Good God, you guys are still going... I thought this might have settled a little during my trans-Atlantic flight
bavmike just admitted that op amps that sounded different, measured differently...woohoo, maybe we can add some objective data to the subjective banter; not that I believe it is the be all and end-all but some objective data would be nice.
When I come out with my finished products, I won't be shy to share a full gamut of AP measurement specs.
I have clearly heard the difference between the discrete opamps I've tested.
Double-blind?
No. It explains why they *could* sound different.Each one of the discrete opamps I've tested have completely different circuits, made from completely different components, and measure much differently. Which explains why they sound different from each other.
Including comparisons between the different buffers?
hypex ncore
I'm not so insecure about both my measurement and listening results that I needed double blind testing. If it measures impeccable, and sounds impeccable, it works for me.
All I can say is the buffers won't be the bottleneck for me. The specs exceed the specs of the NC500's.
Double-blind?
No that was just early experimentation. It's not often you'll find measurements of the test results of all of the prototype circuits manufacturers tried during the development of their products.
Clearly many people in the audiophile community have never really contemplated the question "how do I know what I (think) I know?".
I guess one of the problems with hi-fi is that most audiophiles are too old to have had anything like the modern international baccalaureate curriculum at school or university One of the more useful components is Theory Of Knowledge or TOK.
Of course not. But it is also not often manufacturers make claims on public forums about their prototype circuits.
There has not been any doubt that it is possible to measure your amp. Thus stand-alone measurements don't really tell us anything new. What would have been interesting would have been measurements showing the differences between the different choices.
Just to point out- DBT is almost always badly flawed, enough so that many people can't identify some pretty substantial differences. Our enjoyment of gear is on a relatively long timescale, our listening environment far removed from the stresses of testing, most people listen to music as an escape from pressure, and introducing a test methodology completely changes how they perceive things. Recording engineers etc are more used to listening critically and so are less challenged by the paradigm shift.
So while placebo effect is huge, a lack of reliable perceptive differences in DBT/ABX testing leaves plenty of room for perceptible differences masked by the test itself.
Not necessarily the case here, but just important to keep in mind when asking someone to prove the audible differences in one thing or another.
True. But it still remains our best reference test, and it is the industry standard (when dome properly).
ITU BS.1116 : Methods for the subjective assessment of small impairments in audio systems
ITU BS.1534 : Method for the subjective assessment of intermediate quality levels of coding systems
Why ABX Testing Usually Produces Null Results with Human Subjects
by Teresa Goodwin
ABX testing has been extremely controversial since it was introduced decades ago. It is my hope to put this testing protocol in its final resting place by combining its sad history coupled the difference between how humans perceive sound and how ABX testing actually is applied.
The "X" in the ABX is either A or B, randomly selected, the listener needs to identify whether that "X" is "A" or "B". Unfortunately human beings do not have the ability to compare three sonic events sequentially. One must keep a sonic memory of sample "A" they just listened to so they can compare it to the sample "B" and then listen to "X" and try to decide if it sounds more like "A" or "B". It is the introduction of this third sound that makes it impossible for human beings since we can compare two different sounds as long as we don't wait too long however our sonic memory cannot juggle three no matter how many times one is allowed to go back and forth. Thus ABX tests usually get null results, and cause listening fatigue.
The better way to do this is to play "A" in a relaxed setting for an entire piece of music, at least five minutes and then play the same piece of music with "B" and then ask not if they sound different, but instead which one did you like? This is how most people shop for stereo equipment. Thus, it is not the methodology of ABX tests I object to, but instead their very existence.
Since the introduction of ABX double blind testing protocols many decades ago I have known they were complete and utter frauds and that is one reason I started my print newsletter in the 1980's and later my blog "The Audio Iconoclast" http://audioiconoclast.blogspot.com/
From its purpose statement "The Audio Iconoclast will challenge many deeply held beliefs in both the audio and musical communities. In music and its reproduction explaining what one hears when it is not directly measurable is not easy, the common practice is to dismiss it. This is wrong! In our world of music enjoyment there are subjectivists "music listeners" and objectivists "audio scientists" who try to measure phenomenon. Music listeners believe what they hear with their ears. Audio scientists do not believe what they hear unless they can quantify and measure it. If they cannot measure it, it does not exist and they convince themselves they are not hearing what they hear! My quest is to show the wisdom of enjoying the sound of music and accepting what one hears, even if it cannot be scientifically proven."
For example SACD would have replaced CD by now if not for ABX tests and pseudo-scientific studies in AES papers. Anyone possessing a pair of ears on the sides of their head can clearly hear the huge difference between low and high resolution for themselves however too many of them have been brainwashed not to believe their own ears and instead rely on these pseudo-scientists who over the years with ABX double-blind testing have proven:
1) All amplifiers sound the same.
2) All CD players sound the same.
