Hypex Ncore
went ahead and connected nampon to chassis.
Powered on the amplifier. I hear it play.
Spectacular!!
Its playing in place of a very nice Marantz integrated amplifier. I am not one of those who can usually make out subtle SQ differences. But this amp just feels effortless, i can honestly say i do find it better.
Even if there is no SQ difference, these module are tiny and super efficient.
Hats off Mr. Putzeys.
adding the picture again
The chassis does get a bit warm after about an hour of music.
Thermal contact to chassis on one of the modules isnt as good as i would have liked. Further i think i need more ventilation holes to improve circulation.
I had sanded off the anodization around the XLR mouting, however i did not do that where the ncore modules are placed on the bottom plate.
Does it make sense to unmount and sand the area out? I have to handle the messy heasink paste carefully, dont want any smears to cause shorts on the SMDs.
Just curious and looking only for opinions.
According to experts here, do you think the ncore implements many breakthrough innovations or 'secret sauce' compared to a textbook Class-D?
I am sure lots of iterations and measurements went into achieving the final circuit, but there must be something really clever that sets it apart?
I guess you haven't read Hugo's papers? http://www.hypex.nl/docs/papers/globally.pdf is a good start.
No 'secret sauce', but definitely some good engineering and some breakthroughs in understanding and implementing the feedback theory.
I wouldn't bother with the sanding, as long as you have a proper chassis connection through the audio input cable and XLR connector.
i am probably overthinking this. But the anode coat is pretty good on this chassis and they are not the best conductors of heat and current. Further i did a bit of a sloppy job with the heat sink past under one of the modules.
I am going to factor most of the learning into the second amp that i will work on as i find time
I hope that didn't come across as condescending - it wasn't meant that way. It is just that many of us chose the hypex amps specifically because of Hugo's excellent engineering papers - and the nice thing is that he shares his discoveries and results openly (in conference papers and technical publications, as well as on the net) - no "secret sauce" or voodoo, but open, peer-reviewed application of science.
I would not worry with a chassis with only two amps and one PS - I have to be a bit more careful, with 4 amps and 2 smps's in one chassis.
The fact that your chassis gets warm shows that it is actually conducting heat pretty well. What you don't want is a really hot heat sink/board, and totally cool chassis...
