I2S slave on mainline 4.13Anybody made it in slave i2s mode yet? Mclk from dac side.
Russian page I2S slave на mainline ядре OrangePi
Yes H2/H3/H5This is very interesting! I suppose that your patch will work on any OrangePi board, as long as it is based on the Allwinner H3?
Any chance you can add support for DSD and 768K Pcm? I would like to drive a ESS9038PRO from a NanoPi NEO2 without additional USB-to-I2S converter. If I understand correctly it should just be a matter of bumping up the supported frequencies and adding logic for the correct clock divider.
NanoPi-NEO ALSA-Add-rate-defines-for-352k8-and-384k
NanoPi-NEO/NanoPi-NEO-i2s.txt at master * takobozu/NanoPi-NEO * GitHub
- PC Based
- i2s connection - Orange/Dac