3) A coat hanger sounds the same as an expensive interconnect.
4) MP3 sounds the same as CD.
5) CD sounds the same as SACD.
6) High resolution PCM sounds the same as DSD.
Remember the infamous 1987 blind listening test conducted by Stereo Review that concluded that a pair of Mark Levinson monoblocks, an output-transformerless tubed amplifier, and a $220 Pioneer receiver were all sonically identical?
Or perhaps you remember the ABX test that was likely the most damaging to these pseudo-scientists, comparing a known audibly defective amplifier to a perfectly working one? All listeners were able not only to hear the defect in the amplifier but able to describe it's distorted sound under normal listening conditions. However using ABX testing protocols none were able to identify the difference between the defective and the working amplifier with any statistical significance, thus proving beyond a shadow of a doubt that ABX testing does not work. In addition I am sure none of the participants would be willing to take home the defective amplifier, I am quite sure they would all want the perfect working one!
ABX double-blind testing should be banned by all intelligent people as the absolute scam it is. If one cannot prove the differences people experience every day of their lives when listening to music they love then any such tests are total and complete failures. But more dangerous than that they are hurting the sales of superior audio equipment, superior recordings and the musical satisfaction of gullible music lovers who believe these tests instead of their own ears because of the scientific garb they are dressed in. It is time for the real motives of the anti-high resolution crowd be revealed and their rhetoric buried forever so the masses can actually listen to high resolution with unbiased ears!
In summery ABX double-blind testing does not prove that everything sounds the same as real sonic differences are easily heard in casual listening. No, instead what ABX double-blind testing proves is that human subjects do not have the ability to compare three sonic events sequentially with any statistically significance, revealing a deficiency in short-term sonic memories of our species.
I believe even the most golden-eared audiophiles would not be able to identify differences with any statistical accuracy between an MP3 music file and a professional master recording using ABX double-blind testing protocols. This does not mean we should all only listen to MP3s on the cheapest stereos we can find, quite the contrary it means that we should enjoy the highest resolution music possible on audio equipment that we have determined to sound the best using our ears in standard casual listening evaluations.
Further reading:
ABX test
http://en.wikipedia.org/wiki/ABX_test
Blind Listening Tests are Flawed: An Editorial by Robert Harley
http://www.avguide.com/forums/blind-listening-tests-are-flawed-editorial
by Teresa Goodwin
Further reading:
ABX test
For example SACD would have replaced CD by now if not for ABX tests and pseudo-scientific studies in AES papers.l
Enough said. 🙂
I was just tying to inspire others to think outside the box with their buffer designs. I think Hypex amps can be the amp for everyone with the right buffer. I'm tired of reading reviews like this when we all know Bruno created probably the most perfect "straight wire with gain" amp yet:
Mono and Stereo High-End Audio Magazine: MOLA MOLA MAKUA AND KALUGA review
Not everything from the above sounds logical and some of it runs contrary to the prevailing and proved wisdom: “All simple circuits change the signal audibly, so one has to get to grips with more complicated ones that don’t. Isn`t it the other way around?
From the article. It's obvious the author is hung up on preconceptions and is not being objective.
by Teresa Goodwin
Further reading:
ABX test
Well, women who have there period aren't the most reliable contenders in a ABX test. 😛
I agree.
Sheesh, yes. "A quick comparison with the Crayon CFA-1.2 showed that this little class AB integrated (with a SMPS) reproduces music that is packed with energy and sparkle - it was unbelievable! It even managed to sound more powerful within a certain power envelope. The Crayon amp sounded much more reminiscent of the real thing, even the bass was punchier and more controlled at the same time. "I'm tired of reading reviews like this when we all know Bruno created probably the most perfect "straight wire with gain" amp yet:
Sounds like the Crayon amp had a lot of distortion - 1-2% THD/IM would probably result in "energy and sparkle", "sounding more powerful within a certain power envelope", and "punchier bass".
I agree.
Yep but this is reality. This is what most people like. So you can tell everyone they are wrong and not sell anything, or built them what they want. Better yet, give the option to choose, with the same amp.
Well, women who have there period aren't the most reliable contenders in a ABX test. 😛🙂
That is a rather sexist statement. I don't think it has anything to do with being a woman, it is just that Teresa Goodwin has no background in technology, and she would actually make a Area 51 conspiracy theorist look sane ("I can only listen to vinyl and SACD - PCM is completely unlistenable and give me instant headache").
The real issue is that the whole blog piece doesn't contain a single reference to factual evidence - it is all purely her personal opinions. She is of course entitled to them, just like the other 7 billion people on this planet...
Sexist or not, where are the woman in the audio industry? Can you name one on this world wide forum?😕😕
The dominance by males is so strong, that most of the women I've met in (any meaningful capacity) hifi were once men! Quite truthfully a majority!
- Class D
- Hypex Ncore
