U.FL 2" cable, 2 x Universal I2S isolator, 2 x Passive Battery Management Adapter Rev2.0, 2 x Isolator board
29. lindamar: 1 x Si570 , 2 x TPS7A4700 board, 1 x Universal I2S isolator, 1 x Passive Battery Management Adapter Rev2.0, 1 x Isolator Rev2.0 board, 1 x I2S backdoor KIT for S/PDIF board (is that an additional board?)
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
36. DUC985 1x Si570 clock board, 1 x TPS7A4700 reg board
37. rsotirov 1x Si570 clock board
38. kvl 1 x Si570 clock board, 1 x Isolator board, 1 x TPS7A4700 reg board, 1 x Battery management board, 1x 1.0mm FFC/FPC cables combo, 1 x back door kit.
39. bkdog - 1 x I2S FIFO KIT, 1 x Si570 clock board, 1 x S/PDIF Interface Board, 1 x Isolator board, 1 x BufalloIII u.fl adapter kit, 1 x BufalloIII Clock adapter kit, I2S backdoor KIT, BIII adapter PCB, SMT connector package for BIII adapters, 1 x FIFO isolator board V1.5 MINI KIT, 3 x battery management pcb
40. necplusultra
41. Nikola Krivorov 2 x Si570 clock board, 3 x I2S to PCM board, 2 x TPS7A4700 reg
42. nvduybom
43. Popolvar - 1 x Si570 clock board, 1 x dualXO clock board, 1 x TPS7A4700 reg board, 1 x Package of Universal SMT XO Adapters, 1 x FIFO isolator board V2.0
44. TNT 1 x Si570 clock board, 1 x Isolator board, 6 x TPS7A4700 reg board
45. sidiropa 1x Si570 clock board, 1x isolator 1x 1.0mm FFC/FPC cables combo, 1x battery management pcb,1 x S/PDIF board, , I2S backdoor KIT for S/PDIF board, 2 x TPS7A4700 reg board
46. leejh
47. Alcaudon 1 x FIFO kit, 1 x Si570 clock board, 1 x S/PDIF Interface board, 1 x FIFO Isolator, 1 x Universal I2S/DSD Isolator, 1 x I2S Backdoor kit, 2 x TPS7A4700 Reg. board, 2 x Battery management board.
48. sernikus (all + 2xSi570 )
49. enantra
50. Giordano, FIFO kit + a dual osc.
51. oyvind I2S FIFO KIT, Si570 clock board, S/PDIF Interface Board, I2S backdoor KIT for S/PDIF board, BIII adapter PCB, SMT connector package for BIII adapters, FIFO isolator board V1.5 MINI KIT, battery management pcb
52. duster1 1x Si570 clock board, 1x isolator
53. Blitz Si570 clock, 1x isolator, 3 x TPS7A4700 reg board, 3 x Battery management board, 1 x back door kit, 10 clock adapter for dual clock (2*5), 2 BIII adapters, both sides (incl. 2* Sync.Clock adapters)
54. Josoeff 1 x FIFO kit and 1 x S/PDIF interface board
55. crobbins5421 1 x FIFO kit, 1 x S/PDIF board, 1 x Si570 Clock Board
56. Regal 2 x Si570 clock , 2x TPS7A4700 reg board, 2 x Battery management board, 2 x back door kit,2x isolator board
57. aos FIFO kit, S/PDIF board, 1 x Si570 clock, 6 x U.FL socket, 3 X 6" U.FL cable, 1 X I2S backdoor kit, 1 X SMT XO adapter package, 1 X BIII adapter, 1 X SMT conn for BIII, 1 X FIFO isolator, 2 X cables combo, 2 x TPS7A4700 reg board
58. dvb-projekt 1x FIFO Kit, 1x Dual XO clock kit, 1X Isolator board kit, 1x S/PDIF interface board kit, 1x Backdoor Kit
59. Tubo 1x si570 clock kit, 1x isolator board, 1x tps7a4700 regulator board
60. bisesik 1xI2S FIFO KIT, 1x Dual XO Clock board (Si570), 1 x S/PDIF Interface Board, 1x I2S backdoor KIT for S/PDIF board, 2x FIFO isolator, 1x Battery management board
