It illustrates the influence of the input buffer.......
"Ah, but you can't measure a feeling!"
hypex ncore
Do you think those are the only 2 specs that influence sound? And is that from 20hz to 20khz at all output levels?
Which ones do you feel influence the sound?
Probably most of the ones you don't find on the spec sheet
Such as?
Spec's from Hypex/Mola Mola, 20-20Khz 1/2 power 4 ohm THD+N and IMD.
Whats the difference between 2xSMPS600 for 2xNC400 modules vs using 1xSMPS1200A400 for driving 2xNC400?
an SMPS600 is the same price as the SMPS1200, is there any reason for the higher cost of the 2xSMPS600 soultion?
Likewise. And my scars were definitely not caused by proponents of an evidence-based approach ("objectivists")...
Please explain, for I am a mild-mannered man.
Ahah! So I see that you are an "objectivist" or was that Freudian Slip?
The problem I see is that you would be inclined to call me a "subjectivist" and you would be entirely wrong. But if you insist, who is the aggressive one? Not me! I see too many being verballed by so-called objectivists as being subjectivist, even when they clearly should not be so narrowly defined.
And what exactly is meant by "evidence-based approach" since evidence takes in many forms, what evidence do you accept or not accept? All I see is "preference-based evidence" and that the human inclination is to see what we want to see and disregard the rest (humble apologies to Paul Simon).
If you take a combative stance, then you will not remain innocent for long.
I want to look at things in a broader context, I seek no conflict, I am in no camp, in no school, just want to take in the scenery, be at peace with all men, have a sharing disposition above all.
So why is there so much unnecessary aggro?
Perhaps because a Proselyte is always more obsessed than his Master? Therein lies the root cause of a lynch mob.
That's the complete amp, not the buffer stage.
Such as?
Real world conditions with actual music playing through them.
Have you guys seen the new NC400-T?
Sacrilege! 😛
You know, some people out there might think this would work. 😀
Sacrilege! 😛
Well here we go. Not using Ncore, but UCD 400 with tube input buffer. I suppose the Ncore would probably be overkill after all the tube distortions were added anyways:
Hybrid amplifier
Hybrid amplifier
It may surprise you, but I built one of these things, just ask Guido.
Yes, it had the LM4562 removed.
Hows did it sound?
Hows did it sound?
Not bad. I did it for a client. A few minor issues had to be sorted, but I got it going. It is not a kit for newbies IMO. It's interesting to note that Bruno must have had a hand in the tube stage - you can tell this by Bruno's signature, lots of Red series LEDs which I believe must be fed by a tight CS and give some kind of voltage reference.
What is the purpose of having both a smps and a linear psu in the same box?
Playing a lot of catch up here but.... I thought the Kaluga used the standard on-board NC1200 buffer stage. Is this not the case?
(Btw the Theta Dreadnaught NC1200 based amp is hard to beat for value.)
Who does that?
- Class D
- Hypex Ncore
