Thank you for your updating
Thanks guys for your updating. Please let me know if you need any support. Good luck to your project. Have a nice weekend.
Ian,
I received kits today. beautiful tiny pcbs and really nice packing.
thanks!
Kits received. Thanks
Arthur
I have received the kits in perfect condition.
Thank you!
Ian,
Just confirming you got my order email sent to your email Thursday evening.
Thanks!
Greg
Hi Greg,
I got. Invoice was sent to you by email. Nice weekend.
Arthur
My kits should be shipped couple days earlier but still not received;😕
Your KIT shipped on Mar.10 to your addres ..20th floor.... Please don't worry about that. Should be no problem. Good luck.
Hello Ian
Item posted has been received_safe and sound.
Most pleased with the quality of your work_impressive.
Thank You!
Yours Sincerely
John
PS
Not quite sure about how and where I'm going to use it
at this stage_probably to mod my MERIDIAN 800 (early version).
Thank You!
Yours Sincerely
John
PS
Hello Ian
Thank You!
Yours Sincerely
John
PS
Hi John,
Thank you for your update. What clock oscillators did you use? You will make a lot of new discovery. Have fun with the KIY. Nice weekend.
Hi Ian,
What is the power consumption of the fifo and dual clock board? (say with the ccdh-957 clocks).... Thanks
Hi Ian,
Base on what I actually measured, three boards together with the two cchd975 XOs was 110mA in total. 🙂 Nice weekend.
Wow, very impressive, I am truly inspired by the quality of the work, and the clean professional kits.
Hope there are still some kits available!
This is really an amazing project, can't wait to try it.
For now, I would like to buy the dual XO board, for use as a clock for my PCM4202/PCM4222 Delta-Sigma ADC's.
Is there any word on the FIFO board supporting DSD?
I imagine it would support DSD encapsulated in PCM ala dCs, but would raw DSD work? If it is a question of data rate, it should be possible.
Hi alexcount,
Thank you for interesting. I only have a couple of KIT reserved for some previous order. You have to wait until I confirm some of them is available. Sorry about that.
To support DSD, it would be another FIFO project. Not only because the timing of DSD stream is totally different from I2S, but also the data is much more. It will need more memory, 4Mb will be not enough for buffering DSD.
I'm still hesitating...if...I'm.. to spend another couple of month to develop a DSD FIFO 🙂.
Regards,
multichannel fifo first please 😉I'm still hesitating...if...I'm.. to spend another couple of month to develop a DSD FIFO 🙂.
Hi Ian,
I received the kits in perfect condition.
Thank you!
Ian,
Received the item today. It was nicely pack. Thank you.
-coolhead
Hi Ian,
I have received the kits.
Thank you!
Thank you for your updating. Please let me know for any support. Have fun with the KIT.
Regrads,
In case there is sufficent interest to warant a second production run, I would like to register for.
1*I2S FIFO KIT
1*Dual XO Clock board
Maybe some additional cables, TBA.
Hopefully sufficient people are insterest in the GB to warrant another run!
Best Regards,
James.
1*I2S FIFO KIT
Best Regards,
James.
Hoping to hook up to a basic NOS TDA1541 DAC board (a semi-corrected red barron) next week.
Few questions after reading the excellent documentation :
Hoping to hook it up to a no frills TDA1541A over Easter break.
It will be RBCD only - Legato - Spif BNC -Spdif interface pcb - i2s out - fifo- reclocker- NOS modified TDA1541 redbaron PCB.
Few questions:
1. The spdif board came with only one BNC cable, I was assuming this wasn't as important (since its pre-Fifo) and would use the FPC/FFC 1.0mm ?
2. I did order an extra set of the BNC cables for the final I2S output. But I need a set of the micro-bnc sockets for my DAC board, anyone have a digikey or Mouser part number ?
3. Also I just need confirmation that the spdif board and the fif/reclock have good regulation on board and we just need to supply a decent LM317 DC ?
4. Last since this is going to be RBCD only, do I need to change the crystal on the spdif board (24.576 mhz) to a 512x44.1= 22.5792 clock, I am confused as to the choice of 48x512 for that crystal
Please bear with me and I apologize for all the question but working wihout a schematic (completely understand why) is a bit of a challenge for how I normally put together a project ?
Few questions:
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