61. BDL 1 x Si570 clock board, 1 x Isolator board, 2 x TPS7A4700 reg board, 2 x Battery management board
62. damohpi 1x FIFO kit, 1x Si570 kit, 1x isolator kit, 1x spdif board kit, 1x backdoor kit
63. Overkill Audio - 1xI2S FIFO KIT, 2x Si570 Clock board, 1x FIFO isolator, 1x Battery management board
64. JoeyDD - 1x FIFO kit, 1x Si570 kit, 1x FIFO isolator kit, 3x U.FL 6" cable
65. chi0001 - 1x Si570 clock board, 1 x TPS7A4700 reg board
66. edlinssen Si570
67. buzzforb - 1x FIFO kit, 1x isolator kit, 1x spdif board kit, 1x backdoor kit , accessories
68. hughs
69. ccliu - 2x Si570 Clock board, 1x FIFO isolator, 2x TPS7A4700 reg board, 2x Battery management board
70. mhgawel - 1x FIFO Kit, 1x Dual XO clock kit, 1X Isolator board kit, 1x S/PDIF interface board kit, 1x Package of Universal SMT XO Adapters KIT (lot of 5)
71. Telstar - 2x TPS7A4700 reg boards (or more depending on price, see PM)
72. t27049215 - 1x FIFO Kit, 1x Dual XO clock kit, 1x Si570 clock board, 1X Isolator board kit, 1x S/PDIF interface board kit, 2x TPS7A4700 reg board
73. themystical - 2xTPS7A4700 Regulator boards
74. jtktam - 5x FIFO Kit, 5x Dual XO clock kit, 5X Isolator board kit, 5x S/PDIF, 3x U.FL 4" , 3x U.FL 6" cable, 3x U.FL 12" cable, 3X Isolator board kit, 3x S/PDIF interface board kit
75.mcluxun 1x FIFO Kit, 1x Isolator board kit, 1x S/PDIF, 1x Si570 clock board,
76. unixdeveloper - 1x Package of Universal SMT XO Adapters KIT (lot of 5), 3x U.FL 4" , 3x U.FL 6" cable, 3x TPS7A4700 reg board
77. JamesHill
78. Seavan - FIFO kit, dual xo clock kit (Si570?), s/pdif interface, i2s backdoor kit, isolator board kit, 3xU.Fl 4", 3xU.Fl 12", SMT XO adapter package, BIII adapter, SMT for BIII, FFC/FPC combo, battery management PCB
79. vzs - 1 x Package of Universal SMT XO Adapters; 4x 4” U.FL cable; 6x U.FL socket
80. henry97 - 1 x I2S FIFO KIT, 1 x Si570 clock board, 1 x S/PDIF Interface Board, 1 x Isolator board, 1 x BufalloIII u.fl adapter kit, 1 x BufalloIII Clock adapter kit, I2S backdoor KIT, BIII adapter PCB, SMT connector package for BIII adapters, 1 x FIFO isolator board V1.5 MINI KIT, 2 x battery management pcb
81. TheShaman - TBD
82. noizas 1x I2S FIFO Kit, 1x Dual XO clock kit (Si570), 1x S/PDIF interface board kit, 1X Isolator board kit, 1x Backdoor Kit, 2xU.Fl 4", 2xU.Fl 6", 2xU.Fl 12", 2x Battery management board
84: SSassen : 1x I2S FiFo kit, 1 x Package of Universal SMT XO Adapters, 1 x Si570 clock board, 4x TPS7A4700 Regulator boards, 1x S/PDIF interface board kit
85.hksidney 1x i2s fifo kit, 1 x si570 clock board, 1 x s/pdif interface kit, 1 x isolation board kit.[/QUOTE]
86. WhiteBull: 1x FIFO Kit, 1x Si570 clock board, 4x U.Fl 4" cables, 4x U.Fl sockets, 1x BIII adapter kit
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
11. edbk
12. atom6422
15. Zoran
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
25. spm
26. Fridrik
27. ccliu
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
40. necplusultra
42. nvduybom
46. leejh
49. enantra
66. edlinssen Si570
68. hughs
77. JamesHill
81. TheShaman - TBD
87. Karvid: 1x Si570 clock board
I need more please....
