I got my new lamp. It is for commercial projection use. people use it to replace the
p-vip lamp
Hi ywh
I've bought a Mitsubishi xd300u in the specs, it says it's a 200W P-vip lamp (VLT-XD300LP)
looks like a bsm-dc (rolled wire through front arm of the glass, like 8~9 turns), will be that correct? I can post some photos if you need them
But there is another problem, this projector has a protection circuit that powers off the lamp when it has a long life, and it still works if I reset the counter (it's really a crap, because the lamp it has now still has a good brightness); I suppouse it's a voltage, power or current protection so I wanted to know if the lamps you sell will pass that protection or if you know how can i avoid it
Thanks for your time
LP350
Hi YWH.
You quoted me a price a little while back for LP350 lamp only @ $80, is this still available?
Also, I think I may have found a way to make a custom & unbreakable reflector, at least for this projector, and probably others if needed. I will post pics as soon as I'm closer to a finished product. 😀
I can't send email yet either (under moderation), so I'm going to just join in some conversational threads here and get out of mod... 🙂
Thanks!
-Paul
Lamp for LP500 doesn't work!
Hey ywh,
I received the lamp as promised, got it all installed, but it doesn't work. I think you might have inadvertantly shipped me a wrong/defective bulb.
To make sure the Power supply wasn't bad in the projector, I put a working bulb from another LP500 in it, and it fired up fine. Also, I tricked the cover plate switch and manually read the voltage coming out of the unit. I am reading 520-540 Volts DC.
The info on the back of the working blub reads: SHP22 JAPAN 5K
What gives?
-Mike
Hi flhdari!
you need 270w BSM-DC burner, price is $80, shipping is $5,fee of paypal is $4
Hi felrcf!
what is the wors on your reflector?
Hi piboy
yours is 150W P-VIP, you need 150w BSM-AC burner, price is $80, shipping is $5,fee of paypal is $4
do you have some pictures of your reflector?
Hi abhor
you need 270w BSV-DC burner, price is $40, shipping is $5,fee of paypal is $3
Hi JWLM
Hi mcaramb !
please send it back to me
LP500 Bulb not working (more)
Ywh,
More information:
In my original post, I originally had LP5000 in the subject line, but when I sent you the Paypal payment, I put in the comments that this was a typo, and that I meant I needed one for an LP500.
So, I think maybe you missed that correction. If this stupid forum would allow us to edit our posts, I could have corrected it beforehand.
You had told someone that had an LP530 that they needed a 270w BSM-dc. Is that what I need as well?
As this bulb is already cemented in place, I will have to drill it out, thus destroying it. I am willing to eat the cost if need be since this was mostly my fault.
Let me know,
Thanks,
-Mike
LP500 Bulb not working (even more)
Boy I wish we could edit in this forum...
Sorry about all the posts, but one last thing.
I managed to get the bulb out cleanly. I CAN ship it back now. Apparently the Furnace Cement I was using hadn't dried completely. I think it needs heat to cure completely, so as the bulb never lit, it never solidified completely. So, yes... the bulb is shippable. Just tell me where.
-Mike
ywh said:
Hi fieroboom !
the BSM-DC is not so good to replace SHP, so you can use cheaper JYS/DC only, $40 only. total is $48.
not so bright, about 60% as SHP, 500 hours [/B]
YWH, I like the price, but not the birghtness.... 😀 Is there anything close to brightness and physical size that you have which might work? I'm making a custom reflector, and I can make a custom cage if needed, so I have some 'wiggle room' if you've got some ideas or possible bulbs....
-Paul
