Trial done:
Without ribbon
Just one psu for one module
Switch S1
Amp enable via J4
No ready status....
Voltare seems correct and also cable,only doubt is related to flat cable but in theory you can turn them on just by H+ H- and GND by just using S1....
The ready status came when amp is activated or with input signal and load?
Anyone can confirm me the J4 pin out ?
Without ribbon
Switch S1
Amp enable via J4
No ready status....
Congrats Colin! My concept, Richard from Sonic Imagery's buffer circuit, and your work ethic, resulted in the most glowing Ncore based amp review in 6 moons history!! He compares it right up with the Swiss giants!!
6moons audioreviews: Nord Acoustics
I must say he should have used some beefier speakers to review a 700WPC amp though. Something that would be a much better match and take advantage of the ultra low output impedance, and high damping factor.
It's not a 700 WPC amp.
The 700 W is peak power at 4 ohm load impedance.
Continuous power rating, which is the norm, is one fifth of peak power as specified by Hypex.
So it's more a 100 - 150 WPC amp.
The advantage of ultra low output impedance and high damping factor, which actually are the same, has never been confirmed to be that important wrt the loudspeaker interface.
Well seems like there's 100 different standards which amp power specs are rated. Very few rate with a true continuous spec. Either way using a big 3/4 way speaker with dual 10, or 12" woofers and 86dB/1w/1m efficiency, would have done the amp more justice. Then he could do the comparison with the Crayon and Job and see what's superior.
When they do reviews of massive Soulution or Pass amps they don't use puny little 2 ways and talk about how the damping is excessive.
Well I know, or better take seriously, only one standard, which is continuous power at specified load impedance.
All other standards are meant to present results better than they are in reality.
Hypex is perfectly clear in this regard.
Much has to do with cooling capacity; did you already read Hypex' white paper on this subject to enhance your knowledge?
The max current output tells a better story. Any competently built amp will have proper cooling. So not really an issue.
I guess (hope) you mean max continuous current output, which is the same as continuous max output referred to load impedance.
The max is a good enough reference point. NC 500's are 28 amps, NC 1200's 38 amps. The Soulution 501 are 45 amps.
soulution 501 Monoamplifier
If that isn't enough you might have to endure the painful process of actually listening to them to see if they meet your needs. OR I suppose if you have enough money you can send all of the potential amps you're considering out for independent testing before allowing them into your listening room.
Very likely enough, but very seldom necessary.
The rare low efficiency loudspeakers which dip down to 2 ohm in the lower register will benefit from good amplifier current capability.
But it's merely a specification; sound quality can not be declared by just this ability. More factors are at stake.
By the way I auditioned a Nord 500 amplifier; it's a great amp no doubt, but in the set up I auditioned there was no need for much current capability.
What did you use for a preamp?
Their pseudo-technical copy really is hilarious, get a load of this -
The high Class A operation supplemented by 47,000µF of storage capacitance results in a nearly infinite impulse response
A quasi-IIR high class A amp, who'd have thunk it?
Save
A quasi-IIR class A amp, who'd have thunk it?
People who buy these amps don't care how they're made. They only care if they're more expensive then all their friends amps. So as long as there's big words in the description, good enough.
These Soulutions got sold only after a whole $10k price drop from the original asking price - What's Best Forum (WBF Forum)
Let me add my congrats to Mike's Colin, commendable work!
Save
Save
A lot of true audiophiles don't like them because there's not enough coloration. So they put a tube dac or pre with -85dB noise floor and 3% THD in front of them so they sound good.
To clearify, all the datasheets from hypex state Watt RMS.
More information on that subject in an application note from Audio Precision
- Vendor's Bazaar
- Hypex NCore NC500 build