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
11. edbk
12. atom6422
15. Zoran
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
25. spm
26. Fridrik
27. ccliu
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
40. necplusultra
42. nvduybom
46. leejh
49. enantra
55. crobbins5421 2 x FIFO kit, 1 x S/PDIF board, 1 x Si570 Clock Board, 1 x Dual XO Board, 1 x I2S backdoor kit
66. edlinssen Si570
68. hughs
77. JamesHill
81. TheShaman - TBD
First order from me, thank you Ian!
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
11. edbk
12. atom6422
15. Zoran
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
25. spm
26. Fridrik
27. ccliu
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
40. necplusultra
42. nvduybom
46. leejh
49. enantra
66. edlinssen Si570
68. hughs
77. JamesHill
81. TheShaman - TBD
88. RSG: 1 x I2S FIFO KIT, 1 x S/PDIF Interface Board.
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
11. edbk
12. atom6422
13. misterrogers 1xI2S FIFO KIT, 3x Si570 Clock board, 3x TPS7A4700 Regulator boards, 1x FIFO isolator, 1x Battery management board
15. Zoran
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
25. spm
26. Fridrik
27. ccliu
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
40. necplusultra
42. nvduybom
46. leejh
49. enantra
66. edlinssen Si570
68. hughs
77. JamesHill
81. TheShaman - TBD
. just adding some more ...
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
11. edbk
12. atom6422
15. Zoran
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
25. spm
26. Fridrik
27. ccliu
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
40. necplusultra
42. nvduybom
46. leejh
49. enantra
66. edlinssen Si570
68. hughs
77. JamesHill
81. TheShaman - TBD
86. WhiteBull: 1x FIFO Kit, 1x Si570 clock board, 4x U.Fl 4" cables, 4x U.Fl sockets, 1x BIII adapter kit, 1x FIFO isolator board, 1x Universal I2S/DSD isolator, 1x FFC/FPC cables combo
88. RSG: 1 x I2S FIFO KIT, 1 x S/PDIF Interface Board.[/QUOTE]
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
11. edbk
12. atom6422
15. Zoran
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
25. spm
26. Fridrik
27. ccliu
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
40. necplusultra
42. nvduybom
46. leejh
49. enantra
66. edlinssen Si570
68. hughs
77. JamesHill
81. TheShaman - TBD
89. Joonas: 1x Dual clock board, 1x Isolator mini kit
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
11. edbk
12. atom6422
15. Zoran
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
25. spm
26. Fridrik
27. ccliu
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
40. necplusultra
42. nvduybom
46. leejh
49. enantra
66. edlinssen Si570
68. hughs
77. JamesHill
81. TheShaman - TBD
90. TonyB: everything, some things 2x
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
11. edbk
12. atom6422
15. Zoran
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
25. spm
26. Fridrik
27. ccliu
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
40. necplusultra
42. nvduybom
43. Popolvar - 1 x Si570 clock board, 1 x dualXO clock board, 1 x TPS7A4700 reg board, 1 x Package of Universal SMT XO Adapters, 1 x FIFO isolator board V2.0, 1 x Passive Battery Management Adapter Rev2.0
46. leejh
49. enantra
66. edlinssen Si570
68. hughs
77. JamesHill
81. TheShaman - TBD
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
11. edbk
12. atom6422
15. Zoran
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
25. spm
26. Fridrik
27. ccliu
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
40. necplusultra
42. nvduybom
46. leejh
49. enantra
66. edlinssen Si570
68. hughs
77. JamesHill
81. TheShaman - TBD
91. Bemused 6x TPS7A4700 Regulator boards
... updated my order ...
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
11. edbk
12. atom6422
15. Zoran
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
25. spm
26. Fridrik
27. ccliu
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
40. necplusultra
42. nvduybom
46. leejh
49. enantra
66. edlinssen Si570
68. hughs
77. JamesHill
81. TheShaman - TBD
86. WhiteBull: 2x FIFO Kit, 2x Si570 clock board + TPS7A4700 Regulator board, 10x U.Fl 4" cables, 8x U.Fl sockets, 1x BIII adapter kit, 2x FIFO isolator board, 2x Universal I2S/DSD isolator, 2x FFC/FPC cables combo
91. Bemused 6x TPS7A4700 Regulator boards[/QUOTE]
Ian FIFO KIT group buy GB IV is running now
Please note:
1. Please download the new GBIV order form and send it back to me at iancanada.mail@gmail.com no matter if you already sent the old form to me.
