looking for a bulb for a sharp xr10x but i guess if you have the entire bulb and reflector for it that would be great. i know it costs more but i dont know with my luck if i would be able to do this without breaking bulb...
so that is 135.00 total...what are the specs on the bulb itself. is it exactly like the original bulb in lumen and lifespan?
135.00 total with shipping? now what are the lumen and lamp life of the bulb? just like stock?
infocus sp4800 lamp
YWH
A fair while ago I bought a replacement lamp as a spare for when my original needed replacing
when I received it from you I asked if I should put it in to test it and use original as spare but you said not to bother
well the original is getting dimmer and so I put yours in but nothing...no fan no light just a flashing green light which I assume is a fault error code
I then put original back in and worked straight away
I assume as the original worked after being taken out there is no reset procedure needed to make new lamp work
any idea as to whats wrong
how can I test lamp
send answer to stevejohn54@live.com.au
YWH
how can I test lamp
before we get to that should I reset the lamp hours option
will this make this new lamp work
I didnot do that as was not sure if this would stop me re using old lamp
Hello, i am new here .. i have a busted lamp in a Sharp XR-10S ... it lights up for a minute or so and shuts off, i did the bypass mod, now i need a light ... i would like something more powerful so i can use not only in complete darkness what are my options and how much does it cost ?
hello, i have a Sharp XR-10S and would like to upgrade the busted bulb in it, what do i need and how much would it cost ?
what about the car HID conversions ... are those safe ?
Hello to everyone.
And special HI to YWH
ywh,
can you help me?
Projector lamp unit is RLC-150-001
on bulb HSCR150H6H
lamp 75V/150W
I don't know AC or DC
Do you have something to offer 🙂
Price + Shipping to Latvia?
in case you can answer to e-mail
smarts@apollo.lv
Thank You in advance.
ywh,
can you help me?
on bulb HSCR150H6H
lamp 75V/150W
smarts@apollo.lv
I've got a BoxLight CP-730e and it's got a 132 W AC lamp.
The lamp measures 2 1/4" x 2" x 2 3/4".
does anyone have a clue on something I can use for this?
lp350
looking for a lamp and reflector to use in infocus lp350. The lamp is SP-LAMP-LP3F, as I understand it's 270w SHP. Maybe somebody has something to offer?
Hi guys!
I come back,
please send E-mail to me if you need burner of projector lamp, and you can rebuild you lamp kits.
I need to know the words in your reflector.
I come back,
Burner?
Hello to everyone.
ywh,
can you help me?
on bulb HSCR150H6H
lamp 75V/150W
smarts@apollo.lv
Hi guys!
I come back,
Hello to everyone.
ywh,
can you help me?
on bulb HSCR150H6H
lamp 75V/150W
smarts@apollo.lv
your burner is a 150W AC which requires a minimum of 15KV ignition voltage. Not sure LumenArc ship to Latvia but they have the burner:
LumenArc - 150W AC Projector Lamp Bulb - High Voltage Ignition
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- I got my new lamp. It is for commercial projection use. people use it to replace the
