Yup running the C3/C13 cap mod. 10uF OSCONs.
Also now running a Twisted Pear Trident regulator on the AVCC supply to the TAS5548. Nice mod.
I believe there's an I2S input on P23, can't confirm yet. I haven't tested I2S input at all yet, been working on the car instead...
Long weekend coming up so I hope to post some progress!
Mike
So a good regulator on AVDD supply would be the next mod for me. Can't find any AVCC, could you please confirm that AVCC was a typo ?
Thanks for sharing
Also, consider replacing the nasty 7812 with a new regulated 12V line. V200 is definitely more balanced. Very nice mod.
Cheers
Olly
NB : a car in working order could be useful too
Yup typo. AVDD. From memory you need to cut the trace to C15 (on the top of the board) and connect the regulator across C15. There's 5V supply available on P23, convenient.
Thanks for the suggestion on the 7812, I'll try a TPS7A4700 here.
I'll take some photos on the weekend, when the rugby isn't on...
Cheers, Mike
Cheers, Mike
Using this clock and connection instructions: http://tentlabs.com/Components/XO/assets/XO23mounting.pdf
Hey guys,
I found out about the v200 a little while ago and just stumbled across your mod thread.
How difficult are the upgrades you all are doing? II've done two minor soldering repairs in my entire life, so I'm not sure if I should attempt it or not.
I guess I need to order the amp first, before I start thinking about the upgrades
SMD Soldering Practice Kit
I would recommend practicing on a cheap SMD circuit board first. I've been soldering for 15 years and SMD boards still freak me out...
OK, got I2S working on the AUX input, as per the photo in post #7 of this thread. Nice improvement.
Feeding it from a MiniDSP 2x8 unit https://www.minidsp.com/products/minidspkits/2-x-in-8-x-out
and tapping into the I2S lines.
A bit bulky and awkward so next step is to buy a MiniDSP MiniSHARC https://www.minidsp.com/products/minidspkits/minisharc-kit
which will feed I2S streams to my triple-stack of V200 amplifiers! (active crossover to 3-way speakers)
Photos to follow...
Mike
Photos to follow...
Mike
New XTAL output is 1.4V, hopefully it's ok.
Can't get my new clock to work. I've connected the new clock output to XTAL1 (Y16 side of the previous xtal), removed the 2 capacitors C378 and C379.
Should I need to connect XTAL0 to GND ?
Any idea of what I'm doing wrong ?
Cheers
Olly
Cheers
Olly
Hi Olly,
Did you do it like this? http://tentlabs.com/Components/XO/assets/XO23mounting.pdf
Which clock did you get?
Mike
Mike
Hi Mike,
Yep absolutely.
Could you please post a photo of your new clock in place ? Also have you connected the xtal output to the left side of the old xtal (Y16 side) ?
I've used a 12.288MHz xtal on that board
CD Player High Stability Clock Buffer Module No TCXO Included Assembled | eBay
Cheers
Olly
Yep absolutely.
Cheers
Olly
- Class D
- I AM D v200, Fx Audio d802, optimisation and TPA3116