2. Your order number will be “GBIV” + waiting list number. For example, if you are N23 on the list, your order number will be GBIV23. Please include this number for any support you need from me.
3. If your Paypal shipping address is different from the one on your order form, I’ll ship to the Paypal address except you put a note with a new address on your Paypal payment form.
4. If you know your address use to have problems such as customs clearance or lost mails or etc, please give me a safe address in Canada or USA to ship to. I do not responsible for the lost of mail.
5. For CanadaPost, tracking number equals to register, no tracking number means it’s not a registered mail.
6. Some of the items from GBIII may not keep enough stock.
7. For small quantity prototype factory SMT reflow process, the quality may not as good as mass quantity production. Dry solder may still chance to exist even passing the test. Inspection is required in case having functional issues.
8. I may ask you pay me in Canadian Dollar for this time. It always around par with USD
Description
Here is the R&D thread which you could find all the details.
http://www.diyaudio.com/forums/digi...ifo-project-ultimate-weapon-fight-jitter.html
But for many of us, thread is too long to follow up, so alternatively you can download the user’s guidance and other technical documents I attached below as a kind of sum up.
I’m trying to keep all the pricing as same as GBIII, but may have more items listed.
I may not include the XLR socket on the S/PDIF board for this time for it is too big to ship in an envelope which can save some on shipping for you.
Another thing is the 3.9% Paypel fee was too much for me. I’m afraid I have to ask you kindly sharing half of the Paypel fee with me which would be 1.95% of the total payment as same as GBIII.
All of the Digikey part numbers of the accessories were given in the corresponding technical documents. You can order them from Digikey directly.
Lists and prices
1. I2S FIFO KIT V3.80 $149- CAD/ea
Including:
- A finished and tested I2S FIFO Board with firmware V3.80 upgraded
- Two 8" single-ended PH 2.0mm 7-pin I2S cables
- One 2" double-ended PH 2.0 mm 7-pin I2S bridge cable
- One 6" double-ended U.FL cable for MCLK
- One 2" 10-pin FPC/FFC cable
- An 11.2896 MHz oscillator installed for function verification
- An universal SMT XO adapter KIT for free
- A BIII adapters PCB (input adapter and sync/async clock adapter) for free
- A jumper KIT for free
2. Dual XO Clock board V3.3 $59- CAD/ea
Including:
- An assembled and tested Dual XO Clock Board (double-sided SMT mounting)
- One 6” double-ended U.FL coaxial cable
- One 2” 10-pin FPC/FFC cable
- One 2.5" double-ended PH 2.0 mm 7-pin I2S bridge cable
- 22.5792 MHz and 24.5760 MHz oscillators for function verification
3. S/PDIF Interface Board $89- CAD/ea
Including:
- An assembled and tested S/PDIF Interface Board
- Two 5” double-ended PH 2.0mm 7-pin I2S cables
- One 6” double-ended U.FL coaxial cable for MCLK output
- One 2” 10-pin FPC/FFC cable to interface with the I2S FIFO Board
- Two BNC to RCA adapters
4. SMT U.FL socket $1 CAD/ea
5. 4” double-ended 50 ohm coaxial cable $2 CAD/ea
6. 6” double-ended 50 ohm coaxial cable $3 CAD/ea
7. 12” double-ended 50 ohm coaxial cable $4 CAD/ea
8. I2S backdoor KIT for S/PDIF board $3.99 CAD/ea
Including:
- A 4 pin PH2.0mm SMT male connector
- A 4 pin PH2.0mm connector house
- Four 8” single-ended cables with PH2.0mm terminal (same or different color)
- A small piece of high temperature SMT tape
9. Package of Universal SMT XO Adapters lot of 5 $9.99 CAD/ea
Including:
- Five Universal SMT XO Adapter PCBs (linked together with V-cut)
- Twenty pin terminals
- Ten 100n 0603 SMT MMLC for the optional decoupling capacitors
- Five 1u 0805 SMT MMLC for the optional decoupling capacitors
10. Additional BIII adapters PCB $3.98 CAD/ea
Including:
- A input U.FL adapter PCB
- A SYNC/ASYNC clock adapter PCB
11. SMT connector package for BIII adapters $3.96 CAD/ea
Including:
- A 20 pin 2.54mm SMT female connector header
- A 3 pin 2.54mm right angled pin connector
12. FIFO isolator board V2.0 MINI KIT $15.99 CAD/ea
Including:
- An isolator PCB
- Two 7P Ph2.0 cables
-Two 10P FFC cables
-Two 7P Ph2.0 SMT sockets
-Two 10P FFC SMT sockets
-One 2P Ph2.0 power cable
-Four 33ohm SMT resistor array
13. 10P 1.0mm FFC/FPC cables combo $3.95 CAD/(three cables)
Including:
- Three 7P 1.0mm FFC/FPC cables, 2”,4” and 6”
14. Si570 Clock Board V3.5(with Si570) $89- CAD/ea
Including:
- An finished and tested Si570 Clock Board (double-sided SMT mounting)
- One 2P Ph2.0 power cable
- One 1P double-ended LDO bypass jumper
15. Si570 Clock Board V3.5(without Si570) $59- CAD/ea
Including:
- An finished, programmed and untested Si570 Clock Board (without Si570)
Other includings are as same as above
For 56.320MHz HAM radio Si570CAC000141DG only (Mark on chip: 570CAC000141G, may not work with other part number)
16. Finished FIFO isolator board V2.5 $45.00 CAD/ea
Including:
- An finished and tested V2.5 isolator board
-Two 10P FFC cables
17. Finished TPS7A4700 low noise regulator board V2.5 $25.00 CAD/ea
Including:
- An finished and tested V2.5 TPS7A4700 board
- One 3P SIP 2.54mm socket
- 7 optional 10uF/16V X7R TDK MLCC capacitors
18. PCB of TPS7A4700 low noise regulator $3.93 CAD/ea
Including:
- An empty TPS7A4700 reg PCB
19. Passive Battery Management Board V2.5 Mini KIT $9.98/ea
Including:
- An SMT finished Battery management board with delay surge protection function ready(without realy)
- Three terminal block connectors
- Three 2P PH2.0mm sockets
- Three 3.3 ohm and one 0 ohm 2010 SMT resistors
Terms and conditions
- All finished PCBs are factory assembled
- Loop tested and bit perfect confirmed for all items note as tested
- Technical support by email or via DiyAudio thread
- Repairing for free within 1 year from purchase, buyers pay any possible round-trip shipping and parts
- I provide firmware upgrading service for free within 1 year from purchase, buyers pay any possible round-trip shipping
- No return as DIY KIT
Selection guide
1.If you just stick with one Fs I2S source and do not change it often, for example, 44.1 KHz I2S from a CD player, then the I2S FIFO KIT with single clock board is working for you without any problem. You don’t need other two boards. With both 256*Fs and 512*Fs default MCLK frequency available,FIFO FW V3.80 provides more options for clock. One XO frequency can run two Fs, and one Fs can use two XO frequencies.
2.If you Fs will change often or album by album, for example, I2S from a USB, then you will need the Dual XO Clock Board or Si570 Clock board working together with the FIFO.
3.If you need including the S/PDIF input and output functions or you want to setup a S/PDIF FIFO, or you need switching input between S/PDIF sources and optional I2S source, then the S/PDIF Interface Board would be your choice.
4.With the FIFO FW V3.80 and the I2S backdoor KIT, you can include an additional I2S input source from the S/PDIF Interface Board.
5.Isolator board is highly recommended for your DAC to make clock board as a DAC local analog section with ground loop cut from all other digital frontend.
6. Si570 Clock Board was optimized to ESS DAC SYNC mode with MCLK running at high frequency. The phase noise performance may not as good as CCHD957 when switched to same frequency. If you just need 22.xxx and 24.xxx MCLK, Dual XO Clock Board would be a better choice.
7. The output capacitors assembled on the TPS7A4700 LDO board are 10uF 25V X7R MLCC. They sound with great details, quiet background and beautiful high range. But I come across another 10uF 16V X7R MLCC which has wonderful middle range. I’ll include 7 of them for each TPS7A4700 board for GBIV. It doesn’t mean 16V MLCC is better than the 25V one. It’s just in case you want to try a different taste. If it is possible, let me know which you prefer to.
Delivery and shipping
Delivery via Canada Post. Will be in one of the three following types:
Less than 100g: in a letter, no tracking number
Less than 500g: in a bubbled envelope with/without tracking number
Above 500g: in a box with/without tracking number
Pleas put correct shipping address on your order form and let me know if you need a tracking number, I’ll decide the type of shipping to make a maxima saving for you.
Please understand I don’t responsible for lost mail. So with a tracking number is recommended. If you select without, you have to take the risk. I’ll list the roughly postage (in CAD) below for reference:
To Canada:
In a letter without tracking#: $1.5
In an envelope without tracking #: $4.5
In an envelope with tracking #: $12-
In an box with tracking#:$17-
To USA:
In a letter without tracking#: $2.5
In an envelope without tracking #: $8-
In an box without tracking#:$12-
In an box with tracking#:$21-
To international:
In a letter without tracking#: $4.5
In an envelope without tracking #: $15-
In an envelope with tracking #: $29-
In an box without tracking#:$21-
In an box with tracking#:$68-
To save time, I will not ask for or return the actual shipping difference within $5.
How to buy
1.First, please confirm you have already registered here on the waiting list. Make sure your order number is correct (“GBIV”+waiting list number, eg GBIV23)
2.Then, to keep your privacy, please download the empty GBIV order form (GBIVOrderformEmpty.zip, excel format, pdf format just for reference) at bottom of this post, full in all the necessary information in blue section by excel, rename the file name staring by your order number on the waiting list and following by your Diyaudio ID(for example GBIV23_YourdiyAudioId.xls), send the finished excel order form file back to my email box: iancanada.mail@gmail.com
Following informations are required in the order form:
- Your diyAudio ID
- Your PayPal account (usually an email address)
- Your email (if it is possible, use the same email as Paypal)
- Items and quantity you want to buy
- Shipping address (if it is possible, use the same as Paypal)
Please double check and make sure the shipping address is correct and with a postcode, otherwise it may result in losing of the mail.
3. Once the items are ready for delivery, you will receive a conformed invoice from Paypal based on your order from my email box with my PayPal account.
4. Making payment. (PayPal only)
5. KIT will be shipped within 7 days after I’m getting the payment.
GBIV will be closed next weekend(Feb.23). But now, the GBIV is still open. New registers are still welcome before the closing time.
I’m very pleased having opportunity sharing the FIFO KIT with the diyAudio members again, and I highly appreciate the so many helps I received from the community.
Finally, I want to pay special thanks to my friend Mr. George Richardson, who provides helps to the community by revising the technical documents for each KIT. All group buy members benefit from his perfect job.
Enjoy you project!
Ian
  • GBIVOrderFormEmpty.zip
  • Adapters.zip
  • BatteryManagementV2.5.pdf
  • IsolatorAdapterV2.5.pdf
  • TPS7A4700V2.5SCH.pdf
  • SPDIFinterfaceBoardGBII.zip
  • DualXOGBII.zip
  • Si570ClockBoardUsersGuide.pdf
  • IanFIFOKITGBIV.zip
Pictures of Ian FIFO GBIV items(1)
Please fine the picture names for details.
Ian
GBIV register list
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
11. edbk
12. atom6422
15. Zoran
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
25. spm
26. Fridrik
27. ccliu
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
40. necplusultra
42. nvduybom
46. leejh
49. enantra
66. edlinssen Si570
68. hughs
77. JamesHill
81. TheShaman - TBD
91. Bemused 6x TPS7A4700 Regulator boards3 x BufalloIII u.fl adapter kit
Hi Ian,
Great things are happening here now :) Thanks.
Just a minor note - the order sheet states "FIFO isolator board V1.5 MINI KIT" instead of V2.0. I just would like to make sure which one is in the stock. According to some previous posts it seems that there is no V1.5 left so we should get V2.0, right?
Nice day to Canada,
Daniel
Hi Ian,
Nice day to Canada,
Daniel
Hi Daniel,
The isolator board, I just keep V2.0 PCB KIT and V2.5 finished board in stock. V2.0 and V2.5 are almost the same.
I don't have any V1.5 left.
Ian
